Crimping Amp 4 AWG cable lugs [SOLVED]
Discussion in 'Audio & Video' started by BrakeDust, Apr 12, 2021.
  1. Apr 12, 2021 at 7:09 AM
    BrakeDust
    BrakeDust [OP] New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    So my amp came with a great power cable kit from tech12volts, Sosche brand. Also came with little cable lugs for the ends.
    Turn out those are rather soft, can't just smack them with a hammer, I tried that. They don't stay tight. Trying to melt some solder in there didn't turn out well either - my puny little soldering iron wouldn't even get it started and using a MAPP gas torch to head the lug/cable didn't seem to work either. The solder did melt but only formed a puddle at the end of the cable rather than wicking into the wire. :(
    Going to cave in and get the real tool, a HF hydraulic crimper: Hopefully I can still salvage the lugs, will try to open them again with a punch.
  2. Apr 12, 2021 at 7:22 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Look at the package for the wire, is it OFC (oxygen free copper) or CCA (copper clad aluminum)?
    I really like soldering them, you should not have a problem with getting filling up the lug with solder. Watch a couple youtube videos on it. A soldering iron wont cut it, i fluxed the inside of the lug, used a propane torch to slowly heat the lug until solder would flow in, and kept going until it was damn near full.
    Wynnded likes this.
  3. Apr 12, 2021 at 7:26 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    NewImprovedRon likes this.
  4. Apr 12, 2021 at 7:46 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The terminals that came with my kit had a split in the top. I used channel locks to push one side under the other, crimped side to side, then top to bottom, then repeated. Seemed to do the trick for me, but I’m sure it could have been done better.
  5. Apr 12, 2021 at 9:03 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  6. Apr 12, 2021 at 9:06 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I have a hammer crimper too... but I sure would love the convenience of crimping at the truck with a hydraulic assist vs at the bench!
  7. Apr 12, 2021 at 9:09 AM
    BrakeDust
    Hill Country, TX
  8. Apr 12, 2021 at 9:13 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Get the HF crimper, it works really well. Beats trying to smack the terminal or the crimper above with a hammer, especially when it’s on the vehicle. I’ve tried all of the above and it’s an exercise in futility. The hydraulic crimper is so nice to use after all that frustration.
    NewImprovedRon and 1lowlife like this.
  9. Apr 12, 2021 at 9:40 AM
    BrakeDust
    Hill Country, TX
    So the "4 AWG" die that came with the tool looks minuscule compared to the supplied lug. What am I missing?
    The Lug is also the split kind, can't see this ending well. Will just end up with a flat, squished cable end with little bumps in the middle.
  10. Apr 12, 2021 at 9:40 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    That's a good point.
    I've never had to use it on wires in the vehicle.
    Just on new installations.
  11. Apr 12, 2021 at 11:36 AM
    BrakeDust
    Hill Country, TX
    It ended up working very well. I started with the 0 AWG dies, then 2 AWG, finished with 4 AWG. I had fluxed per earlier recommendation. Finally heated up the end with MAPP gas and ran some solder in there. Should be on there for life!
  12. Apr 12, 2021 at 11:41 AM
    ZenkiS14
    ZenkiS14 New Member
    2012 Tundra TRD Rock Warrior
    +1 for the Temco hammer smash one. Flawless for me.
  13. Apr 12, 2021 at 11:58 AM
    War Machine
    War Machine SSEM # 5 3MW
  14. Apr 12, 2021 at 12:08 PM
    Danimal86
    Daniel
    Sacramento, CA
    So you crimped and soldered?
  15. Apr 12, 2021 at 1:59 PM
    Charvonia Design
    Keith
    Huntersville, NC
    Yeah it works fine on the bench but imagine me trying to figure out a safe way to use it on a car lol
    1lowlife[QUOTED] likes this.
  16. Apr 12, 2021 at 3:28 PM
    BrakeDust
    Hill Country, TX
    Yes indeed. My "vice grip crimp" wasn't very strong, after I used the hydraulic crimper it's rock solid. Added a little solder for good measure.
    Black Wolf likes this.
  17. Apr 12, 2021 at 3:44 PM
    Yep, hydraulic crimpers are the way to go. We calibrate thousands of them at work every year. Widely used and depending on use require periodic calibration.
  18. Apr 12, 2021 at 3:48 PM
  19. Apr 12, 2021 at 4:31 PM
    War Machine
    Especially since I borrowed them from work!
  20. Apr 13, 2021 at 2:59 PM
    ZenkiS14
    ZenkiS14 New Member
  21. Apr 13, 2021 at 3:28 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    A crimp is only as good as the tool and material can provide. The better the tool, the better the crimp. I have used this amphenol/king tool for just about everything for almost 20 years... Never a bad crimp.
    https://www.mouser.com/Search/Refine?Keyword=227-944
    Yes I have many dies and yes they all cost hundreds of dollars each. But you don't need a new tool everytime the connector type changes, you just buy the die and you're good to go.
