CrewMax Overlander
Discussion in '2.5 Gen Builds (2014-2021)' started by smslavin, Jul 21, 2017.
  1. Mar 29, 2020 at 1:02 PM
    #721
    TheBeast The Beach
    covid projects, that's what I'm talking about..haha
    smslavin[OP] and jewsNbrews like this.
  2. Mar 29, 2020 at 1:11 PM
    #722
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    :cheers:
  3. Apr 4, 2020 at 11:04 AM
    #723
    smslavin
    Hudson Valley
    Some stuff
    all right. let’s drill some holes and pull some wire.
  4. Apr 4, 2020 at 1:02 PM
    #724
    smslavin
    Hudson Valley
    Some stuff
    panels on. mounts are on the bottom of the crossbars. allows the panels to set below by just a bit so the rack is still usable.
    cables will run along the rack then down through the roof of the shell. solar battery, mppt dc-dc controller and inverter are all in the bed.
    this might take a few days...
  5. Apr 6, 2020 at 5:15 PM
    #725
    smslavin
    Hudson Valley
    Some stuff
    my original plan had been to just use fuses in the solar hookup but i changed my mind today and went with blue sea circuit breakers. 80A breaker from MPPT to secondary battery under the hood. a 70A from MPPT to LiFePo battery then a 100A from MPPT to fuse block and inverter.
    anyone know if there's a good spot for a chassis ground under the bed? if not, i need to buy some more 4AWG wire to run the negative from the MPPT DC-DC charger to the secondary battery.
    final hook up of everything is probably going to have to wait until i can get some MDF. not really in the mood to brave home depot right now...
  6. Apr 11, 2020 at 3:48 PM
    #726
    smslavin
    Hudson Valley
    Some stuff
    panel cables are now through the roof. makes me feel better with the snow coming later this evening.
    the panels are connected in parallel as the max input voltage for the DC-DC MPPT unit is 25v. according to renogy, two 100w panels in parallel should have a 17.6v operating voltage.
    i really can't wait to have this all connected.
    Sunnier, drobb, TheBeast and 6 others like this.
  7. Apr 11, 2020 at 5:37 PM
    #727
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    Dang man that’s clean.
  8. Apr 11, 2020 at 6:57 PM
    #728
    smslavin
    Hudson Valley
    Some stuff
    :hattip: :cheers:
  9. Apr 12, 2020 at 2:58 PM
    #729
    smslavin
    Hudson Valley
    Some stuff
    so, it’s kinda snowing. 70 and sunny yesterday but i’m stuck inside anyway. figured i’d use the time to map out the rest of the solar install. looks like i’m going to need some longer inverter cable though. the two foot cables that came with it aren’t quite going to reach.
    i need to price out the cable (1/0 from ce auto electric) but it may need to wait. all other parts i already have and it’s no biggie if the inverter isn’t connected right away.
    colorado is on stay-at-home until 4/26 so i won’t be making a run for MDF until after that. once i get the MDF, i can get it all into the truck.
    Sunnier, Wallygator, TheBeast and 5 others like this.
  10. Apr 18, 2020 at 10:21 AM
    #730
    SSM_16
    SSM_16 New Member
    2014 TSS CM
    Stock
    Fun project! Looking forward to see how it comes out
    smslavin[OP] likes this.
  11. Apr 25, 2020 at 5:22 PM
    #731
    smslavin
    Hudson Valley
    Some stuff
    started the solar wiring today. forgot how long it takes to sleeve 40' of cable so i didn't get much done. we'll see how far i get tomorrow.
    well, this is messy. i'll be tidying that up a bit.
    these are no longer needed since the fridge and switch panel will run off the solar system now.
    i did get the new 4awg cable run from the batteries under the hood to where they will connect with the dc-dc mppt. that was really the biggest PITA. everything else is connected in the bed. it'll be nice to have this done.
  12. Apr 25, 2020 at 5:32 PM
    #732
    SSM_16
    SSM_16 New Member
    2014 TSS CM
    Stock
    You’re making me think if I need to change my wires... I got 6AWG for my dual batteries to run back to the bed. Should I change to 4 or 2?
  13. Apr 25, 2020 at 7:07 PM
    #733
    smslavin
    Hudson Valley
    Some stuff
    are they powering something or connecting to a mppt controller?
    the renogy manual for the dc-dc mppt recommends 4awg for runs of 16-30 feet and 6awg for 3-16. the way i have the cable routed, it's right about 28 feet.
    this guy has a ton of great info. he also recommends 4awg for mppt to starter battery.
    https://www.mobile-solarpower.com/
    Damie Street likes this.
  14. Apr 25, 2020 at 9:06 PM
    #734
    TheBeast The Beach
    nice connectors though :)
  15. Apr 26, 2020 at 7:36 AM
    #735
    SSM_16
    SSM_16 New Member
    2014 TSS CM
    Stock
    Yes. They’ll be used to send power to my power box through an Anderson plug. I’ll have the inverter, fuse box and some outlets for charging electronics and possibly a coffee pot lol. I won’t be using the box all the time so that’s why I want it removable.
    But they’ll come straight from the auxiliary battery back there.
  16. Apr 26, 2020 at 8:12 AM
    #736
    smslavin
    Hudson Valley
    Some stuff
    excluding the inverter, do you know how many amps you'll be pulling? how big is the inverter and what is its draw? this is a handy chart to keep around.
    ColoradoGuy, Sunnier and Wallygator like this.
  17. Apr 26, 2020 at 9:40 AM
    #737
    Wallygator
    Can't wait to see how you ran the wires and hooked it all up.
  18. Apr 26, 2020 at 11:06 AM
    #738
    smslavin
    Hudson Valley
    Some stuff
    just asked my lovely wife what she wanted to do today since, well, there are so many options right now. her response?
    'get outside and fix your f'ing truck.'
    i love her.
    Sunnier, zcarpenter92, Bailey and 6 others like this.
  19. Apr 26, 2020 at 11:22 AM
    #739
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Great info. Thanks for sharing. I want a solar setup but first have to get a topper for the truck.
    smslavin[QUOTED][OP] likes this.
  20. Apr 26, 2020 at 2:24 PM
    #740
    smslavin
    Hudson Valley
    Some stuff
    test fit looks good so far.
    1100289B-3C89-4EA4-A1D6-4EBCE8EC25C4.jpg already have the baltic birch cut to fit. going to start placing everything and measuring wires. i’ll get it all wired up and running then take it all off and paint with some primer and bed liner.
    just need to figure out a tie down for the battery.
    SSM_16 and Wallygator like this.
  21. Apr 26, 2020 at 2:39 PM
    #741
    Wallygator
    Maybe use a battery box and strap it down to the board?
  22. Apr 26, 2020 at 3:06 PM
    #742
    SSM_16
    SSM_16 New Member
    2014 TSS CM
    Stock
    Well I’ll need to change the wire gauge since the run is gonna be more than 5 feet long. The inverter is gonna be 750W which is more than enough for what I want. Thanks for the chart bro.
  23. Apr 26, 2020 at 3:41 PM
    #743
    smslavin
    Hudson Valley
    Some stuff
    i have a box. just not sure if i want to use it. i kind of like the idea of laying the battery down rather than having it stand upright. keeps it below the window line. need to futz around with it a bit more.
    SSM_16 and Wallygator[QUOTED] like this.
  24. Apr 26, 2020 at 6:28 PM
    #744
    fundra_goes_west
    Evan
    2022 SQ8
    The 95DZ is serious! Looks good!
  25. Apr 26, 2020 at 6:42 PM
    #745
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Blue Sea has a great web site for this info too ;)
    http://circuitwizard.bluesea.com/
    SSM_16[QUOTED] and smslavin[OP] like this.
  26. Apr 26, 2020 at 6:53 PM
    #746
    TheBeast The Beach
    gone are the days of a ground tent and a coleman oil lamp..lol..this is serious overlanding here.
    smslavin[OP] and JLS in WA like this.
  27. Apr 26, 2020 at 9:40 PM
    #747
    smslavin
    Hudson Valley
    Some stuff
    camping is secondary. it’s more for powering the studio in the back country. there are a lot of things that i’ll be able to do that most photo/video guys won’t. making myself a niche. just hoping i can get it to payoff.
  28. Apr 26, 2020 at 10:00 PM
    #748
    TheBeast The Beach
    "ice cold beer anyone ?" ;)
    Sunnier and smslavin[QUOTED][OP] like this.
  29. Apr 27, 2020 at 2:40 PM
    #749
    smslavin
    Hudson Valley
    Some stuff
    first section of the power panel.
    blank spot below the fuse block will have the battery monitor. the blanks next to the power outlets will have switches. one switch for the outlets. one for bed lights. one for camp lights on the rack. switch on the bottom right is the remote on/off for the inverter.
  30. Apr 27, 2020 at 2:42 PM
    #750
    Damie Street
    Edsel
    South Carolina
    Where are you going to mount this?
