Crooked steering wheel with straight alignment?
Discussion in '2.5 Gen Tundras (2014-2021)' started by andnyleswillriot, Sep 30, 2020.
  1. Sep 30, 2020 at 6:42 AM
    andnyleswillriot
    andnyleswillriot [OP] Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Just got my tundra a couple weeks ago, had a full mechanical inspection at a trusted shop done and my steering wheel is crooked to the right by 5% they say (and I can definitely see it). They said the truck tracks straight and that it's really not an issue. Well suffice it to say that it is to me because it bothers me at some point on almost every drive to have a newer truck with a crooked steering wheel haha
    Any way to fix it? I found a video or two showing just using a wrench underneath to straighten it out but really have no idea what I'm doing down there. Not afraid to get down there and try though. Thanks!
  2. Sep 30, 2020 at 6:48 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    One way to do it is loosen the coupler on the half shaft under the dash, turn the steering wheel to straight and re-tighten the coupler.
    Wvmoonshiner, joonbug and sr5shark like this.
  3. Sep 30, 2020 at 6:48 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I hear ya man! That has to be perfectly straight for me or I lose sleep, Lol
    Providing everything else is good, The straightness of the steering wheel is adjusted by the Tie rods. I did mine when I switched to a leather steering wheel by watching a couple of youtube videos. If you don't feel confident any alignment shop can do it..
    andnyleswillriot[OP] likes this.
  4. Sep 30, 2020 at 7:21 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Links? I need to do the same for the same reasons.
  5. Sep 30, 2020 at 7:27 AM
    andnyleswillriot
    Breckenridge, CO
    Any chance you can elaborate on that further? Do I need to remove anything to access that?
  6. Sep 30, 2020 at 7:36 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Just remove the lower dash, 2 screws and pops out. It's a splined coupler, you'll see it. It will click over the splines as you rotate the steerig wheel. Just be sure to tighten properly
  7. Sep 30, 2020 at 7:48 AM
    andnyleswillriot
    Breckenridge, CO
    Thanks!
  8. Sep 30, 2020 at 8:41 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Please post pics when you do it, mine is slightly askew .
  9. Sep 30, 2020 at 8:46 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Yes x2! I replaced mine with a leather wheel but havent straightened it out. Didn't wanna mess with the tie rods so if this is easier, I'm all about. Awaiting your results!
  10. Sep 30, 2020 at 8:49 AM
    Mustache 1
    Mustache 1 New Member
    2015 Tundra ,Limited , MGM
    It has a steering angle sensor . If the sensor was not set during the last alignment it will cause the steering wheel to off. My steering wheel was off to the left 1.5 degrees. Reset the steering angle sensor when I did my alignment and now the steering wheel is straight.
  11. Sep 30, 2020 at 9:02 AM
    Bammer
    Monroe, CT
    So we can't do anything?
  12. Sep 30, 2020 at 9:37 AM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    It’s properly done by the tie rods when adjusting toe. Shouldn’t take more than 5 minutes.
    MTRock, apwisher and EDDO like this.
  13. Sep 30, 2020 at 9:53 AM
    Mustache 1
    If the alignment specs are good then it’s a quick reset but would require a alignment system . Like the Hunter Hawk Elite systems found at most dealers.
    831Tun likes this.
  14. Sep 30, 2020 at 5:55 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Not really. It is possible to do your own alignment w/o the big machines. I've done it and it was/is at least as good as any shop.
    So, I blew my steering rack in the desert. We replaced it and aligned the truck in the desert. It actually came out nearly perfect......except the steering wheel was waaay off. I loosened the half shaft and straightened the wheel, no issue with the sensor or anything else. In the desert we could only eye ball the camber and couldn't do anything with the caster but it ended up being OK. Then (because I keep bending my coil buckets in toward the engine) I had a brace installed from one coil bucket over the engine to the other coil bucket. I took my truck to @Vizsla's house and we did a full alignment in his garage.
    It's done using a digital angle finder for caster, camber can be done with the same tool or even a small level. Toe is set by scribing a line around the circumference of each front tire and adjusting the tie rods so the measurement from side to side is less on the front of the tire than it is on the rear of the tire. It can be very tedious work since w/o rotating pads under the tires, you have to lift the wheels off the ground, adjust, lower the truck, back it up a few feet and roll it back forward. But, it can be done. :D
    String alignment is another DIY method.
    TheBeast likes this.
  15. Sep 30, 2020 at 5:59 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Please don’t go messing with your steering wheel. It’s a simple adjustment of the outer tie rod. They didn’t put your steering wheel straight when they set your Toe. It will literally take them 5 mins to fix. Bring it in and tell them to fix it.
  16. Sep 30, 2020 at 6:46 PM
    GiantWinston
    GiantWinston New Member
    Justin
    2016 MGM SR5 5.7l 4x4 Crewmax
    Toytec Boss Lift (3.5" front / 2.5" rear) 295/65/R20 Nitro Ridge Grapplers 2018 LED Headlight Conversion Pioneer AVH-W4400NEX Headunit
    I did mine recently also. Steering wheel was off just enough to notice. I adjusted each of the tie rod couplers by 1/4 turn (extended passenger side, shortened driver side) and the wheel is now perfect and it didn't mess up the tracking of the truck.
    I marked the position of the tie rod before adjusting in case I messed something up, and to easily see how much each side turned. Nothing to it really.
  17. Oct 1, 2020 at 2:29 AM
    RocknRoll
    RocknRoll I’ll make you famous
    DFW, TX
    2019 MGM TRD Sport 4x4
    5” lift, 37” Toyo R/T’s 20” Fuel AMP steps, Ceramic 20% Tint
    This. I've never had an alignment where its been off and they've left it to me. Im particular about where Ill get my work done, but the alignment shop I use(just today in fact) did exactly what I paid them to do...
    Tundra_361 likes this.
  18. Oct 1, 2020 at 2:41 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    I don't know why you're even considering fixing it yourself. You paid money - take it back to them and tell them to adjust it. It should take them 5 minutes - simply adjusting tie rod ends, like someone already posted. If they say it's not fixable, don't ever go back there again.
    MTRock likes this.
  19. Oct 1, 2020 at 3:32 AM
    BLK1794
    BLK1794 New Member
    Ontario, Canada
    ‘17 Toyota Tundra 1794
    Procomp 7” Stage 1 37x12.5 on 20” Fuel AMP retract runners Anzo front and rear lights Dual Magnaflo exhaust and some other stuff.
    It’s a basic steering wheel alignment. When they did your wheel alignment they never checked that your steering wheel was straight when making adjustments. That’s just laziness.
  20. Oct 1, 2020 at 5:27 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Mine is tilted slightly to passenger side. Do I extend or shorten the drivers side?
  21. Oct 1, 2020 at 5:39 AM
    GratefulDean
    GratefulDean Swagless
    Dean
    Rocky Mountains
    2020 Tundra SR5 TRD in Cement Grey
    Bed Rack, Decked System, Softopper
    Funny, I have the same issue AND I see you’re from Breck, I just spent the weekend there. We blew through 7 growlers from Highside Brewery.
    Anyway, I’m due for my first service (5k) and have asked them to take a look at it (as well as turn off the “key not in the car when a door closes chime”). It’s scheduled for the 22nd. I’ll report back what they say.
  22. Oct 1, 2020 at 5:50 AM
    andnyleswillriot
    Breckenridge, CO
    Unfortunately I bought the truck on Carvana (which has actually been a great experience other than this minor problem) and had the inspection done at a shop they have no affiliation with. The shop didn't do an alignment as it is already tracking straight, so I'm sure if they did they wouldn't have left it like that. All I paid for was an inspection, and I bet they'd charge more to do this as simple as it is. Quite honestly I don't mind trying to learn these simpler things anyway as it is good to know.
    Uhhhh....[QUOTED] likes this.
  23. Oct 1, 2020 at 6:32 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    That makes sense. Was the inspection part of the Carvana purchase or something you just decided to do afterwards? Either way, might be worth getting a hold of Carvana and see if they'll take care of it since they sold it to you that way.
    Personally, though it's prob pretty simple to screw in one tie rod end and unscrew the other, I'd hesitate on doing it myself since it might mess up the alignment even a little bit (possibly unnoticeable) and cause uneven tire wear. Then again...I've dealt with severe uneven tire wear caused by alignments, so I'm a little paranoid with that stuff. Not that you asked :)
  24. Oct 1, 2020 at 6:38 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Driver in, Passenger out...But you really should watch a video.
    Keep in mind that moving the steering wheel method one spline won't get it perfectly center most of the time..
  25. Oct 1, 2020 at 6:39 AM
    andnyleswillriot
    Breckenridge, CO
    It was of my own doing, while Carvana has generally good reviews except for some registration issues, they're still relatively new and I wanted to make sure everything was 100% even on a truck with only 44k on it. I'll probably contact them to see what they say though.
  26. Oct 1, 2020 at 6:47 AM
    Critical05
    Critical05 New Member
    2018 MGM TRD Sport, Crewmax 4x4
    I'd just remove the steering wheel and move it a spline tooth over. Its very simple and doesn't take much time, as I have swapped in a leather Tacoma steering wheel on my Tundra. Just mark the steering shaft and wheel with a sharpie before you remove it so you know where to readjust it too. I'd rather try this as this doesn't affect the steering geometry you just paid to have done. Disconnecting the battery will remove any concerns you have about the airbag.
    There are several youtube videos on how to do this as well as a thread on here on swapping a Tacoma steering wheel.
    https://www.youtube.com/watch?v=xOX_6E5pZYI&ab_channel=Victory4x4
    831Tun likes this.
  27. Oct 1, 2020 at 7:12 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    How much did your Tacoma steering wheel cost??
  28. Oct 1, 2020 at 7:22 AM
    Critical05
  29. Oct 1, 2020 at 7:22 AM
    GiantWinston
    Justin
    I am no specialist here, so please use your own judgement and think things through if you are going to make any adjustments. If your truck is already tracking straight, you should adjust BOTH the passenger and drivers side the same amount, but in opposite directions.
    If your wheel is tilted slightly to the passenger side, when you turn your wheel back to straight, both wheels will turn to the left (looking at it from the drivers seat).
    Looking at my pic of the drivers side tire from the front, you can see how the tie rod adjustment affects the wheel position. In your case when you straighten the steering wheel, the truck will be now be tracking left. You will need to shorten the tie rod on this side to bring that wheel back to straight.
    If you think about the passenger side, when you straighten your wheel, again your passenger wheel will be turned to the left, but on this side you will need to extend the tie rod to bring that wheel back to center.
    In my pic, the blue arrow is pointing to the nut you need to loosen first. The red arrows are the pieces of the tie rod that you will need to extend or retract. You can see my markings on them already. I highly recommend marking them as all the pieces are free to move.
    Also note that only small adjustments are needed here. A quarter turn on each rod my be enough.
  30. Oct 1, 2020 at 8:48 AM
    monaco730
    16 Inferno Tundra
    One spline doesnt always center it. between the two most "northern" splines, my wheel was left and right, never center, so i picked left and will have to do the tie-rods.
