CrewMax Overlander
Discussion in '2.5 Gen Builds (2014-2021)' started by smslavin, Jul 21, 2017.
  1. Apr 25, 2019 at 12:55 PM
    #631
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    The post from @sdhq_offroad has me intrigued, but otherwise I may take you up on that.
    Erichudgins and smslavin[OP] like this.
  2. Apr 26, 2019 at 6:24 PM
    #632
    thetwood
    thetwood New Member
    Louisville, CO
    2017 Blazing Blue Limited CrewMax TRD
    Kings, SPC, Icon Six Speed, Falken Wildpeak AT3w
    I read that you're using a Cascadia 4x4 Flipster license plate holder on your Expedition One bumper. I'm looking to do the same and was just starting to look at all the pieces showing up. I'm trying to figure out how to fit the Flipster with the recessed winch opening. Any advice on how you mounted everything? Did you use the V2?
  3. Apr 27, 2019 at 6:25 PM
    #633
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    bumper then flipster then fairlead. yes, it's the v2. let me know if you need a picture of anything.
    see what? :cool:
  4. Apr 28, 2019 at 5:04 PM
    #634
    thetwood
    thetwood New Member
    Louisville, CO
    smslavin[QUOTED][OP] likes this.
  5. Apr 29, 2019 at 10:36 AM
    #635
    smslavin
    Hudson Valley
    Some stuff
    yes, mine is mounted 'upside down'. it flips down. i should have mentioned that earlier. it does not interfere with the winch line in any way. i'll grab a pic in a few.
    thetwood[QUOTED] likes this.
  6. Apr 29, 2019 at 11:09 AM
    #636
    smslavin
    Hudson Valley
    Some stuff
    okey dokey. secondary bypasses are back on.
    i ordered some new mount (shock and resi) tabs from the kind folks at @TOTAL CHAOS. last friday, @ColoradoTJ helped weld them on. since the camburg kinetik arms so much larger than tubular arms, there were some clearance issues with the original mounts. i cut those off and we welded the new ones on about 5/8" further back than TC's original location. i also cut a little bit more out of the fender well for just a little extra breathing room.
    once the upper mounts were in, i now have about 1/2" clearance between shock body and arm on the driver side and about 5/16" on the passenger side. more about that in a bit but it's a whole lot more than what i had originally.
    chris and i debated almost ad nauseum about where to put the bypass resis. my plans are solid mid-travel. long travel is not on my radar. i can hear you snickering and trying to contain the i-told-you-so remarks but, it's true. most likely. probably. i swear. anyway, that creates some clearance issues.
    my wheels are +25 with 35x12.5 tires and there is an aggressive body mount chop. we tried multiple positions and finally settled on putting the resi mounts on the forward facing side of the hoop. we were pretty confident in the clearance but no, tires rubbed at full lock. no biggie. made it home and decided to look at it later.
    i spent saturday morning futzing around with the resis. there are now mounted on the opposite of the hoop, down low and pushed in as far as possible. everything clears.
    back to the clearance issue. i'm still scratching my head a little on that one and there's only a couple of things i can think of. one is that after welding in the shock hoops, the angle is slightly different between driver and passenger sides. the other is the heims on the driver and passenger side have a slightly different caster angle. the last one is a combination of the first two. i haven't gotten in there to count threads on the heim bolts yet but might. i think i'm also going to run for an alignment since the truck is due for that anyway.
    i have not yet done any tuning to the bypasses, front or rear, nor have i changed anything on the coil overs. the front end is only slightly stiffer and handles amazingly well. i do have new valve stacks for the coil overs and will be taking care of those in the next couple of weeks. i've got a couple of roads picked for tuning runs but the weather needs to clear up a bit before i can get up there. hoping that will be soon. in the meantime, i'm aiming for every pothole and jumping every curb...
    zcarpenter92 and d0zer like this.
  7. Apr 29, 2019 at 12:23 PM
    #637
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
  8. Apr 29, 2019 at 1:00 PM
    #638
    smslavin
    Hudson Valley
    Some stuff
    what did you do with the washer fluid?
    TheBeast likes this.
  9. Apr 29, 2019 at 1:20 PM
    #639
    sdhq_offroad
    GILBERT, AZ
    Currently working on that. We will be relocating/replacing it.
    jc153, T-Rex266 and smslavin[OP] like this.
  10. Apr 29, 2019 at 3:58 PM
    #640
    smslavin
    Hudson Valley
    Some stuff
    looking forward to seeing the rest of it. seems to be an easy spot for mounting the secondary. unfortunately, it won't work for me since my compressor is mounted in that location.
  11. May 22, 2019 at 9:21 PM
    #641
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    Sweet build! I Will be in Denver in a few weeks, hope to see you around!
  12. Jul 18, 2019 at 3:57 PM
    #642
    dak13
    dak13 Butt Stuff
    2015 Tundra SR5
    Crazy journey. Solid build. Have you gotten around to regearing yet? Bad boy looks heavy.
    zcarpenter92 likes this.
  13. Aug 6, 2019 at 12:13 AM
    #643
    Tundrabigbang
    Tundrabigbang New Member
    2019 tundra sr5 double cabbin
    Where did you order your taillights bro?
  14. Aug 6, 2019 at 1:14 AM
    #644
    19greysport
    19greysport New Member
    2019 crewmax sport
  15. Aug 27, 2019 at 2:24 PM
    #645
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Sean, you still here??? This build thread needs updating!
  16. Aug 28, 2019 at 5:35 AM
    #646
    coTony
    Tony
    Montrose, CO
    This is interesting but I am in the process of adding my onboard air and my Up/Down Air system and everything is right there where you guys put the battery. Bummer.
    What was the other thing revealed at T2S that I missed? I was there and did not hear of anything being announced... but was busy with the dogs
  17. Oct 22, 2019 at 4:02 PM
    #647
    TheBeast The Beach
    miss this guy. Hope all is well brother.
  18. Oct 22, 2019 at 4:20 PM
    #648
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    Yep me to. Never met the man, bit seems like a very solid guy. I hpe all is well with and his family.
    Thanks for posting that @TheBeast
    Pinay likes this.
  19. Oct 22, 2019 at 4:35 PM
    #649
    He’s a good dude. Miss him too. I’ll shoot him a text
  20. Oct 22, 2019 at 5:21 PM
    #650
    Broncobroke
    Charlie
    Piedmont, NC
    Thanks you sir. Been worried about him
    Seemed to have alot of tough stuff going on. I had been meaning to pm you or @Coloradatj and see if he was ok
  21. Oct 22, 2019 at 5:29 PM
    #651
    He’s still alive. He’ll text me back in a bit.
    Broncobroke likes this.
  22. Oct 22, 2019 at 6:22 PM
    #652
    smslavin
    Hudson Valley
    Some stuff
    i'm still breathing. crazy town is only somewhat of a valid description of how things have been. appreciate the concern. i'll try to crawl out from under my rock and check in more often.
    quite a few updates on the truck...
  23. Oct 23, 2019 at 1:17 PM
    #653
    smslavin
    Hudson Valley
    Some stuff
    can't remember where i left things but i don't think i've put in any details on the dual battery setup. i'm going to preface this by saying it was not easy. it was probably the most difficult and time consuming project next to the big 4 wire upgrade.
    anyway, i used the xfaktr unicorn dual battery tray. well, maybe it's not an unicorn anymore but it works and it's well machined. space is tight. like really really tight. so it starts...
    yes, those are 2 odyssey pc1500 batteries. here's the bottom of the tray.
    the batteries stand vertical with the posts facing the fuse box. the bottom and top of the tray match the contours of the batteries. once the batteries are in, you really can't get in there to do anything.
    since everything is so tight, there were fitment issues. regular terminals don't fit which bummed me out because i really liked the machined ones from @sdhq_offroad that i have. hunting around a bit, i came across these machined flat terminals. however, the lip on the back of the top tray was touching the terminal. no bueno. angle grinder to the rescue.
    after that it was just a matter of mounting, wiring and trying not to zap myself since everything had to get connected on the way in. i failed on the last point and there's a nice scorch mark on the ratchet as a reminder.
    once that was done, it was time to put in the switch and a volt meter. since i no longer have stock headlights, there was really no need for the level switch. out it came.
    a wee bit of trimming with the dremel and the switch went in perfectly.
    now, time for the volt meter.
    the dual battery kit came from off grid engineering. all the necessary pieces and they are great guys to deal with. made the whole thing almost painless.
    i also finished the panel in the bed of the truck. on current pictures though. on the panel, is a renogy solar controller and a blue sea switch panel with a usb socket, a 12v socket and another volt meter. blue sea stuff came from the guys at off grid as well. the blue sea panel, and the fridge, are wired to the fuse block attached to the secondary battery. running the cable for those two things to the front of the truck was a process.
    i have 2 100w solar panels that i never got to mounting over the summer. i've been working on my welding and my current thought is to build a mounting tray for two batteries. i have room behind the fridge and will bolt that to the deck just like the fridge. panels will go on the rack and i'll have a short wiring run, less than 6', to get from the solar controller to the batteries. wiring for fridge and blue sea panel will then go to the solar battery bank leaving the second battery up front for jump start duties only.
    main reason i'm waiting on all that is because i want to go fiberglass fenders all the way around...
    i can't report too much on the suspension setup is running. i was only able to put the truck into the dirt twice this summer. when it was in the dirt though, no sway bar up front and secondary bypasses are pretty kick ass. :cool: :burnrubber:
  24. Oct 25, 2019 at 2:09 PM
    #654
    smslavin
    Hudson Valley
    Some stuff
    one of 2 trips where the truck actually saw dirt this summer...
  25. Oct 25, 2019 at 4:32 PM
    #655
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    That's sweet!! Thank you for sharing.
  26. Oct 31, 2019 at 11:10 AM
    #656
    smslavin
    Hudson Valley
    Some stuff
    re-gear has not happened yet. i had pennies saved and then they blew away. saving again. debating 5.29s and 37s...
    zcarpenter92 and Trdwillie14 like this.
  27. Nov 11, 2019 at 5:45 PM
    #657
    SSM_16
    SSM_16 New Member
    2014 TSS CM
    Stock
    Any updates? :popcorn:
  28. Nov 12, 2019 at 7:19 AM
    #658
    smslavin
    Hudson Valley
    Some stuff
    sorry to disappoint but, no. still in a bit of a rough patch these days so, the truck sits. it's been driven maybe 200 miles in the past few months. there are a number of things that need to be fixed. alignment, bypass hoses need shortened on the secondaries and the switchpro needs replacement.
  29. Nov 14, 2019 at 8:16 PM
    #659
    ramb74
    ramb74 New Member
    Ricardo
    2018 Toyota Tundra SR5 Crewcab TRD sport
    Amazing build thread!! Thank you!
    smslavin[OP] likes this.
  30. Nov 16, 2019 at 1:25 PM
    #660
    smslavin
    Hudson Valley
    Some stuff
    not truck related but... new promo materials for the studio are finally here.
    went for letterpress business cards this time around and so happy i did. this is my third portfolio book from lost luggage and i just love them.
    hnsmrob, Major, TheBeast and 3 others like this.
