CrewMax Backseat Storage Hack
Discussion in '2.5 Gen Tundras (2014-2021)' started by moonshineheadache, Jun 30, 2018.
  1. Sep 23, 2018 at 2:38 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    My boyfriend is my truck....he takes my money all the time:rofl:
  2. Sep 23, 2018 at 3:22 AM
    At least he gives you a good ride.:rofl::rofl::rofl:
    D3VA, Bob_Wiley, Inquiringone and 5 others like this.
  3. Sep 23, 2018 at 6:28 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    Very true!
    TheBeast likes this.
  4. Sep 23, 2018 at 6:29 AM
    :thumbsup:
    4x4_Angel[QUOTED] likes this.
  5. Sep 23, 2018 at 9:13 AM
    Mtbrider541
    Mtbrider541 New Member
    Eric
    Medford Or
    2015 Tundra CM TRD
    Front and rear bumpers, ICON stage 1, Zone UCA's, Custom made airbag mounts with firestone bags, Body mount chop, ICON progressive rear leaf pack 1 inch lift, OME greasable rear leaf shakes & bushings, 295x70x18 Toyo Open Counrty ATII, URD Maf calibrator, K&N Intake tube w/ OEM Airbox, AFE Trans Temp and AFR Guage w/ Lotek guage pod, leer 100XQ with leer locker, Mangnum RT steps, and Trail Ridge tow mirrors.
    As you can see this allows you too easily access behind the seat when its lifted, this also provides enough room to build a 3/4 .5cubic ft sub box for an enclose 10 inch sub. The sub enclosure will be 22 inch high in the rear 7 inches across the bottom 16 inches wide. (Wedge design)
    4x4_Angel likes this.
  6. Sep 24, 2018 at 5:09 PM
    Mtbrider541
    Eric
    Medford Or
    2015 Tundra CM TRD
    My adjustment brackets are built pictures below, now I just have to fit the leg bases onto the new base extensions shown below. Paint and re assemble
    040Tundra and aperezsh like this.
  7. Sep 24, 2018 at 5:15 PM
    Mtbrider541
    Eric
    Medford Or
    2015 Tundra CM TRD
    By the way the Moonshine Bandits will be in concert in Apple Valley California near Victorville on October 27th hope to see you there
    Danny likes this.
  8. Sep 26, 2018 at 9:36 AM
    Mtbrider541
    Eric
    Medford Or
    2015 Tundra CM TRD
    Hello everyone, So I hit a big hurdle last night and had to take a couple steps back to get things right. I will post the updates soon but my new plan will not involve any cutting or trimming of the OEM seat bases. It will however require some technical welding of bolt studs for the OEM brackets to mount too.
  9. Sep 26, 2018 at 9:43 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I see Amazon sells the same size food trays in black polycarb, another option. I'm planning on the big Diamondback bin for extra storage, thought about ESP but don't wanna spend $ on both, and I have those extended under-the-seat Husky mats too. Might do this hack. Great job OP!
  10. Sep 26, 2018 at 11:41 AM
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    Yeah when I did my ESP storage, that foam was no joke. I used a 4" serated hunting knife to get in there.
    But man.. $22 great job OP. Well spent twenty bucks20170816_122210.jpg 20170816_122233.jpg
  11. Sep 27, 2018 at 5:18 PM
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    To you guys and gals who have done these mods, is there more interior truck noise after you do it? I mean you are removing a sizable amount of soundproofing.
  12. Sep 27, 2018 at 5:56 PM
    Rhernandez09
    Rhernandez09 New Member
    Roy
    2018 Black Tundra TSS
  13. Sep 27, 2018 at 5:58 PM
    Rhernandez09
    Roy
    I took the carpet and insulation and put it below the trays I haven’t noticed any noise difference.
    Fiestee23, SteyrM40A1 and Boerseun like this.
  14. Sep 27, 2018 at 6:20 PM
    madmatt
    madmatt New Member
    Ocala Florida
    If you put it below the trays, how is there room for the trays? They should be sticking up as though you never cut anything out then?
  15. Sep 27, 2018 at 6:58 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    He is talking about the carpet and a thin padding under it, not the styrofoam.
    Rhernandez09 likes this.
  16. Sep 27, 2018 at 7:25 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The styrofoam doesnt really add any sound proofing qualities. The carpet padding does add a little bit so putting that back in below the storage bins would probably not be much different that stock as far as noise goes. I added closed cell foam and mass loaded vinyl on between the styrofoam and carpet, if I put bins in I would put the closed cell foam, carpet pad, and MLV under them.
  17. Sep 27, 2018 at 8:27 PM
    Rhernandez09
    Roy
    Not talking about the foam just the carpet and underneath the carpet is a thin layer of insulation.
  18. Sep 28, 2018 at 6:12 AM
    Blueknights75
    Ron
    Clayton, NC
    Nope
  19. Sep 28, 2018 at 1:02 PM
    #49
    madmatt
    madmatt New Member
    Ocala Florida
    Ok, that makes more sense, thank you.
  20. Sep 28, 2018 at 1:32 PM
    #50
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    NO! Trust me, you will not notice any difference...
    madmatt[QUOTED] likes this.
  21. Sep 28, 2018 at 4:42 PM
    #51
    Mtbrider541
    Eric
    Medford Or
    2015 Tundra CM TRD
    By the way. New leg bases aren't cheap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  22. Sep 29, 2018 at 8:40 PM
    #52
    Mtbrider541
    Eric
    Medford Or
    2015 Tundra CM TRD
    Few picks from today
    betotundra, doggiecareman and Pudge like this.
  23. Sep 30, 2018 at 2:15 PM
    #53
    FRescueLt
    FRescueLt New Member
    Dave
    Wisconsin
    2018 MGM TRD CM
    None.... Yet
    Love seeing this. I am a chicken with mods. I just got the 2018 Tundra last week and want to use space that I know can be there. Unfortunately, I also teach vehicle rescue and worry about changing the seats without anyone to stand behind it (or be willing to sit on them after). For the most part, I just want a 4" deep space under the seats that is the width of the row. Was looking for something like a metal single rifle case but haven't found the right one yet. Any thoughts?
  24. Sep 30, 2018 at 2:24 PM
    #54
    Boerseun
    Ferdie
    Sarasota Florida
    https://www.esptruck.com/product-page/2014-2018-toyota-tundra-crewmax-long-box-under-seat-storage
  25. Sep 30, 2018 at 2:25 PM
    #55
    FRescueLt
    Dave
    Wisconsin
    2018 MGM TRD CM
    None.... Yet
    Thank you. Now to save my loose change.
  26. Sep 30, 2018 at 2:26 PM
    #56
    madmatt
    madmatt New Member
    Ocala Florida
    I plan to put in a rifle case and a pistol safe once I get the guts to cut my new truck. I’ll let you know how it goes.
  27. Sep 30, 2018 at 4:37 PM
    #57
    FRescueLt
    Dave
    Wisconsin
    2018 MGM TRD CM
    None.... Yet
    Madmatt I would appreciate that. I would like to figure something out for my AR pistol or my sbr. However, with two little boys I also have carseats sitting on the back row so folding isn't the easiest. Possible, but not easy.
  28. Sep 30, 2018 at 4:58 PM
    #58
    madmatt
    madmatt New Member
    Ocala Florida
  29. Sep 30, 2018 at 5:07 PM
    #59
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  30. Sep 30, 2018 at 5:16 PM
    #60
    madmatt
    madmatt New Member
    Ocala Florida
    I just watched a video about it, now I think I’ll have to reimagine what I’m going to do. Hmmmm
