Cruise control shuts off going up hill
Discussion in '2.5 Gen Tundras (2014-2021)' started by Paul84, Jul 17, 2018.
  1. Jul 17, 2018 at 7:04 PM
    Paul84
    Paul84 [OP] New Member
    Paul
    2014 4x4 Crewmax
    2014 CM 30k miles with a 4wheel camper on the back. While driving up some inclines my cruise will kick off sending my motor up to 4000 rpm for a brief period then back to normal. The first time it happened I got worried because we were in the middle of nowhere and thought my truck was going to grenade. Can it be that the heavy load on the back is effecting the cruise control function thinking something is wrong while going up hill? It started happening more frequently as the trip progressed, to the point that I turn it off going up hills altogether. Any thoughts?
    Thanks
    Paul
    Y0TA PR0 likes this.
  2. Jul 17, 2018 at 7:11 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    If your towing yes it will shut itself off, and let you take over.
    When I tow my trailer I don’t use my cruise.
    Just my opinion.
    15whtrd and landphil like this.
  3. Jul 17, 2018 at 7:28 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Normal w most cruise control. If it slows down about 10 mph lower than what it’s set at it’ll kick off. Like lugging up a hill.
    Black Wolf, landphil and Y0TA PR0 like this.
  4. Jul 17, 2018 at 7:35 PM
    Tundrazy
    Tundrazy Turd Bro
    David
    '17 CM Cement PRO
    My 2007 SR5 never did that while towing my 3-place ATV trailer, but my 2017 Pro does it every time I ascended even the slightest of hills:notsure:. Is it newer programming to shut down the cruise control to save over shifting (heating) of the transmission?
  5. Jul 17, 2018 at 7:38 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    What speeds are you doing? What is it at the start of going up the hill and what is it when it kicks off? What is the road grade? Elevation?
  6. Jul 17, 2018 at 7:44 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You have bigger tires on the ‘17?
    Does Tow/Haul change anything for the cruise?
    What about manually downshifting in “S” mode while on cruise?
    It makes total sense to me to have cruise cut out when constant load /throttle position exceeds a certain point, basically forcing the driver to be in control, and hopefully monitor the gauges and even select a lower gear as needed.
  7. Jul 17, 2018 at 7:47 PM
    Paul84
    Paul
    2014 4x4 Crewmax
    70-75 mph, usually mid slope or towards the top of the hill and so far have only noticed it at elevations above 4000ish ft
    WAtundra4x4[QUOTED] likes this.
  8. Jul 17, 2018 at 7:51 PM
    Tundrazy
    Tundrazy Turd Bro
    David
    '17 CM Cement PRO
    Utah, typically 4000' to 6000' elevation, yes in tow/haul mode. Of course I am doing 75 mph on I-15, so I just think it is part of the programming trying to save the transmission from overworking. Funny thing is my 2007 stayed engaged travelling the same roads at the same speeds.
    landphil and WAtundra4x4 like this.
  9. Jul 17, 2018 at 7:55 PM
    Paul84
    Paul
    2014 4x4 Crewmax
    Thanks. Yes...part of the trip was I-15 to the 70
  10. Jul 17, 2018 at 8:07 PM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
    Same: I rarely cruise control when towing, especially uphill.
    Y0TA PR0[QUOTED] likes this.
  11. Jul 17, 2018 at 8:15 PM
    Tundrazy
    Tundrazy Turd Bro
    David
    '17 CM Cement PRO
    I won't anymore, ha
  12. Jul 17, 2018 at 8:20 PM
    Paul84
    Paul
    2014 4x4 Crewmax
    Thanks y’all.
  13. Jul 18, 2018 at 5:10 AM
    nodak67
    nodak67 New Member
    JR
    after looking at the manual, it has changed to a 10 mph differential (use to be 5 mph), min 30 mph to set the CC (use to be 25 mph), and min 25 mph to resume (as before)
    edit: biggest issue is after 4 mph differential, it kicks out of overdrive or down a gear. that is more annoying than the 10 mph issue.
  14. Jul 18, 2018 at 9:45 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    You read the manual???? haha.. My 07 manual says the same thing although I have used CC when towing a couple time. Not a super heavy load though. CC stays solid.
    NewImprovedRon likes this.
