Creaking/Clanking/Noise Front Drivers Door
Discussion in '2.5 Gen Tundras (2014-2021)' started by jtdunc, May 1, 2019.
  1. May 1, 2019 at 2:52 PM
    jtdunc
    jtdunc [OP] New Member
    2014 Tundra Double Cab - Magnetic Gray
    My door makes two loud clanking noises when I open and close. Like it's forced into two slots before opening or closing fully.
    No misalignment and it's not rubbing on the front quarter panel or hitting the door latch wrong?
    Dealer had recently (90 days ago) replaced by power door vacuum lock assembly.
    Ideas to quiet?
  2. May 1, 2019 at 3:00 PM
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    My rear doors made a somewhat noise at two spots. Sort of where the door shifts itself to where it stays open. I looked at the hinge and if you look closely it’s an odd shape but it has two main spots that once you open it past those, it’s sort of like a bulge to keep it from closing. Maybe some wd-40 there????? Not sure if this is what you’re talking about but I just left it alone to let it work itself out during use.
  3. May 1, 2019 at 4:28 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Check the 2 bolts on both the door and the 1 on the a-pillar extension to ensure the hinge brackets arent loose.
    If you cant figure out what I'm talking about, let me know and I'll take a pic.
    bulldog93 and Black Wolf like this.
  4. May 1, 2019 at 4:30 PM
    This^^^. Quite common.
    bulldog93 and 14burrito[QUOTED] like this.
  5. May 1, 2019 at 4:32 PM
    Same issue on my 09 Taco and happened on my driver side front door on my Tunny. Easy peasy fix.
    bulldog93 and 14burrito like this.
  6. May 1, 2019 at 8:36 PM
    jtdunc
    These?
    https://youtu.be/TxS9ytraxnY
    If these are the right ones, can one of you please take pix so I know which bolts to check? I'm a visual guy.
    bulldog93 likes this.
  7. May 1, 2019 at 8:51 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    That's it
  8. May 3, 2019 at 6:09 PM
    jtdunc
    That was it. Loose 10mm bolts. Thanks guys!!!!:thumbsup:
  9. Feb 5, 2023 at 9:49 PM
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    Going to try this tomorrow morning! Thanks guys for posting these great remedies!!!!
