crolison’s OVRLND Camper Build
Discussion in '2nd Gen Builds (2007-2013)' started by crolison, Oct 25, 2019.
  1. Feb 23, 2020 at 4:55 PM
    dirtgypsy
    dirtgypsy New Member
    2008 Tundra TRD
    None
    wow fast work! the ARB bumper and camper look great!
    crolison[OP] likes this.
  2. Feb 24, 2020 at 4:11 PM
    crolison
    crolison [OP] New Member
    Got a couple hours today to work on punching holes in the camper. Mounted my Powertank 10lb propane tank mount. Added in my bulkhead fitting for propane into the camper. Also added in my propex heater outlet into the camper, and finished that interior piece.
    DBB1F840-09CD-435F-97E9-2B26D3EBFA16.jpg 1B0720CF-2FAE-461F-8B02-29603D9F80FD.jpg
  3. Feb 26, 2020 at 10:22 AM
    crolison
    Next step in the propane addition is done, had some custom hoses made up at a local propane store.
  4. Feb 26, 2020 at 4:35 PM
    crolison
    Received an AT Overland jerry can mount in the mail today, so went ahead and mounted it up.
  5. Mar 8, 2020 at 1:46 PM
    crolison
    Finished up my camper side wiring, except for the propex heater. Using Blue Sea Systems switch panel, battery disconnect, scanstrut usb, and renogy solar controller.
    19BB044C-702A-41AC-B2D3-B110660999EA.jpg 92DCCC10-6C55-4F4E-84DD-14A3FCF0B7F9.jpg CB51C7CC-98A8-483C-A5A7-495D80EECF7E.jpg 35C7FDF1-1E33-4173-9683-E9A1325112CB.jpg
  6. Mar 31, 2020 at 8:05 PM
    crolison
    Worked on the propex mounting, exhaust and intake routing a little bit today. Gives me a good idea of how much storage I’ll have once the install of the heater is done.
    38AA68E3-9B0D-4676-977F-E9E24111DADC.jpg 6B1703F2-6655-40D7-948D-8B50FD25C6D5.jpg 589F180F-40B1-45B1-BFF3-8AC315C53D0D.jpg
  7. Apr 9, 2020 at 2:06 PM
    crolison
    Worked some on the driver side storage, and got some wood cut for the platforms on the passenger side. Looking forward to all the storage I am gonna have with this setup.
    4578F43D-1FAF-44E0-B6BA-9A0CC1E4474F.jpg 88900F71-4E46-4966-886F-82BFD5ED3195.jpg 33AC8853-B2C8-49C9-BDF3-F171A7EF1946.jpg 1BE1F339-894C-440C-9D2E-C151F64BB2B4.jpg 37969628-991B-4378-9999-9BB921149DB6.jpg
  8. Apr 13, 2020 at 4:46 PM
    Redcon41318
    Redcon41318 New Member
    Very nice! Whered you get the skeleton bed side storage frame?
  9. Apr 13, 2020 at 6:47 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    What did you use for the headliner and how did you attach it? I have a Four wheel camper that needs a headliner.
  10. Apr 14, 2020 at 8:34 AM
    crolison
    The material is 8020, extruded aluminum. I used mostly 10 series extrusions on this project. I purchased most of it from https://www.tnutz.com/
    The headliner is ripstop fabric, it is attached via velcro sewn into the headliner and attached to the outer edge of the frame.
  11. Apr 14, 2020 at 12:46 PM
    pickeledpigsfeet
    Kings & Icons
    Sounds like a great idea. My headliners get really grungy and it would be nice to be able to pull it oit and wash it at the end of the year.
    crolison[QUOTED][OP] likes this.
  12. Apr 16, 2020 at 9:34 AM
    crolison
    Worked on the upstairs and downstairs ducting for the Propex 2800, and had some propane hoses made up. Now just waiting on a warranty on the propex thermostat to start this baby up!
    509C48FF-188C-4545-ABCA-EFD29A6DD2F2.jpg 9F68D072-2A91-47A6-B0D3-812340F5AF5A.jpg A0A7D7B6-7D18-4BC2-8327-585E7B2E6A5C.jpg 1A2B3478-E0DA-4A70-96B4-35E594A1ECB5.jpg 232C3135-1ADB-4EED-9910-1B77A174CE3D.jpg
  13. Apr 22, 2020 at 6:49 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    is that an m or e series switch? are you just using it for your house battery? thinking about putting one on my main since getting to the cables is a major PITA with the way the dual batteries are installed.
  14. Apr 22, 2020 at 7:55 PM
    Wallygator
    Awesome build! Subscribed.
    Mountun Goat likes this.
  15. Apr 23, 2020 at 1:17 PM
    crolison
    It is an M-series switch, i am using it for the truck battery to the solar panels / camper.
    smslavin[QUOTED] likes this.
  16. Apr 24, 2020 at 8:27 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Killer build so far! We have very similar sliders, I built 2x6 as well! I love doing things myself, and you look similar :) I’m excited to keep watching :popcorn::headbang:
  17. Apr 24, 2020 at 8:41 AM
    crolison
    Thanks! But I like the weight difference, like doing projects, and it’s new. Fwc weigh more than you’d think and realistically are at or above the payload of our trucks.
    The OVRLND is Close to same weight as a stock project m and cheaper with options.
    4-500lbs lighter than a shell model and $3k+ cheaper with options and build out, 7-800lbs lighter than a hawk and $10k+ cheaper
  18. Apr 24, 2020 at 4:22 PM
    Wallygator
    Yeah not even close to the price of a FWC when this is done.
  19. Apr 24, 2020 at 6:18 PM
    #49
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Great build! Just curious where you will be mounting your 2nd battery? I finished up my own DIY 2nd battery few months ago using Blue Sea ACR and PC1200 battery. Worked flawlessly with my Death Valley and Mojave trips this year. Thinking of also doing a solar mat at some point and having it sit on my tent.
    Wallygator likes this.
  20. Apr 25, 2020 at 12:28 PM
    #50
    crolison
    I am just using one group 31 battery for the truck and camper. I have the solar running which usually charges up the battery by lunch from using the heater and fridge all night. I am usually driving around and dont usually camp in one spot more than 2 nights. I also have a noco jump pack as backup.
  21. May 21, 2020 at 7:22 AM
    #51
    crolison
    been meaning to update the post, so here we go.
    Finished up the interior upper sides to cover up the insulation. I went with two rows of 4" self adhesive velcro. Super happy with how it turned out and the amount of storage i have now. For securing cargo i got a bunch of the perfect bungees. I used one of their bungee nets on the door to hold down light stuff like jackets, etc, actually on the drivers side door.
    I also picked up a trasharoo.
    IMG_1637.jpg IMG_1638.jpg IMG_1687.jpg IMG_1688.jpg IMG_1734.jpg IMG_1735.jpg IMG_1736.jpg IMG_2053.jpg
  22. May 21, 2020 at 7:25 AM
    #52
    crolison
    Last weekend we took our first family trip out in the camper and it turned out awesome. Original idea to sell my tacoma build was to fit a pack n play in side the truck which we have accomplished. With this camping trip we had a hand full of ideas and small things to change before our next trip out.
    IMG_2131.jpg IMG_2150.jpg IMG_2152.jpg IMG_2157.jpg IMG_2200.jpg IMG_2199.jpg
  23. May 21, 2020 at 7:27 AM
    #53
    crolison
    Starting on some more storage this week for cups and such. Also swapped out the wheels on the truck for some stock spare steelies. The OVRLND camper with its straight walls still allows to carry 4 tires/wheels and a bike to the shop to get them swapped out.
  24. May 21, 2020 at 7:35 AM
    #54
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    nice. where'd you guys wind up? looks like a great spot.
  25. May 21, 2020 at 9:05 AM
    #55
    crolison
    Ended up down by Buena Vista
    Wallygator and smslavin[QUOTED] like this.
  26. May 21, 2020 at 9:53 AM
    #56
    Redcon41318
    How does the truck handle the camper payload?
    I applaud you for taking a little one out camping!
  27. May 21, 2020 at 12:30 PM
    #57
    crolison
    Handles it quite well. Even at altitude it handles the weight better and with more power than my old 2nd gen Tacoma stock. Mpg is worse than the taco but not much and I bet in the open road long highway stints probably the same
    Kiddnapped Tundra and Wallygator like this.
  28. May 21, 2020 at 4:47 PM
    #58
    Wallygator
    Just an awesome setup!
  29. Jun 7, 2020 at 6:21 AM
    #59
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    This thing is awesome.
    Hello from highlands ranch, co.
  30. Jun 11, 2020 at 4:51 PM
    #60
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    The new tundra looks great man :thumbsup: I followed your tacoma build on TW also and it was set up really well.
