Cruising range for 38 gal tank?
Discussion in '2.5 Gen Tundras (2014-2021)' started by JDHolliday27, Jan 22, 2018.
  1. Jun 6, 2018 at 3:21 PM
    Kelly70
    Kelly70 New Member
    Kelly
    2018 Toyota Tundra Crewmax TRD
    Maybe someone here can help?
    I have a 2018 Tundra Crewmax TRD. It’s my 4th Tundra so I’m well acquainted with them. I’ve had it for about 8 months, and never once has the low fuel light illuminated or alert sounded for low fuel. I’ve gotten the miles to empty down to 2 and still no light. Service Dept says it’s dunctioning normally in tests. Has anyone heard of such a thing? I try not to rely on the light, but sometimes I forget. Plus...it’s just supposed to work!
    Y0TA PR0 likes this.
  2. Jun 6, 2018 at 3:25 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome to the forum!
  3. Jun 7, 2018 at 9:51 AM
    GoCboys
    GoCboys New Member
    TX
    2018 MGM CrewMax
    Welcome Kelly70, congrats on your 2018!
    Now that you mention it, I have not seen mine on yet either. Check out my pic from post in January - still shows 18 miles to “empty”, lowest I’ve been. Nice to think that reserve is in their but don’t want to chance it.
  4. Jun 7, 2018 at 10:14 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    when my truck was stock, the low fuel light would come on around 475 miles and I would fill up between 525-550 miles. If I were to run the tank dry, it would go 600 miles.
    now with the tires and small lift, the low fuel light comes on around 425 miles and I fill up between 450-475 miles. If I were to run the tank dry, it would go 525-550 miles (depending on how heavy my foot was during that tank of gas :D).
    I ignore the "miles to empty" display and, instead, I calculate my mileage by hand.
  5. Jun 7, 2018 at 10:22 AM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    You notice how far off your electronic MPG indicator is?
    I've got the numbers for the last 6 months or so (havent calculated them all, but write down ODO, Trip, Electronic MPG - then reset trip and E-MPG before taking off from the gas station).
    My readout seems to be about 0.5mpg off. Truck is stock from the dealer (has a wheels and tires package that may effect - TSS comes with 20" rims and offroad tires).
    I usually fill up around half a tank - but when i'm getting lazy i'll let it go further - usually not much more than 390mi which reads about 1/4-1/8 to empty i think. usually average 14.5mpg or so (hand calculated) ... lots of city miles. averaged about 16-17mpg on a road trip from TX to California.. depending on what part of the trip i was on lol
  6. Jun 7, 2018 at 10:24 AM
    trdprobped17
    trdprobped17 New Member
    I usually get about 520-540 on the indicator at fill up. But, surprisingly it’s been telling me that I have 550+ miles available at fill ups, ever since I installed my TRD CAI. And I am running regular unleaded fuel all the times. I do have the flex fuel 5.7l, but, I have never put anything but regular unleaded in it.
    HecticEnergy likes this.
  7. Jun 7, 2018 at 10:38 AM
    Netmonkey
    Georgetown, TX
    yeah, the electronic display has always been a little off. it is fairly close, but it is still just an estimation/projection. calculating it by hand at each fill up is exact.
    for me, the "miles to empty" display reads zero right at about when the low fuel light comes on, but the miles per gallon display is always reads about 0.5 mpg higher than what I calculate by hand.
    Interesting observation...
    Now that I am running the 295/55/20 tires, the speedometer and the odometer are extremely accurate (verified by gps and the speeding ticket that I just got :)). as opposed to the stock, 275/55/20 tires, I was actually going a little slower and traveling a little shorter distance than what the speedometer and the odometer read.
    HecticEnergy[QUOTED] likes this.
  8. Jun 7, 2018 at 11:03 AM
    drt tundra
    drt tundra New Member
    Alex
    2016 Silver Tundra TRD OffRoad 4x4
    I let it get down to about 10 miles til empty and I'm only able to put 30 gallons. Just filled up yesterday morning after I let it get beyond 0 miles to empty and put 32 gallons in. Regarding the range, mine comes up to about 540 on average.
  9. Jun 7, 2018 at 11:27 AM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    ^ me too
    trdprobped17[QUOTED] likes this.
  10. Jun 7, 2018 at 4:31 PM
    Patrickbateman
    Patrickbateman New Member
    2017 crew 4x4 limited
    I reset my trip every time I fill up. Once it gets close to 550miles I’ll fill up. Usually takes 34-36 gallons at the pump.
    trdprobped17 likes this.
  11. Jun 28, 2019 at 8:49 PM
    kustomeyez
    kustomeyez New Member
    2019 Tundra double cab
    N-Fab steps AVS low profile window vents some front window tint 'N that's it
    Here,... And I was just about to contact the dealer and ask what the hell?.. glad I checked here first. Everything I see makes perfect sense. Thanks Tundra forum Family!
  12. Jun 28, 2019 at 9:02 PM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    I always fill at half so it doesn't matter to me. I'm not driving 5-6 hrs straight without a break anyways.
  13. Jun 29, 2019 at 9:05 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Mine consistently says 500-510 at fill-up. 2018 2wd, 35,000 miles, 87 regular. I go by calculated MPG, the displayed is simply an estimate. In my case, I've gone down to 0 only a few times and have about 9 gallons left at fill-up. In realistic terms I could get about 650 miles before coasting to the side of the road on fumes. The fuel pump will NOT self destruct if you run out of gas, that is an old myth.
  14. Jun 29, 2019 at 9:22 AM
    NorAZ
    NorAZ New Member
    Brandon
    2019 Cement CM
    I agree with this ^^
    Just traded my 07 in that I had for 11 years 275k miles on it and almost always ran it 50 miles after reading zero on display. It would consistently take 25 gallons at the pump, so I was running the tank pretty dry for 11 years no fuel pump problems. Now with that said I have been a little cautious doing that with my brand new 19’. But give it a year and I’ll be doing it again.
  15. Jun 29, 2019 at 10:51 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    This particular meter was somewhat accurate on my 16 Tacoma, but I've learned to completely ignore it in my Tundra. During the summer I'm usually at about 535 miles to empty after a fill up, but in the winter it has gotten as low as 490 after filling up. I think it just averages your MPG's for the previous tank.
  16. Jun 29, 2019 at 11:00 AM
    Metro14536
    Metro14536 New Member
    Brandon
    Las Vegas, NV
    2025 Ice Cap SR5 TRD Rally
    :annoyed::frusty::frusty::frusty:
  17. Aug 25, 2019 at 7:56 AM
    Badmanrick
    Badmanrick New Member
    Rick
    2017 Tundra Platinum 4x4
    I have a 2017 Platinum Tundra with 38 gallons tank, on long trips I average 17.6 mpg. Got 513 miles when it showed 25 miles left. Filled up took 29.6 gallons. That included some city traffic at start of my trip. I kept truck at 70 mph most of the time on interstate.
    After fill up it showed 570 miles to empty. Even showed getting 21 mpg till I hit the hills in NC. Then dropped down to 15 mpg. On the way home was doing 80+ averaged 14.6. Big difference from 70 mph. The most fuel I have put in my 38 gal tank has been 30.1 gallons. That was when I let the mileage meter read 0.
    So there was 8 gallons reserve. If I baby it I figure I can get close to 640miles to an empty tank.
  18. Aug 25, 2019 at 2:26 PM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    City driving I get 400-450 before light comes on. When the light comes on and display reads 0 miles until empty then you have 8 gallons left in the tank.
    Road trip I’ve gotten over 600 miles on one tank of gas. Before I filled up.
    I normally get 20-25 mpg on long road trips
    My last fill up showed 577 miles until empty 03EC3EA2-FA2F-4AE2-A130-53F41671DA26.jpg
  19. Aug 26, 2019 at 12:32 PM
    #49
    nodak67
    nodak67 New Member
    JR
    here are the stats for our 2018. 80-95% of the time is city driving. the min mpg is when towing from ATL to ND with a 6x12 uhaul trailer and the max mpg was driving from ND to ATL (without a trailer) to move furniture back.
  20. Aug 26, 2019 at 12:41 PM
    #50
    nodak67
    nodak67 New Member
    JR
    here are the stats for my 2014 4Runner. the min mpg and the max mpg is from the same trip pulling a 6x12 uhaul trailer for a different load of stuff a few years earlier.
    my driving cycle is 4 days a week at 73 mph to/from work. 1 way is about 15 miles door to door. rest is city traffic.
  21. Aug 26, 2019 at 4:45 PM
    #51
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    I have a 150 mile daily commute all highway. I cruise anywhere from 72-80mph. When I fill up it typically says 500 miles until empty. If I drove it dead empty I could probably get 550-575 miles out of it.
