CrewMax Overlander
Discussion in '2.5 Gen Builds (2014-2021)' started by smslavin, Jul 21, 2017.
  1. May 28, 2018 at 9:43 PM
    #301
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    For the air, look for a system called 2 Way Air. They're out of business, but you may be able to find a kit on Amazon or something. It's what we used to make our central tire inflation. If you're interested, I can probably give you a part by part list of the core items. We have a schrader valve under each wheel well, and quick connect whips to push onto each tire. Then you cna air up and down all four at once.
    smslavin[QUOTED][OP] likes this.
  2. May 29, 2018 at 6:00 AM
    #302
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    wizard might be pushing it. court jester is probably more likely. :cool:
    do you mean this?
    http://www.northridgenation.com/rock-smasher-2way-air-installation/
    looks like a good setup. i'd love any info you'd be willing share.
    lionix likes this.
  3. May 29, 2018 at 6:43 AM
    #303
    bito
    bito New Member
    @smslavin I thought I saw where you were talking about moving the backup cam but can't find it, maybe it was another rig. Are you moving it? Or does it work with your current setup?
  4. May 29, 2018 at 6:53 AM
    #304
    smslavin
    Hudson Valley
    Some stuff
    i'm not planning on moving it. must have been someone else. the spare tire blocks about 1/3 of the view but it works fine for me.
    bito[QUOTED] likes this.
  5. May 29, 2018 at 7:29 AM
    #305
    bito
    bito New Member
    Cool, thanks! I really like that bumper.
    smslavin[OP] likes this.
  6. May 29, 2018 at 8:26 AM
    #306
    KevinK
    Tundras to Sedona
    Yessir that's the one. Looks like a pretty good write up they have on it also. Here's our write up.
    https://www.tundras.com/threads/kom...h-speed-overland-rig.16989/page-5#post-630851
    and a video that takes longer to watch than it does to actually fill 4 37s.
    https://youtu.be/IOOpyP76UOY
    We use a bottle of nitrogen on our setup, so I left off the pressure relief valve since the tires fill so fast. I had planned to use the bottle regulator to set the pressure and walk away, thinking I'd come back to properly inflated tires, but it fills so fast I just stand there for a minute.
  7. May 29, 2018 at 8:28 AM
    #307
    smslavin
    Hudson Valley
    Some stuff
    awesome. another drunk engineering video. can't wait. :cool:
    thanks for the info. :cheers:
  8. May 29, 2018 at 9:39 AM
    #308
    KevinK
    Tundras to Sedona
    Sure thing!
    I meant to also respond about the NMO antenna mount in the roof. I've done it twice already and now use a mag mount. Even with a shorty antenna it just caught on low hanging branches constantly and that one time I drove into the garage at home before taking it off - the garage took it off for me. Now we have an R2-D2 looking droid on the roof where that mount used to be (I had to cover the hole somehow). So I made a new NMO in the roof, and then bent that one too.
    If there's even a remote chance you'll touch that antenna to something, use a mag mount. Everyone I asked had said an NMO on the roof was plenty sturdy, but either I'm a dumbass, or they drive like chickenshits. Probably a bit of both.
  9. May 29, 2018 at 9:44 AM
    #309
    smslavin
    Hudson Valley
    Some stuff
    this is the ssb-1. 16.5" tall and flexible.
    https://www.hamradio.com/detail.cfm?pid=H0-001562
    the ssb-5 is 38" tall and definitely not flexible.
    https://www.hamradio.com/detail.cfm?pid=H0-001571
  10. May 29, 2018 at 11:18 AM
    #310
    KevinK
    Tundras to Sedona
    I wonder how flexible that first one is. It would be cool to see it in person.
    We run this Diamond, very similar to the ssb, but you can fold it down at the base. I got tired of stopping, and climbing up the side of the truck to flip it down all the time (and then still hitting branches).
    We now run a mag mount on the hood like a damn unicorn. Lisa has threatened to paint it in pink sparkles - I think she should.
    In this picture you can also see the smaller antenna on our roof. That's a cell phone signal booster, also on a mini mag mount, also needing to be flipped back up all the time after territorial disputes with low hanging branches.
    Oh and the big black thing in the middle of the ham antenna is heat shrink around the open coil the stop branches from snagging it (we did that as a precaution based on research I had done before the initial NMO roof install)
    blue16 and GodlessPro like this.
  11. May 29, 2018 at 11:22 AM
    #311
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    The heat shrink is an interesting idea, I might borrow that.
    smslavin[OP] and KevinK[QUOTED] like this.
  12. May 29, 2018 at 11:46 AM
    #312
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Never noticed this thread before, sick build!!!
  13. May 29, 2018 at 11:57 AM
    #313
    smslavin
    Hudson Valley
    Some stuff
    so, on my FJ i had that diamond antenna. it was mounted to the roof rack on a swivel mount. with a little bit of a stretch, ok, a big stretch, i could reach out the drivers window and rotate it down. sometimes i'd forget. nah. most times i'd forget. i broke 3 or 4 of them. one of the other FJ guys i ran around with in SD was smarter. he put his on a switch operated motorized mount. it was a sweet set up.
    i'll get you some photos of the comet when i pick it up. probably in the next week or so.
  14. May 29, 2018 at 2:32 PM
    #314
    KevinK
    Tundras to Sedona
    oooh, I like the motorized idea...
  15. Jun 8, 2018 at 7:12 AM
    #315
    smslavin
    Hudson Valley
    Some stuff
    Started collecting air system bits...
  16. Jun 8, 2018 at 8:30 AM
    #316
    You coming out tomorrow homie?
  17. Jun 8, 2018 at 8:56 AM
    #317
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    Appreciate the park tools.
  18. Jun 8, 2018 at 9:35 AM
    #318
    smslavin
    Hudson Valley
    Some stuff
    still trying. not sure what time though. might not be until towards the end. when i originally put this on the calendar, i'd forgotten that bec and roxy would be in moscow.
    :cheers:
    all park for the bikes with the exception of a few specifics from abbey, campy and pedro's.
    T-Rex266[QUOTED] likes this.
  19. Jun 8, 2018 at 12:06 PM
    #319
    d0zer
    2017 MGM Platinum
    Posted this in another thread, but I'm sure you can appreciate a little more than the average guy here.
    Enve, Saint, Fox Factory with all hsc/lsc front and back.
  20. Jun 8, 2018 at 1:03 PM
    #320
    Juddrussell
    Juddrussell New Member
    Jacob
    Bentonville, AR
    2016 MGM Tundra TRD Pro
    BAMF Bedrack, 295/70/r18 General Grabbers, Bedslide, Weathertech floor mats, and Tepui Autana Sky RTT.
    @smslavin just, holy schnikes. Well, well done. That is all.
  21. Jun 8, 2018 at 2:34 PM
    #321
    smslavin
    Hudson Valley
    Some stuff
    that is a fun whip you have. :headbang:
    yes, finally. someone else with saint and 180 rotors on a trail bike.
    hHx5qV4pXiNnQN8qs4bPYvPvNsl6FcwUA80KqBj6_a8331d5dff9423a9e655d7edf4c0f6530c698b15.jpg
    sb66-c (yes, i still run 26) with saint, king, hayes brakes, race face cranks, xfusion up front, cane creek dbair cs on the back. 1x10 setup, 30 up front with an 11-40 out back using the one up cage and sprocket. considering switching to saint brakes. the hayes have great power but servicing them blows.
    DH bike is also a yeti, the 303rdh. wish they were still making them. saint drivetrain and brakes, fox 40 up front, cane creek dbcoil on the back.
    XLJSVpltmdgVPMAyHdIJ24-rxP15mMWlJYHupt8h_7581e809590651520e433ccf7f453de87d0f5a7e.jpg
    i'll be doing lowers service on both bikes this weekend along with truing wheels and putting new rubber on the 303. trestles opens on 6/16 and keystone is already open. :bananadance:
    :hattip:
  22. Jun 26, 2018 at 4:35 PM
    #322
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Still enjoying your sliders? Reconsidering my options since their products were great to me on my FJ.
  23. Jun 27, 2018 at 5:11 AM
    #323
    smslavin
    Hudson Valley
    Some stuff
    i caress and whisper sweet nothings to them every night.
    no issues and i've always been a fan of jason. he treated me well with the fj so getting a few bits for the tundra from him was a no brainer. just so you know, the sliders will ship via freight service on a pallet. they're heavy and really really long.
    Bailey[QUOTED] likes this.
  24. Jul 8, 2018 at 3:29 PM
    #324
    TheBeast The Beach
    re-read the whole thread....just because :) any plans on adding a RTT on top of topper ? you still like the drawer system ?
  25. Jul 9, 2018 at 5:46 AM
    #325
    smslavin
    Hudson Valley
    Some stuff
    things around here moving that slow lately? :bored: :cool:
    definite no on the rtt. i've got a great ground tent and i'd rather have a trailer. one of these days, when the lottery ticket comes through, i'll get the trailer. these have recently caught my eye.
    drawers are still solid. zero issues with them. they've been holding up well and i keep a ton of crap in them.
    i still need to fix the leaf springs. been a little preoccupied lately so those are on a back burner for right now.
    TheBeast[QUOTED] and T-Rex266 like this.
  26. Jul 9, 2018 at 11:45 AM
    #326
    TheBeast The Beach
    I'm on the fence now...topper with drawer or bed rack with RTT...mmmm. I like being able to lock all the gear with the drawers and topper.
  27. Jul 9, 2018 at 11:48 AM
    #327
    smslavin
    Hudson Valley
    Some stuff
    +1
    Help likes this.
  28. Jul 9, 2018 at 12:39 PM
    #328
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    +2
    I'm planning on building a fold-able sleeping platform on top of the drawers that one day i'll eventually get around to building.
  29. Jul 23, 2018 at 2:17 PM
    #329
    smslavin
    Hudson Valley
    Some stuff
    and the roof rack hunt comes to an end. prinsu now has a cab rack for the crewmax with a matching topper rack. pulled the trigger this morning. patience can sometimes pay off.
    now, if i could only get that patience to pay off for my life in general we might be getting somewhere...
  30. Aug 24, 2018 at 1:48 PM
    #330
    smslavin
    Hudson Valley
    Some stuff
    A week late but the front and rear Prinsu rack just shipped. Should be here Tues. not sure when I’ll get mounted since I’m having hand surgery Thursday. :(
