Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Dec 27, 2022 at 7:00 PM
    #2251
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Pics of us driving home with me holding the shifter in place.
    icewater, bmf4069, txagg and 3 others like this.
  2. Dec 27, 2022 at 7:21 PM
    #2252
    daveeasa
    David
    Earning stripes.
    Tundra2[OP] likes this.
  3. Jan 1, 2023 at 2:01 PM
    #2253
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
  4. Jan 1, 2023 at 7:11 PM
    #2254
    dbittle likes this.
  5. Jan 3, 2023 at 7:41 PM
    #2255
    Tundra2
    Noah
    Western Kentucky
    Steering column support arrives tomorrow Via "FedUp." I'm hoping to have everything installed, and fixed either by the weekend, or during... Thanks again @shifty`, and @Jack McCarthy for digging up threads/making thread here or there to help with this repair.
    I've been doing some mechanic thinking on why that corner piece is so "weak." It's designed that way to protect the transmission linkage, and the cable. That's the "easiest" thing to repair out of all the things that could go wrong with that whole idea of shifting... Would you all agree?
    shifty` and Jack McCarthy like this.
  6. Jan 3, 2023 at 7:48 PM
    #2256
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Truthfully I haven’t given it much thought in years. A thin steel plate sandwiched between the two cast pieces could aid in preventing it from coming apart by holding the screws I suppose. It’s just a bad design with the materials chosen.
  7. Jan 4, 2023 at 5:42 AM
    #2257
    If something is going to be a clear fail point, you beef it up. Either by casting extra supports into the part, making it a 2-piece clamshell design, adding more material on the thin sides (northeast/southwest as the part sits) or similar.
    I haven't seen this happen in the '05-'06 trucks, so something must've been improved later. I can't think of a way to beef it up, really, and if it's simply a casting issue and/or metallurgy problem, they may've fixed the later casts, so the new part may actually last longer. If not, enjoy the next 20 years until the new part fails! :rofl:
  8. Jan 14, 2023 at 4:09 PM
    #2258
    Tundra2
    Noah
    Western Kentucky
    I finally got my steering column support replaced today. I tried to do it in the cab, and it just wasn't happening.
    I figured out where all the squeaking from my steering shaft was coming from, or part of it. The upper bearing as seen below is rusted to hell and back. The lower bearing was a little better. I lubed both of these with anti-sieze as it's all I had on hand.
    I ended up having to remove the whole column to get this job done which let me fix the intermittent horn, and the squeaky shaft too. Guess it was a bonus.
    @empty_lord do you know if these are OEM markings or Junkyard markings? Gut says junkyard, but lack of mangling on anything makes me think OEM.
    Anyways, these pivot points were a bitch. Ended breaking the bracket to get them out. I don't own a slide hammer.
    Taking everything apart really let me see how nasty the inside of the truck is, but it did let me lube everything up. Everything that slides got a healthy coat of anti-sieze. I would have used grease, but I didn't have any.
    I "pre-tapped" the lobular screws before putting the new shift mechanism on.
    Finally starting to go back together!
    I even lubed the joint at the tilt steering for the steering shaft. Again, with anti-sieze...
    The horn contacts were dirty/corroded from the humidity that's apparently been in the cab at some point. Brushed it off, and lubed this with anti-sieze also.
    I got everything back together, and then went for a test run through the yard. That shifter is fucking smooooooth now along with the the steering shaft no longer squeaking.
    This is crackies new resting place until his abilities are needed again.
    Bmktw2, shifty`, bmf4069 and 9 others like this.
  9. Jan 14, 2023 at 4:16 PM
    #2259
    Jack McCarthy
    Bill
    North of Boston
    Yeah even my steering column is nowhere near that crusty rusty. My guess is junkyard swap. FYI…Autozone used to rent the slide hammers. I don’t know if that’s changed or not. Great work though. Glad you got your squeak fixed.
    Tundra2[OP] and dbittle like this.
  10. Jan 14, 2023 at 5:23 PM
    #2260
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Looks like yard markings
    Bmktw2 and Tundra2[QUOTED][OP] like this.
  11. Jan 14, 2023 at 6:13 PM
    #2261
    Tundra2
    Noah
    Western Kentucky
    Damn... Are they all the same through all the years?
  12. Jan 14, 2023 at 6:42 PM
    #2262
    empty_lord
    05 rollover special
    00-06 access and reg cabs are I believe.
    Tundra2[QUOTED][OP] likes this.
  13. Jan 14, 2023 at 6:48 PM
    #2263
    Tundra2
    Noah
    Western Kentucky
    Thanks Dan, I'll add this to my WTB thread as a "non-important" but if you see one that's in good shape... snag it.
    How is your truck coming along?
  14. Jan 14, 2023 at 7:33 PM
    #2264
    Definitely JY markup there, FWIW. So, someone's been in there before. That's interesting... Wonder if this isn't the first time it broke?
  15. Jan 14, 2023 at 8:11 PM
    #2265
    Tundra2
    Noah
    Western Kentucky
    @shifty` took me a second to find your words. I agree.
    Mom just sent me this.
    bmf4069, shifty`, txagg and 1 other person like this.
  16. Jan 14, 2023 at 8:56 PM
    #2266
    empty_lord
    05 rollover special
    body shop is booked full till march
  17. Feb 1, 2023 at 9:17 AM
    #2267
    Tundra2
    Noah
    Western Kentucky
    So... while I was "away" I almost killed crackie. Left late going to the new job, and hit a patch of black ice. The ass end swung out to the right of me, and I was skooting down the road sideways. Passengers side first. I tried to steer into it, but it didn't do anything. Once my front wheels got off the pavement, the 4WD pulled right directly towards this telephone pole. I cut down one of the support guide lines or grounds or whatever it is. @Cummins3500 would know exactly what it is. Maybe @Outbound too.
    Here's pictures from that morning. The flash on my phone reflecting off my case is that "glare" you see.
    Pictures from the gas station down the road a ways.
    Pictures of my quinoa I spilled all over the fecking place when I was trying to steer away from the telephone pole...
    Daylight pictures from the new Job.
    Pictures of the scene in daylight.
  18. Feb 1, 2023 at 9:26 AM
    #2268
    Tundra2
    Noah
    Western Kentucky
    Also documenting the ice event.
    20230131_042732.jpg 20230131_042735.jpg 20230131_042741.jpg 20230131_050448.jpg 20230131_084731.jpg 20230131_084746.jpg
    And now the first thaw...
    Jack McCarthy likes this.
  19. Feb 1, 2023 at 9:43 AM
    #2269
    Outbound
    Aaron
    Northern Alberta
    I just call them support lines. Maybe grounding wires too, but I'm not sure. Almost all our power lines are below ground.
    Glad you didn't crack up in Crackie.
  20. Feb 1, 2023 at 9:48 AM
    #2270
    Glad you're OK and crackie rides again. Guy wires is what we've always called them, but regardless we are glossing over the biggest question from those "incident" photos. Sonic sells quinoa??
  21. Feb 1, 2023 at 10:31 AM
    #2271
    I'd always heard to called guyed ("guide") wires because they're used on guyed towers. To the point I usually just write "guide" so people know wtf I'm talking about.
    Learned something new today.
    Noah, it could've ended way worse than it was and actually looks like it ended in almost the best possible way. If you were an asshole, you might not've been so lucky ;)
  22. Feb 1, 2023 at 11:19 AM
    #2272
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Ya'll talking about kite catchers?
  23. Feb 1, 2023 at 11:20 AM
    #2273
    Uncle caught the back tire of his wheelie-in-progress CR125 on one. That's a bad day at the office. And a visit to the ER.
  24. Feb 1, 2023 at 11:39 AM
    #2274
    Collar bones intact?
  25. Feb 1, 2023 at 11:59 AM
    #2275
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Black ice is so common here in the PNW so I forget that y’all don’t typically deal with it in the south. Glad you’re ok though.
  26. Feb 1, 2023 at 1:53 PM
    #2276
    And they call me "shifty". Sheesh. :rofl:
    (I can't believe I missed this opportunity prior)
  27. Feb 1, 2023 at 2:46 PM
    #2277
    Tundra2
    Noah
    Western Kentucky
    Cractivities
  28. Feb 1, 2023 at 3:19 PM
    #2278
    Tundra2
    Noah
    Western Kentucky
  29. Feb 1, 2023 at 4:59 PM
    #2279
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    What kinda TP you run in the cold? 35 psi? 45psi? Charmin double ply?
  30. Feb 1, 2023 at 6:41 PM
    #2280
    Tundra2
    Noah
    Western Kentucky
    I run 35 all the time. Hot or cold.
