CrewMax and Truck boxes?
Discussion in '2.5 Gen Tundras (2014-2021)' started by vader7071, Sep 17, 2018.
  1. Sep 17, 2018 at 9:14 AM
    vader7071
    vader7071 [OP] New Member
    Dothan, AL
    2018 SR5
    Ok, so I'm looking to add storage to the Tundra. 2018 model, CrewMax.
    In the olden days, before I had extended cabs, crew cabs, etc, (e.g long truck beds), I would just put a truck box in the bed, lose a little storage, and move on. But getting the CrewMax, the bed is only about 5' 6" (give or take). Do I want to give up almost 2 feet of my bed putting in a truck box?
    What are the thoughts from the hive? Who has put them in and liked them? Who has put them in and taken them out? Who looked at the box and said "Aw hell NAW"?
    And part 2 of my question, what did you do to store your tow straps, tools, boots, junk, and other odds and ends?
  2. Sep 17, 2018 at 9:25 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I currently store my recovery gear in my under seat storage (lots of DIY info here on that). If I end out doing a tool box it'll be something I can lock down for off-roading and take out when I'm not using it so I can have the space back. I'm also considering a Diamondback cover and one of their storage systems, but that may not fit my purposes. I've got a list of the ones I'm considering on my build page.
  3. Sep 17, 2018 at 9:26 AM
    JoshO
    JoshO New Member
    2018 Magentic Gray Tundra
    So I got an organizer for the center console and put the straps in there and got a tray that keeps other things at arms reach. I also shoved some things behind the seat, if you flip up the seat you can access the little cavity back there. I then and got a roll up tonneau cover.
    I have seen some nice mods with Ammo Cans. I have also seen the truck boxes the mount behind and over the wheel well that do not take up very much bed.
    Additionally there is a bin that you can install under the rear seat cutting out some carpet and insulation.
  4. Sep 17, 2018 at 9:28 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    ESP storage box under second row. Stow all my recovery gear there.
    Blueknights75 likes this.
  5. Sep 17, 2018 at 9:31 AM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    I just added some storage to the bed of the truck. Takes up minimal bed space
    Was going to do the DIY Ammo Can Storage, but needed more room. Might add one to the other side for extra storage
    4x4_Angel, Gabrielo93 and saybng like this.
  6. Sep 17, 2018 at 9:32 AM
    4x4_Angel likes this.
  7. Sep 17, 2018 at 9:57 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    You're probably not running a cover but if you are this is what I run. It folds away when and if you need the full bed.
    https://bakindustries.com/bakbox2-utility-storage-box
    I didn't want to do the under back seat storage as I always have the dogs in the back seat and always have a cover/hammock on the seat which would make it a pia when I need to get to the stuff.
  8. Sep 17, 2018 at 9:58 AM
    vader7071
    Dothan, AL
    2018 SR5
    Can't run a cover. I have 2 antennas mounted in the bed.
    4x4_Angel and nowayout like this.
  9. Sep 17, 2018 at 10:00 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    In that case I think @ColoradoTJ idea is the best.
    4x4_Angel and ColoradoTJ like this.
  10. Sep 17, 2018 at 10:27 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  11. Sep 22, 2018 at 10:18 PM
    Gabrielo93
    Gabrielo93 New Member
    Gabriel
    Grand Prairie, TX
    2015 Black Toyota Tundra SR DC
    12 Volt Remote Starter Lockerdown Safe ICS Fab Dash Mount Husky All Weather Beaters Mats Rear Folding Seat Mod Linex Platinum Kicker Sub/Amp Combo CoverCraft Dash Cover Kenwood Headunit Cravenspeed Untenna CupHolderHero Aukee Tailgate Inserts OEM Deck Rails Rolling tonneau cover CravenSpeed Untenna
    Did you mount the ammo can?
  12. Sep 23, 2018 at 8:56 AM
    Bailey
    CO
    Yes - 4 bolts to the bed
  13. Oct 8, 2018 at 1:21 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    What size can did you use?. I'm getting my bed cover put on wed and I want to do this on the weekend. I'm nervous about screwing it into the bed though. I have the factory Toyota drop in liner I might try and just screw it that instead of the bed. You think that would hold it sturdy?
  14. Oct 8, 2018 at 3:11 PM
    Bailey
    CO
    20mm Ammo Can. I'd recommend bolting through the bed or installing threaded inserts (nutserts). Don't think a drop-in liner would hold up very well
  15. Oct 8, 2018 at 3:16 PM
    War_Wagon312
    Rich
    Stock horse
    Any pics of where you drilled? My luck I'll hit something hahah
  16. Oct 9, 2018 at 11:18 AM
    TheBozzHogg
    TheBozzHogg New Member
    Jimmy
    2015 White Texas Edition SR5 CrewMax
    I run two, they are both shallows, so there is still bed room under the boxes also have a weekender type ladder rack. Not a huge fan of bed covers, they tend to leak and even if they don't you wind up with chaos underneath it. So if I have something that is too tall to fit in the bed under the boxes and I can't get it on the rack, then open the tail gate and tie it down on there. Best part is hauling furniture is not something I will get asked to do. But even if I have to do something like that, only takes about 20 minutes to remove both boxes...I have a ton of tools that I have to haul around for work, so this was the best option for me.
    tbutler likes this.
  17. Oct 9, 2018 at 11:31 AM
    TheBozzHogg
    Jimmy
  18. Oct 17, 2018 at 7:02 PM
    incredibillhulk
    incredibillhulk New Member
    Bill
    As others have said, the ESP Truck underseat storage is a must and should have absolutely been something offered direct from Toyota. They were my first upgrade. Beyond that, while you've mentioned not wanting to lose length, what about depth? They're costly, but how about a storage system liked that from DECKED (pictured below).
    jewsNbrews likes this.
  19. Oct 17, 2018 at 7:11 PM
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
    Just put a shallow low profile in on mine (matte black) and like it so far. I rarely haul stuff in the bed, and if I do it's related to camping and I have plenty of room for that with the toolbox in place.
  20. Oct 23, 2018 at 2:54 PM
    vader7071
    Dothan, AL
    2018 SR5
    I'm making my own little version of the ESP storage. Mine will run me about $40 when done. You can see what I am doing here: https://www.tundras.com/threads/crewmax-backseat-storage-hack.27951/page-4#post-823146
    As for the Decked system. I seriously looked into that. I liked it a lot, until I started reading the reviews. I like that concept, and I am toying with making my own version, or I'm debating making one like this:
    Keeping the spacing about 49" face to face so I can still lay a full sheet of plywood in the bed.
    Bassmonkey67 and Hondoman like this.
  21. Oct 23, 2018 at 3:03 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Do you have a link for the one on the pic?
  22. Oct 23, 2018 at 3:18 PM
    vader7071
    Dothan, AL
    2018 SR5
    That is for a Nissan Titan. My neighbor has it and I'm gonna try and build a Toyota version.
    Hondoman[QUOTED] likes this.
  23. Oct 23, 2018 at 3:19 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Ah, gotcha. Thanks
  24. Oct 23, 2018 at 3:40 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    That’s not real.... lol it looks awesome
  25. Oct 23, 2018 at 3:46 PM
    NHPig
    NHPig Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
  26. Oct 23, 2018 at 3:56 PM
    I think you’re correct on pricing.
