Cruise Control
Discussion in '1st Gen Tundras (2000-2006)' started by Emerger, Jul 12, 2019.
  1. Jul 12, 2019 at 9:18 AM
    Emerger
    Emerger [OP] New Member
    The cruise control on my 2000 Tundra has stopped working. Any suggestions?
    Pinay likes this.
  2. Jul 12, 2019 at 9:19 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCal
  3. Jul 12, 2019 at 10:22 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What have you checked so far? Fuses? Google search seems to indicated there is a brake control switch. Do you have a brake light out? Apparently that is a common cause.
    "A shorted tail light will prevent the cruise control from operating so check the bulbs are working correctly. Also you should check to be sure the brake switch works properly. There are two sets of contacts. Check them both. You can unplug the electrical connector and use an ohm meter. Both sets should change states when pressed and released."
  4. Jul 12, 2019 at 10:25 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
    I'd be surprised if you don't get the answer to this here.
  5. Jul 12, 2019 at 4:33 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Does the cruise light illuminate when you turn it on?
  6. Jul 12, 2019 at 5:37 PM
    Emerger
    No it doesn't.
  7. Jul 12, 2019 at 5:54 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Does your horn work?
    If it doesn't your clockspring is probably the issue.
  8. Jul 13, 2019 at 7:27 AM
    Professional Hand Model
    Hand Protectors
    NewImprovedRon likes this.
  9. Jul 13, 2019 at 9:57 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Check fuses also
