Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Aug 30, 2021 at 4:32 AM
    #181
    Yeah, just be sure to save the PCBs for the controls on the old panel or whatever. Just in case. May feel stupid holding onto a busted up old panel, but ... Man, if your AC ever dies because the controls go out, you're f'ed.
    Oh, and make sure your AC still works after swapping in the new-old-new. :D
    Tundra2[QUOTED][OP] and bmf4069 like this.
  2. Aug 30, 2021 at 5:14 AM
    #182
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I thought pink milk shake was when you blow the head gasket and the red Toyota coolant mixes with your oil. Now I'm confused.
    Tundra2[QUOTED][OP] likes this.
  3. Aug 30, 2021 at 5:25 AM
    #183
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I suppose someone might call it that but it's actually when your coolant makes it's way into your transmission via those lines that help cool the transmission fluid. It seems to be pretty rare though.
  4. Aug 30, 2021 at 5:32 AM
    #184
    TRDGen
    TRDGen Schnooogins
    Travis
    Right? I'm confused on how red coolant and red trans oil makes a pink milkshake.
    Tundra2[OP] likes this.
  5. Aug 30, 2021 at 5:33 AM
    #185
    Pink milkshake happens when the radiator goes bad. Specifically the part of the radiator that has the transmission cooling lines ran through it. Then Coolant gets into the trans fluid creating a delicious strawberry delight. That destroys transmissions.
    Tundra2[OP] and TRDGen[QUOTED] like this.
  6. Aug 30, 2021 at 5:33 AM
    #186
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I think the oil and water mix and turn frothy making is look like a milk based product
  7. Aug 30, 2021 at 5:58 AM
    #187
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Called advanced auto in e-town. Spoke with a very helpful, and knowledgeable dude. He asked me what engine size. I said "4.7 liter V8." He asked me if it was an Access Cab, and I said "Regular cab." He said "Oh, very cool." :D
    Tried to sell me on cheaper off-brand radiators which I declined. Was insistent on Denso. He explained that they do price match, but not with Amazon. I'll shop around online to see if I can find a cheaper unit.
    A-zone doesn't list denso on their website. If I can't find a cheaper one, I'll bite the bullet, and call Advanced at Hoptown.
    NUDRAT and FrenchToasty like this.
  8. Aug 30, 2021 at 6:01 AM
    #188
    And froth is bad for transmissions. Transmission fluid is specifically designed to eliminate frothing. They are hydraulic and need pressure from pumping the fluid to operate. Bubbles are compressible and make the fluid unable to maintain the pressure needed to operate. It also acts as a lubricant. The coolant/water part decreases the lubricity increasing wear and can create corrosion.
  9. Aug 30, 2021 at 6:09 AM
    #189
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    TRDGen[QUOTED] and Tundra2[OP] like this.
  10. Aug 30, 2021 at 6:34 AM
    #190
    Tundra2
    Noah
    Western Kentucky
  11. Aug 30, 2021 at 6:52 AM
    #191
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Quick search finds an OEM Rad ~$150
    https://www.oemgenuineparts.com/oem-parts/toyota-radiator-16410az018
  12. Aug 30, 2021 at 10:47 AM
    #192
    @Tundra2 if you haven't found any radio brackets yet (I'm not headed to JY soon or I'd look on your behalf!) it looks like 00-02 used the same brackets and 03-06, and I did a little digging in case you hadn't found any donors yet and it may save you time or something.
    These are the p/n for the first couple years (00-02?): 86212-0C010, 86211-0C010
    Here's the p/n for the latter years (03-06?): 86212-0c011, 86211-0c011
    Looks like fleabay has an option for both.
    The older ones for $50 shipped, search for 362731957289
    The newer ones for $42 shipped, search for 361752256524
    NUDRAT and Tundra2[OP] like this.
  13. Aug 30, 2021 at 11:39 AM
    #193
    Tundra2
    Noah
    Western Kentucky
    So what did I order from mcgeorge? Viewing on mobile is hard...
    These are supposed to be left and right.
  14. Aug 30, 2021 at 11:39 AM
    #194
    Tundra2
    Noah
    Western Kentucky
    So good news, Toyota is going to replace the frame!
    Hooptytrix, chrisb, N84434 and 10 others like this.
  15. Aug 30, 2021 at 11:54 AM
    #195
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Bad news....you pissed your pants after hearing that :eek2:
    Stoked for ya :yes:
  16. Aug 30, 2021 at 12:05 PM
    #196
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  17. Aug 30, 2021 at 2:02 PM
    #197
    Tundra2
    Noah
    Western Kentucky
    Picked up the shit box from Swope with @TundraGirl2
    Still another 93 miles till home.
  18. Aug 30, 2021 at 2:31 PM
    #198
    Yep, you got the right ones! Awesome.
    HELL THE F YEAH! Super awesome. See, it pays to buy trucks from tweakers! They're too messed up to realize recall work, warranty work etc. can be free if you have the time and knowledge.
    Now all you gotta worry about is cleaning up and de-tweaking that interior, then patching up that lil but of rust on the side. Wish you were closer, I'd totally help you with that patch. Granted, I'm sure we probably have other members closer who may be able to help...
    Btw, while you're better off just cutting a small section off a donor truck to make your patch, if you really wanted to go OEM with that rust patch, I think the part number is 61418-0c030 but check the exploded diagram on this page to confirm what you need - click "View Full Size", jot down the 5-6 digit number in the diagram, then use CTRL+F/Command+F to search the page for that number.
    Oh, and the parts on that page are specifically for the 2000 RC SR5 4.7L Auto transmission truck. Dealership should be able to confirm you're getting the right part, but this part number will get you in the ballpark.
    NUDRAT and Tundra2[QUOTED][OP] like this.
  19. Aug 30, 2021 at 2:32 PM
    #199
    Why do I get the funny feeling this is going to end up becoming your main truck?
    chrisb, NUDRAT, FrenchToasty and 6 others like this.
  20. Aug 30, 2021 at 2:33 PM
    #200
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Best news I've heard all week! Glad all this driving has been worth it anyway.
    You better take a gander at that timing belt now though.
  21. Aug 30, 2021 at 2:38 PM
    #201
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    Great news on the frame replacement! If you decide to keep the truck, I expect that you will find it to be amazingly useful.
  22. Aug 30, 2021 at 2:59 PM
    #202
    Tundra2
    Noah
    Western Kentucky
    NUDRAT likes this.
  23. Aug 30, 2021 at 3:06 PM
    #203
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Hmmm....have you taken a peek at the TB ?
  24. Aug 30, 2021 at 3:22 PM
    #204
    Sounds like a schoolbus How's the timing belt look? (considering all the other shit tweaker dude ignored)
  25. Aug 30, 2021 at 3:38 PM
    #205
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Damn, better get that exhaust fixed! That sure is annoying.
  26. Aug 30, 2021 at 3:56 PM
    #206
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I've only asked him about the timing belt 3 times. :D I wouldn't keep driving it until I looked at it.
    06yotamike and Tundra2[OP] like this.
  27. Aug 30, 2021 at 4:13 PM
    #207
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    he's giving it a good test at 80 :facepalm:
    NWPirate and Tundra2[OP] like this.
  28. Aug 30, 2021 at 5:16 PM
    #208
    Tundra2
    Noah
    Western Kentucky
    Well, as requested, numerous times... I give you pics of the Timing belt!
    I'd say it's original. I didn't feel like burning my hands anymore against hot coolant pipes and hoses for more clearance. Y'all'll just have to wait till I get to the TB/WP, and thermostat.
    Desert Dog likes this.
  29. Aug 30, 2021 at 5:17 PM
    #209
    Tundra2
    Noah
    Western Kentucky
    I'm still jaded from today. Been on the road since 8 am. 5 different cities, $5,200, 400 miles, and two different time zones later... I'm home at 6:00 pm before Timing belt pics.
    Thank you so much for all this info. I'll give it a gander once I'm not so woozy from today.
    NUDRAT likes this.
  30. Aug 30, 2021 at 5:32 PM
    #210
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yep. That belt is toast. You planning to do the timing belt yourself? Should be a fun project.
    This truck is a testament to Toyota reliability. Been a farm truck for 20 years. Rode hard and put away wet. Likely the original timing belt at nearly 300k miles. Probably hasn't had any maintenance aside from an occasional oil change. Wouldn't be surprised if the trans fluid is original. Try doing this with a Ford or GM. There is no way it would still be humming along.
    Nice find Noah. Once she has a new frame you can drive it another 20 years. Excited to see the maintenance journey.
