CrewMax Overlander
Discussion in '2.5 Gen Builds (2014-2021)' started by smslavin, Jul 21, 2017.
  1. Oct 31, 2017 at 5:31 AM
    #181
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Pull off the shift knob then pop off the center console. Start at the back then pull up and away from the dash. The black piece with the lighters comes out as a single piece. You need to pull towards you. Try wedging a trim tool along the bottom edge. It's going to take some effort. When you're done, pop everything back into place, drop in the center console, put the knob back on. Easy peasy.
    TheBeast[QUOTED] likes this.
  2. Nov 5, 2017 at 2:10 PM
    #182
    smslavin
    Hudson Valley
    Some stuff
    Just a few photos of Expedition One’s dual swing out bumper. Yes, Piper left her mark.
    6CEBCAA9-8872-4822-8EDD-5EBA246156A4.jpg 9835F18B-6A92-474C-99A0-1CD5AD9D62EB.jpg 91F2DAE7-5328-4E8C-A372-C2613566E493.jpg AC246E51-E12C-4A89-8F24-AA9B47CDBBF9.jpg D6152651-3BB0-4382-8AEA-8606D8A13AD0.jpg
    Need to give them a call and go through a few things. Clearance on the driver side swing out is super tight. A paper towel will slide between so it isn’t touching but, that’s a little close for comfort. Passenger side is fine. Pivot points and latches are really quite strong. I need to pick up some lug nuts for the spare and there’s a 4 can Rotopax mount on the way. I also need to wire up the Baja Design Squadrons but I’ve got a little noodling to do first.
  3. Nov 5, 2017 at 2:12 PM
    #183
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    That thing is so nice I would probably even take it on a date before i pushed in for the kill
  4. Nov 5, 2017 at 2:28 PM
    #184
    Sunnier
    Sunny
    San Diego, CA
    Dude, you never miss one. I'm totally bewildered about how anyone thought I could be you. I'm so. careful.
  5. Nov 6, 2017 at 5:21 PM
    #185
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    I'd let it date my sister.
    @smslavin That bumper looks even better than I imagined it would. I'll be adding this to my ever growing list of things you buy that I want haha. Is the close clearance enough to possibly cause the swing out to hit the tailgate when loaded?
  6. Nov 6, 2017 at 6:38 PM
    #186
    smslavin
    Hudson Valley
    Some stuff
    Not sure. It's too close for my comfort. I'd like to see at least 1/4" gap. I spoke to them on the phone today about a few things. I need to pull it back apart and take another look at their frame mounting brackets. I have a couple of ideas to fix it.
    TRD15559 likes this.
  7. Nov 6, 2017 at 7:35 PM
    #187
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    That is a one good looking swing out Sean. But I’d definitely be worried about it hitting the tailgate with a little flex offroad. Hope you get it sorted out. Can’t wait to see the tire on there.
    smslavin[OP] likes this.
  8. Nov 7, 2017 at 7:16 PM
    #188
    Help New Member
    Ryan
    Tucson, AZ
    Could the fix be something as simple as a felt (or similar material) liner on the possible contact points?
  9. Nov 8, 2017 at 6:02 AM
    #189
    smslavin
    Hudson Valley
    Some stuff
    could be but then i'd have to worry about the potential rubbing. it really just needs more room. the guys at expedition one are bending over backwards to help me get it figured out. they're awesome and i have no complaints.
  10. Nov 8, 2017 at 6:17 AM
    #190
    Eclipsed & Floating
    Voluptuous Whitey
    ^^THIS is what sets a company above the rest of the field. I try to deal with orgs like this in everything I do
  11. Nov 8, 2017 at 7:05 AM
    #191
    Great minds think alike.
  12. Nov 8, 2017 at 7:29 AM
    #192
    ncmtnman
    ncmtnman New Member
    Robert
    2016 Tundra Limited....and then some
    Level kit, Pro mods, shell, lights, and then some
    Expedition One is a great team to work with!! I've been talking to them regarding this same bumper for a while as a replacement for my more "standard Expedition One" one. Good to finally see it on a truck and man...that looks smacking awesome!!!
  13. Nov 9, 2017 at 10:00 AM
    #193
    smslavin
    Hudson Valley
    Some stuff
    So I had a little bit of time in between conference calls today. Took another look at the rear bumper. Opened the swing outs, loosened a couple of bolts then hung myself on each swing out like the little monkey I am. Bumper moved itself out and down. Tightened up a bolt on either side, closed the swing outs, and... viola! I now have about 1/2" clearance all the way around between each swing out and the tail gate. Tightened everything up and we are all good. Mucho happier now.
    Saturday's projects include:
    - Mounting and wiring rear BD Squadrons
    - Mounting and wiring front BD Squadrons
    - Pull broken BD S8 out of hood and replace with the new one sitting on my office floor
    - Install winch line and Factor55 FlatLink
    Then, it's back on the road for 2 weeks...
  14. Nov 9, 2017 at 11:10 AM
    #194
    TheBeast The Beach
    sweet !
  15. Nov 11, 2017 at 3:18 PM
    #195
    smslavin
    Hudson Valley
    Some stuff
    And... lights on
    So, those are bright. Shouldn’t have any problem seeing where I’m going in reverse. Tailgater deterrent? Possibly.
  16. Nov 12, 2017 at 2:14 PM
    #196
    smslavin
    Hudson Valley
    Some stuff
    Front BD Squarons wired up and winch line installed.
    Starting button up all the little things. Need to find a different plate holder. This one doesn’t quite fit with the Factor55 link.
    Gave her a bath too along with wifey’s car. I’ve spent the whole day outside and this is the first I’ve picked up the phone. Wish every day could be that way.
    Time to pack for this week’s day job travels...
  17. Nov 12, 2017 at 6:19 PM
    #197
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
    Damn nice dude
  18. Nov 12, 2017 at 6:27 PM
    #198
    smslavin
    Hudson Valley
    Some stuff
    :hattip:
    stefan702[QUOTED] likes this.
  19. Nov 12, 2017 at 6:53 PM
    #199
    TheBeast The Beach
    looking good ! who needs a license plate anyways ;)
  20. Nov 13, 2017 at 6:44 PM
    #200
    Eclipsed & Floating
    Voluptuous Whitey
    Did you pull your headlights apart and paint the chrome portions?
    Also, how you you have the beaded look on your LED strips?
  21. Nov 13, 2017 at 6:51 PM
    #201
    Eclipsed & Floating
    Voluptuous Whitey
    When I ask you questions you better respond, Mister!!!
  22. Nov 13, 2017 at 6:54 PM
    #202
    He’s texting me right now and said he’ll get to you by 2000never
  23. Nov 13, 2017 at 7:01 PM
    #203
    smslavin
    Hudson Valley
    Some stuff
    Hell no. They’re Recons. I bought them that way. The only thing I upgraded was putting in the 55w HID kit from Toytec.
  24. Nov 13, 2017 at 8:15 PM
    #204
    Eclipsed & Floating
    Voluptuous Whitey
    Well, you don't have to be rude.
    A simple, "they're Recons, dickbag. I wouldn't F with them" would suffice.
  25. Nov 14, 2017 at 5:22 AM
    #205
    smslavin
    Hudson Valley
    Some stuff
    Well, hold onto your britches. The next month is going to turn me into a total raving asshole.
  26. Nov 14, 2017 at 5:58 AM
    #206
    Hey, more gates may be coming to DIA
  27. Nov 14, 2017 at 6:34 AM
    #207
    smslavin
    Hudson Valley
    Some stuff
    And... that’s a good thing?
  28. Nov 14, 2017 at 6:46 AM
    #208
    Hell yes. Less crowded gates.
  29. Nov 18, 2017 at 1:42 PM
    #209
    smslavin
    Hudson Valley
    Some stuff
    So... these arrived while I was gone this past week...
    Not sure when I’ll be able to pull together the rest of it but I’m not in too much of hurry.
  30. Dec 3, 2017 at 5:06 PM
    #210
    seahaul
    seahaul New Member
    Any thoughts on mudflaps?
