Crank and No Start: Facts and Assumptions (with vid)
Discussion in '2.5 Gen Tundras (2014-2021)' started by Snowboard Tundra, Jan 24, 2019.
  1. Jan 26, 2019 at 9:28 AM
    Snowboard Tundra
    Snowboard Tundra [OP] New Member
    Correct, at the house (8300 ish)
    mojojo[QUOTED] likes this.
  2. Jan 26, 2019 at 9:31 AM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Elevation matters to the MAF. Good luck and hope it works!
  3. Jan 26, 2019 at 10:00 AM
    15whtrd
    15whtrd Mr. Blonde
    Hope it works out for ya! Report back with updates for sure.
  4. Jan 26, 2019 at 11:01 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    after the first failed start you should have switched keys. do you have your second key?
  5. Jan 26, 2019 at 3:59 PM
    Snowboard Tundra
    I have a second key, same result
  6. Jan 26, 2019 at 4:00 PM
    Snowboard Tundra
    Well....
    On my second attempt to start it at the house today....crank crank crank crank. Took three tries yet again.
    I ordered a new MAF from Napa and will pick up this week, will let you know.
    15whtrd[QUOTED] likes this.
  7. Jan 26, 2019 at 4:03 PM
    15whtrd
    15whtrd Mr. Blonde
    Man I hate throwing parts at stuff without a clear answer. But I have gotten lucky many times in the past from gut feelings.
    Unless I missed it, did you answer whether or not you are flex fuel?
    Boosted4runner likes this.
  8. Jan 26, 2019 at 4:06 PM
    Snowboard Tundra
    Sorry about that. Not Flex fuel.
    New MAF like $90, if it works it's great. If it doesn't....well I have a new MAF and next stop will be dealership (dread). It's still got some warranty I believe.
  9. Jan 26, 2019 at 8:16 PM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Yep. I agree. It just leaves you even more frustrated in the end.
  10. Jan 26, 2019 at 8:17 PM
    Boosted4runner
    WA
    Did you clean the battery terminals?
    And I mean clean the shit out of the terminals, and the cables? Baking soda....
  11. Jan 29, 2019 at 10:16 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Maybe someone had asked this before... when it does finally start after the cranking issue, does the engine initially run any different that when the problem does not occur? Is there any hesitation or rough idle?
  12. Feb 1, 2019 at 6:37 PM
    OleCarWeezy
    OleCarWeezy New Member
    Kevin
    2015 Black Tundra Limited- Lifted
    ProComp Lift 20" LRG Rims 35" Firestone Tires AMP Power Step Boards
    @Snowboard Tundra I'm having the same issue with my 2015 with 85k. It has happened inconsistently but almost exclusively in Cold Weather. Has happened in Mississippi and Maryland over the last 12 months. When it misses, it has never failed to eventually start, but it takes on average 3-4 attempts. i haven't found a solution yet. Following to find out what to try next. Mine is an FFV though. I have seen it mentioned above about the TSB being put out for a fix similar to these issues but i haven't seen anyone report back confirming that resolved it.
  13. Feb 20, 2019 at 9:41 AM
    Snowboard Tundra
    Just wanted to provide an update. Prior to making appointment with dealership I wanted to try one final thing. I ran 2 bottles of fuel injector cleaner through the truck....since that time (about 2 weeks ago) I have had no issues starting the truck. At the house, in the high country it fires the first time every time and even in the extreme cold we have had recently.
    Not sure how this $20 fix will last but it seems to be going great so far.
    NewImprovedRon likes this.
  14. Feb 20, 2019 at 9:42 AM
    15whtrd
    15whtrd Mr. Blonde
    Wonder if something weird like injectors being stuck and leaking out when parked.
  15. Feb 20, 2019 at 12:39 PM
    15whtrd
    15whtrd Mr. Blonde
    Do you think there’s a possibility that that stuff could contaminate the oil? Whenever I’ve ran any fuel system treatment I tried to run it near the end of the oil life cycle so that I would be putting in fresh oil soon. I only did this because I was slightly paranoid it would break down my oil somehow someway.
  16. Feb 20, 2019 at 1:18 PM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    My truck started doing this a couple of weeks ago. I just added a bottle, let’s hope it helps!
  17. Feb 20, 2019 at 3:11 PM
    15whtrd
    15whtrd Mr. Blonde
    No mostly just hearsay. But I’ve never heard anything bad about seafoam. It was put into my head from a buddy who over thinks everything but he’s pretty mechanically inclined. I was using Lucas fuel system cleaner injector cleaner stuff. Just something he threw out there.
  18. Feb 20, 2019 at 3:46 PM
    Twinky
    07 double cab work horse
    It depends on if its being used in your gas vs oil.
    For gas its not an issue since you're going to burn it up. For oil use it will remain in the system.
    I believe seafoam states to use it for about 2 weeks for oil applications. Other than that i dont remember there being any other application that mentions any restrictions.
    Optima batts are actually AGM, not gell.
    Just to clarifying.
  19. Aug 22, 2020 at 8:58 PM
    #49
    channlan
    channlan New Member
    Has anyone found a definitive solution to this? Happened to me for the first time today in high elevation.
  20. Aug 22, 2020 at 11:59 PM
    #50
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    After watching the video...when your truck finally started after a long crank, I noticed it was running very rich and idle rough for a couple a second. This is a sign of bad leaky injectors. They are flooding your engine and that is why you are having problem starting. Need to replace INJECTORS.
  21. Aug 23, 2020 at 5:52 AM
    #51
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The OP found a definitive solution to his problem. See post #43 above. Easy and low cost solution if your problem is caused by the same fault as the OPs.
  22. Aug 23, 2020 at 6:58 AM
    #52
    blanchard7684
    blanchard7684 New Member
    I know its an old post, but this also sounds similar to the 'fuel pump recall' symptoms.
  23. Mar 29, 2023 at 3:42 PM
    #53
    bookooc
    bookooc New Member
    Rick
    Love it when someone tells you what you need to do, (not the solution) long after you found the solution and reported the fix. And thanks to the OP for not leaving everyone hanging how he fixed it.
