Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Aug 21, 2022 at 12:44 PM
    #2011
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    congrat's!
    Tundra2[OP] likes this.
  2. Aug 22, 2022 at 6:43 AM
    #2012
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Shiiiiiit, maybe... I don't know yet. Gotta see how the rest of this year pans out my dude!!!
    I've got research to do, and lots of it...
    There's wires taped up on the tongue, and an additional LED set of tail lights wired into the factory set. Best of my research yields a 7 round plug was factory. Wire nuts, crimps, and zip ties underneath all point to modifications by one of the three previous.
    I have no idea how insurance works on it yet. I need to call state farm, and inquire. I may omit the fact that the brakes don't work yet to see what they can do.
  3. Aug 22, 2022 at 6:44 AM
    #2013
    Tundra2
    Noah
    Western Kentucky
    Well... shit.
    Thanks @NUDRAT one step closer to freedom!
    NUDRAT[QUOTED] likes this.
  4. Aug 22, 2022 at 6:49 AM
    #2014
    Tundra2
    Noah
    Western Kentucky
    Got it home late Saturday night. Just pulled straight into the driveway, and parked. Sunday morning we swung it around, and put the camper in its temporary spot while we are still at the parents place.
    Crackie will move anything in 4LO at idle. Just pulled up into the neighbors yard in the wet morning grass made a large loop, and pulled straight back down into the driveway, and creeped it back to where she sits now.
    Gonna be re-sealing the roof, recaulking everything, re-sealing everything, and replacing all the shrouds on the roof.
    New shrouds, and vent covers will be here tomorrow. Any advice for doing a roof is welcome. I'm a newbie...
    bmf4069 and FrenchToasty like this.
  5. Aug 22, 2022 at 6:53 AM
    #2015
    Tundra2
    Noah
    Western Kentucky
    The dinette has been removed from our, and replaced with a light weight table set. A few differences between the 86 model and the 88 model. This is basically what it looks like inside.
    https://youtu.be/w1FzGHvC_gE
    FrenchToasty likes this.
  6. Aug 22, 2022 at 7:03 AM
    #2016
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    As for roof, would be surprised if onesjouner didn’t have some input. Search his history here or post at TS, he’s under different name
    Tundra2[OP] and FrenchToasty like this.
  7. Aug 22, 2022 at 7:12 AM
    #2017
    NUDRAT and Tundra2[OP] like this.
  8. Aug 22, 2022 at 7:13 AM
    #2018
    I'm going to guess that a 1/4 cup of liquid bleach diluted into a gallon of water with a healthy squirt of dish soap added will go a long ass way to getting the mildew off the roof. Apply the solution to the roof and hit it with a deck brush after it soaks for a couple minutes. You'll want to clear that up before you caulk or seal anything.
    KNABORES and Tundra2[OP] like this.
  9. Aug 22, 2022 at 7:14 AM
    #2019
    Tundra2
    Noah
    Western Kentucky
    I left a post over on TS for him. I wish he'd come back here, but I understand...
    Thanks for the recco. I'll look into it. Dad has a gallon of some sort of rubber coating he bought a few years ago for the other camper.
    My main question is... do I replace the vents/shrouds before or after the new rubberized membrane?
  10. Aug 22, 2022 at 7:21 AM
    #2020
    Some of the covers may be screwed into the roof. If so, you need to remove the old sealer, unscrew and remove the old cover, scrape and clean to install the new cover, then apply the eternabond tape. The rubber roof coating stuff is hit or miss and has to be frequently inspected, patched and repaired. Eternabond, when properly applied, is a semi-permanent solution. Find one of those crusty looking RV parts sellers, not f@cking campingworld, and check out there used and scratch and dent items. Good place to score low cost goody bits for the camper. You can spend a fortune on the dumbest things for campers.
  11. Aug 22, 2022 at 7:35 AM
    #2021
    While on the leak prevention mode, every window, door and opening on the camper needs to be cleaned and re-sealed with caulking to prevent the worst kind of leak. The invisible one. Really anything screwed to the side of the camper, lights and fittings included. I had a 6 year old camper get floor rot in front of the door due to the door seal leaking. turned into a big repair project.
  12. Aug 22, 2022 at 11:42 AM
    #2022
    Tundra2
    Noah
    Western Kentucky
    We planned on going through the whole thing resealing everything. All lights. Every seam. Every thing we can find, or poke with our caulk.
    While on the subject of caulk... @onesojouner said on TS that if we were to use silicone that it would hold for a while, but nothing else would ever stick to it. Here's a direct copy paste from him: "The # rule is do not use any silicone based products on it. It will work for a while but then when you need to reseal nothing will stick to it. Nothing will get it off. Leaks and UV are what kill these things."
    Here's what we ordered yesterday before we knew about the silicone thing... Below is the product info.
    12 Pack Dap 18300 DYNAFLEX 230 Premium Indoor/Outdoor Sealant - White 10.1-oz Cartridge (18275)
    Any and all advice is appreciated, and welcomed. Move forward with this stuff, and commit or find a different product. Thoughts?
    NUDRAT likes this.
  13. Aug 22, 2022 at 11:44 AM
    #2023
    Tundra2
    Noah
    Western Kentucky
  14. Aug 22, 2022 at 11:48 AM
    #2024
    Dynaflex is great for things that don't move. It's great for sealing doors, windows, etc. on stationary homes. I wouldn't use it on anything that flexes a lot, like a mobile home.
    Tundra2[QUOTED][OP] likes this.
  15. Aug 22, 2022 at 12:05 PM
    #2025
    Tundra2
    Noah
    Western Kentucky
    Well... what do you reccomended? I didn't know that about dynaflex...
  16. Aug 22, 2022 at 12:08 PM
    #2026
    I got some stuff from the RV place to repair the roof and seal some windows. The stuff for the roof was the self-leveling caulk. The stuff for the windows looks like regular caulk, but it’s stringy like mozzarella cheese when you try to smooth it. Have to apply it better than I normally do the bathroom stuff. And wear gloves.
  17. Aug 22, 2022 at 12:33 PM
    #2027
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Never used it on a RV but this stuff works very well but it's pricey. We needed it because it was drinking water safe, clearly not a concern for your application though.
    https://www.amazon.com/Sika-Sikaflex-Adhesive-Sealant-Cartridge/dp/B00C50GIQI
    For your use I'd probably lean towards polyurethane.
    https://www.homedepot.com/p/Loctite...dow-Door-and-Siding-Sealant-1675293/203163736
    Tundra2[QUOTED][OP] and shifty` like this.
  18. Aug 22, 2022 at 12:33 PM
    #2028
    I'm a Sika guy. Don't get me wrong, I use Dynaflex and other DAP products all over the house, especially their flexible trim sealer, it's killer. But when it comes to self-leveling sealers, masonry sealers, etc. I'm using Sika. But full dislosure, I've never used any Sika products on moving-walled things, like boats, trailers, etc. I just know from experience you don't want to use big-box-store flexible sealers on anything that sees regular flex and torsion.
    That said, Sika has an interactive page for mobile homes specifically, which links you up with products. Be forewarned, some of their shit is expensive.
    https://industry.sika.com/en/home/transportation/caravan-and-motorhomes.html
    EDIT: I see Fester also posted Sika at the same time as me. Jinx!!
  19. Aug 22, 2022 at 3:56 PM
    #2029
    Here’s the roof stuff I used
  20. Aug 22, 2022 at 4:44 PM
    #2030
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    compare with Progressive.
    You probably want to research towing insurance.
    No one will tow truck & trailer. Towing the truck could be covered, but the trailer will be separate & on your dime. Lots to learn.
  21. Aug 22, 2022 at 4:55 PM
    #2031
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    return it. Absolutely correct, no silicone on anything RV. Well, maybe sink to counter - but that's it.
  22. Aug 22, 2022 at 4:56 PM
    #2032
    NUDRAT
    NUDRAT 6 lug life
    SW CT
  23. Aug 22, 2022 at 5:01 PM
    #2033
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    e-trailer has often been a good source for me.
    Obviously repack wheel bearings.
    You can't send the woman to the trailer to make dinner while you're driving. ;-)
  24. Aug 22, 2022 at 5:39 PM
    #2034
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Don't cover the trailer with a plastic tarp for the winter - traps moisture, becomes a sweatbox, wood rots....
    Real proper RV cover or no cover.
    Learn how to winterize the water system.
    Double check the water heater when winterizing.
    YouTube is your friend.
    prop fridge, freezer, bathroom doors open for winter.
    NO food, no 'mouse' food left in over the winter. They will come. Make it uninviting.
    Check it at least 1x/week (okay reality is 1x/month) over the winter. Look for leaks, mice, vagrants.
    Some people say leave a radio turned on in it all winter. I dunno. Doubt mice are scared of a radio.
    Hah! You need a mouse jiggler for the RV. Someone invent that!
  25. Aug 22, 2022 at 5:41 PM
    #2035
    Tundra2[OP] and NUDRAT like this.
  26. Aug 22, 2022 at 5:53 PM
    #2036
    Looks to be right. This stuff is for the roof only as it stays liquidy for a while and flattens out to fill like floor leveler. No good on the sides as it doesn’t firm up and adhere in time. I used this on my last camper and used it to patch a bad factory seal on one of the vents on my current camper. When the time comes to freshen the seals up, I’m going all eternabond.
    Tundra2[OP] and shifty`[QUOTED] like this.
  27. Aug 22, 2022 at 6:44 PM
    #2037
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Page 69 for ol crack-thread
    Noah I found an ad on craylist, dude got rid of a trailer and had this kit he was giving away. Ive emailed the asshole 4 times over the last 2 days and still no response from him. The ad was only posted 2 days ago and is still up. Anyways, I'm tryin to hook you up, if he gets back to me, I'll grab it and you cover shipping. It's still in the box and includes the sway kit. Why would someone post some shit and not respond? I don't get that
    Tundra2[OP] and KNABORES like this.
  28. Aug 22, 2022 at 6:47 PM
    #2038
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
  29. Aug 22, 2022 at 6:49 PM
    #2039
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
  30. Aug 22, 2022 at 7:01 PM
    #2040
    Had that same setup on my first camper. Worked pretty good. And at free.99 the price is right. The trailer part installs easy, just lay it on the rail and tighten the set bolt. The setup for the truck mounted hitch part is a little time consuming, but once it’s dialed in you’re good to go.
