CrewMax Overlander
Discussion in '2.5 Gen Builds (2014-2021)' started by smslavin, Jul 21, 2017.
  1. Apr 14, 2019 at 4:59 PM
    #601
    3mxdivr
    3mxdivr New Member
    NorCal
    2018 Limited Crewmax TRD Off Road
    app?
  2. Apr 14, 2019 at 5:04 PM
    #602
    Mgmslow/
    ColoradoTJ likes this.
  3. Apr 14, 2019 at 5:19 PM
    #603
    TheBeast The Beach
    have you thought of removing your front sway bar to get full benefit of the front suspension ?
    smslavin[OP] likes this.
  4. Apr 14, 2019 at 5:24 PM
    #604
    3mxdivr
    3mxdivr New Member
    NorCal
    Hahahahahaha!
    T-Rex266[QUOTED] likes this.
  5. Apr 14, 2019 at 7:33 PM
    #605
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    dometic app for monitoring the fridge
    yes. it’s coming off.
    dometic fridge monitor. not for batteries.
  6. Apr 16, 2019 at 9:36 AM
    #606
    smslavin
    Hudson Valley
    Some stuff
    this is what makes this whole project fun for me. it's like a big puzzle.
    when we put the secondaries on up front, as i mentioned earlier, clearance was very tight with the kinetik arms. crawling under the truck the other day, i fully realized how tight. this is the passenger side. yes, a little bit of the hose rubbed off...
    bypasses have since come off the truck. traded a few emails with total chaos and new tabs are on their way. i'll cut the original ones off and move the new ones back. TC recommended about 5/8" clearance between the bypass and the arm. tweak and re-tweak. all fun.
  7. Apr 17, 2019 at 1:14 PM
    #607
    smslavin
    Hudson Valley
    Some stuff
    mmm. now i can charge my shafts whenever i'm in the mood without having to knock on @ColoradoTJ's door...
    TheBeast, T-Rex266 and ColoradoTJ like this.
  8. Apr 17, 2019 at 1:55 PM
    #608
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Is that a euphemism?
  9. Apr 17, 2019 at 2:09 PM
    #609
    smslavin
    Hudson Valley
    Some stuff
    not sure. right now i'm too busy trying to figure out if i want to pull the puddle or push it...
  10. Apr 17, 2019 at 2:13 PM
    #610
    smslavin
    Hudson Valley
    Some stuff
    digging around trying to find easy ways of mounting things to the prinsu rack without having to pull the side rails off. came across these lovelies on that other forum for the baby trucks...
    roll in t-nuts with a spring. https://www.ebay.com/itm/263037318909
    just pop them into the cross bars and away you go. fits an M6 bolt.
  11. Apr 17, 2019 at 3:32 PM
    #611
    NWExplorer
    NWExplorer this guy
    Washington
    2010 CM Platinum 4x4
    8020.net has a bunch of options too. Nice build btw.
  12. Apr 18, 2019 at 10:09 AM
    #612
    CCarr
    CCarr New Member
    Hey man, would you mind measuring the length of the 8020 extrusions for your prinsu rack? I'm planning to order some to make my own rack but am not sure what length to get. Eventually I'll probably get the prinsu cabrack, so I want it to match the width of that.
  13. Apr 18, 2019 at 2:03 PM
    #613
    smslavin
    Hudson Valley
    Some stuff
    figuring out the ham radio install...
    need to go pick up the mic extension and some antenna cable. not sure where i’m going to put the head unit yet. maybe up under the passenger side dash or under the driver’s seat.
  14. Apr 18, 2019 at 2:04 PM
    #614
    smslavin
    Hudson Valley
    Some stuff
    crossbars are 54”
    CCarr[QUOTED] likes this.
  15. Apr 18, 2019 at 5:46 PM
    #615
    smslavin
    Hudson Valley
    Some stuff
    hey smart people. kinda looking at you @Lars.
    need some mounting suggestions. i’m thinking this is where the yaesu should go.
    passenger side footwell. puts it up and out of the way. easy access to the data port and wiring for antenna, power and faceplate.
    is there a way to get the plastic piece off that is under the glove box? if i can, then i can bolt the unit to a cross bar or a heavy duty strapping brace to take the load off the plastic. not seeing how to get it off though. maybe down through the glove box?
  16. Apr 19, 2019 at 2:02 PM
    #616
    smslavin
    Hudson Valley
    Some stuff
  17. Apr 19, 2019 at 2:25 PM
    #617
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Can't go wrong with those. I ran them on my FJ and loved them. Great value
    Edit: Did you only replace 2/4 bump stops up front or all 4?
  18. Apr 19, 2019 at 2:56 PM
    #618
    smslavin
    Hudson Valley
    Some stuff
    just the back two
    TheBeast and Bailey[QUOTED] like this.
  19. Apr 23, 2019 at 3:04 PM
    #619
    smslavin
    Hudson Valley
    Some stuff
    starting the big 4 upgrade by making some new cables. this is going to be a project. plan is to tackle this in its entirety on thursday along with the dual battery install.
    messy workbench in the photo since @T-Rex266 loves it so much...
  20. Apr 24, 2019 at 10:43 AM
    #620
    smslavin
    Hudson Valley
    Some stuff
    factory harness is out. starting to run new cable and tape everything back together. taking my time and going very slowly...
  21. Apr 24, 2019 at 10:50 AM
    #621
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    LOL... Not only do I have the same awesome bump stops, but I installed them with the same blue Channel Lock Pliers!!
    smslavin[QUOTED][OP] likes this.
  22. Apr 24, 2019 at 11:37 AM
    #622
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    Awesome build man
  23. Apr 24, 2019 at 12:36 PM
    #623
    TheBeast The Beach
    no LP9's yet ? ;)
  24. Apr 24, 2019 at 3:42 PM
    #624
    smslavin
    Hudson Valley
    Some stuff
    well... didn’t quite finish but super close. all the new 1/0 cable (pos & neg) is run, sleeved and taped up. it’s a job and took longer than i expected but i’m burnt and my knuckles say no more...
    plan for tomorrow is to at least get everything connected back to the main battery and start the truck. if there’s time, i’ll connect the secondary. need to get running so i can get back to @ColoradoTJ on friday for more welding fun.
  25. Apr 24, 2019 at 4:22 PM
    #625
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Should of waited another month or so for that dual battery kit ;)
  26. Apr 24, 2019 at 4:30 PM
    #626
    smslavin
    Hudson Valley
    Some stuff
    :( :annoyed: :smack:
    will yours fit 2 odyssey group 34 pc-1500s? biggest issue i have is the vertical mounting of the batteries and trying to find clearance for your clamps. it's tight but doable. either way, with the new 1/0 cable, i'm all set to drop in a 250a alternator at some point down the road.
    curious to see what you guys came up with for the dual batteries. :cheers:
  27. Apr 24, 2019 at 4:33 PM
    #627
    sdhq_offroad
    GILBERT, AZ
    It will. Too bad you aren't at T2S this weekend, you would be able to see it in person. Maybe I'll leak some pictures :D
    03Marine, T-Rex266 and smslavin[OP] like this.
  28. Apr 24, 2019 at 4:34 PM
    #628
    sdhq_offroad
    GILBERT, AZ
    We have 2 new products we are "debuting" at T2S
    Broncobroke and smslavin[OP] like this.
  29. Apr 24, 2019 at 5:11 PM
    #629
    smslavin
    Hudson Valley
    Some stuff
    yea, wanted to be there, had the days off and everything. curiosity piqued on the dual battery and other new goodies.
    Broncobroke and TheBeast like this.
  30. Apr 25, 2019 at 9:27 AM
    #630
    smslavin
    Hudson Valley
    Some stuff
    well, hmm. have not been able to get the xfaktr dual battery tray to fit, at least not with the sdhq battery clamps. tried with the factory clamps and there’s just not enough room with the new power cables. pretty bummed about the xfaktr tray. need to figure something out so i can get the fridge and a few other things powered up.
    @sdhq_offroad i’m even more interested in what you guys came up with. especially if it fits the odyssey PC1500s.
    @the_midwesterner still interested in the xfaktr tray? i’ll make you a deal. maybe you’ll have better luck with it.
