Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Aug 16, 2022 at 5:41 AM
    #1981
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Yesterday, I drove home dry. All 12 miles of it from the alignment shop. Couldn't get the drain plug off, but did get the fill plug off. Ran a hose from the top of the engine to the fill plug. Had dad pour in the gear oil. Lucas 75W-90 synthetic.
    Had very small glitters come out the Overflow. Haven't driven since buttoning everything up. Feeling good about it. Truck drives straight after alignment, and brakes feel great brake fluid flush.
    Started to round the drain plug and stopped. Any tips on how to get it out short of welding a bolt to it? I tried to shock the threads with a BFH. No go.
    des2mtn[QUOTED] and FrenchToasty like this.
  2. Aug 16, 2022 at 5:44 AM
    #1982
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Did all the fluid come out when you pulled axles?
    You could try some heat, then spray with penetrant fluid, a few cycles of that and then a wack with Mr BFH
  3. Aug 16, 2022 at 5:51 AM
    #1983
    des2mtn
    des2mtn Barf me out, gag me with a spoon!
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Yeah, after having trouble with mine I knew you would have trouble too since your rust situation is/ was a bit worse.
    Empty gave this advice to me awhile back. Could also try welding a nut onto the drain plug.
  4. Aug 16, 2022 at 6:02 AM
    #1984
    shifty` Do some sister twisters 'til the cows come home
    This could be a good time for an inexpensive toolbox add, assuming you don't have one of these already.
    If it were me, I'd take a Dremel or similar to grind a notch in the head. Then go for a drive to warm it up, park, take a manual impact driver (like this) with a flathead installed, insert into your new slot, then BFH it.
    If you wanted to go overboard, you could try hitting it with PBB or Kroil while hot, or use a torch to create heat, then cool off with the spray. Anything to cause heat/cold expansion and contraction may pop it free.
    I know you're religious with the anti-seize and you'll apply it after.
    Glad to hear nothing is clearly toast, but obviously drain-and-fill to clear debris out after, and cross your fingers there's no chunks.
  5. Aug 16, 2022 at 6:31 AM
    #1985
    Tundra2
    Noah
    Western Kentucky
    I actually already have one! I just straight up forgot about it. I'll give that a try after a few drives.
    des2mtn likes this.
  6. Aug 16, 2022 at 7:08 AM
    #1986
    Just don't go nuts on it. Last thing you want to do is crack your case repeatedly hammering it. i.e. best bet may be a lighter weight 1lb stubby ball peen vs. 3lb+ hand sledge.
    I assume that's a steel plug in an alloy housing. That's the unfortunate part about alloy and steel, they tend to chemically bond into each other with time. I'm struggling with that issue right now, just learned I may lose a sale that would otherwise dump $hundreds into my truck slush. While packing, we found an alloy part (stem) firmly seated inside a steel tube. If it won't come free with some finessing in the next hour or three, I doubt the buyer'll want it anymore, and I lose the sale. Or, if he does still want it, I'd need to knock $100 off, plus pay +$60 extra on shipping and another +$60 to the guy i've got freighting it out, and I'm making, like, $50 profit out of it.
    Tundra2[QUOTED][OP] likes this.
  7. Aug 16, 2022 at 7:25 AM
    #1987
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I wonder if the trick recommended for stuck spark plugs would work here too. Try to tighten it a hair, then try to loosen. Basically try to move it back and forth. Gentle of course. Don't mangle it like I would.:anonymous:
    Heat and penetrant sounds good too. :welder:
    bmf4069 and Tundra2[OP] like this.
  8. Aug 16, 2022 at 7:29 AM
    #1988
    Tundra2
    Noah
    Western Kentucky
    Worst case scenario... I drop the truck off with Bruce once my new plugs come in. I'm sure he could weld a nut on that plug no problem. I just don't have a welder... lol
    bmf4069 and shifty` like this.
  9. Aug 17, 2022 at 5:30 AM
    #1989
    Tundra2
    Noah
    Western Kentucky
    Gave an over on the other place. Quick synopsis of everything that'd already here.
  10. Aug 17, 2022 at 5:35 AM
    #1990
    WOMP WOMP.
    Login required. Meh. (But I guess I already read everything here)
    NUDRAT and Tundra2[QUOTED][OP] like this.
  11. Aug 17, 2022 at 6:42 AM
    #1991
    Tundra2
    Noah
    Western Kentucky
    You read the detailed version here. Much less detail there.
    shifty`[QUOTED] likes this.
  12. Aug 19, 2022 at 3:20 PM
    #1992
    Brynden29
    Brynden29 Just a guy who works on cars
    Brynden
    Bellville, TX
    1999 Mustang GT
    I have it off:
    Do you need the screws too?
  13. Aug 20, 2022 at 7:05 PM
    #1993
    Tundra2
    Noah
    Western Kentucky
    Yeah, send em. I'll PM you.
    RUSTYNUTS and FrenchToasty like this.
  14. Aug 20, 2022 at 7:08 PM
    #1994
    Hell yeah, makin' the magic happen right here!
  15. Aug 20, 2022 at 7:17 PM
    #1995
    Tundra2
    Noah
    Western Kentucky
    No, this is making the Magic happen.
    Here's a pic of the rear bump stops at this gas station.
    Happy to report that 4HI, and 4LO both work as normal with no ill effects. Still need to flush the front diff out, but a challenge for another day.
    1988 Jayco 2450 travel camper. 3920 lbs. Truck did great the 240 miles home. Averaged 8MPG while towing.
  16. Aug 20, 2022 at 7:21 PM
    #1996
    FTFY bud
    And that's in fantastic shape for an '88. You can literally go anywhere, live anywhere, do anything in that mf!
  17. Aug 20, 2022 at 7:43 PM
    #1997
    Tundra2
    Noah
    Western Kentucky
    That's the idea!! More pics tomorrow. Picked it up for $5,300. Needs a little bit of work, but it's 95% just paint...
    Clean title. We are the 4th owners.
    I do need to figure out these electric brakes. From the factory, these came with a round 7 pin harness. This one has a 4 pin flat...
  18. Aug 20, 2022 at 8:02 PM
    #1998
    Azblue
    The Dirty T ( ^_^)_且
    If the trailer has a 4 pin, then the brakes don't work. You really, really need those to work. Also, get a weight distributing hitch.
    https://www.etrailer.com/question-415564.html#:~:text=The 4 flat connector doesn,t work well at all.
  19. Aug 20, 2022 at 8:26 PM
    #1999
    Tundra2
    Noah
    Western Kentucky
    RUSTYNUTS and Azblue[QUOTED] like this.
  20. Aug 20, 2022 at 8:30 PM
    #2000
    Azblue
    By the time you load anything (propane, water, food, clothes, etc) you will be near 5,000 lbs or more. Even on a larger 2 or 2.5 Gen that's when it's pretty much a requirement. Also, it handles much, much better, more stable, less sway. Believe me, it's a no-brainer once you tow with one.
  21. Aug 20, 2022 at 8:43 PM
    #2001
    Azblue
    The WDH will distribute the weight more evenly, back to the trailer and also back to the front axle of the truck. Obviously, having weight back on the front steer axle greatly improves stability and reduces some of the sag. Plus, most also have anti-sway, which is safer and reduces those white knuckle moments. Here is a pic of my set-up (trailer max is 7,000 lbs), you can see the truck is level.
    And, yes, I know you're a 1st Gen guy, so mandatory pic of my 2000 that I owned for 20 yearsTrailer1.jpg 2000 Tundra.jpg
    bmf4069, NUDRAT, shifty` and 3 others like this.
  22. Aug 20, 2022 at 8:53 PM
    #2002
    FrenchToasty
    Mo
    Bone stock
    That salsa AC is a beauty!
  23. Aug 20, 2022 at 8:55 PM
    #2003
    Tundra2
    Noah
    Western Kentucky
    Alright, alright. I understand now. Safer, easier, more balanced.
    Y'all got any brands that are good? Reccomendations?
    I saw some Curts on Scamazon, and a few other brands. Camco, weigh safe, equalizer, etc
  24. Aug 20, 2022 at 8:57 PM
    #2004
    Azblue
    Best truck ever. That truck went from hauling my son around as a kid in the AC cab, to being his first vehicle at 16, to me shipping it to D.C. so he would have something to drive while he was in the Navy.
  25. Aug 20, 2022 at 8:59 PM
    #2005
    FrenchToasty
    Mo
    Bone stock
    Hell yes!
    Tundra2[OP] and Azblue[QUOTED] like this.
  26. Aug 20, 2022 at 8:59 PM
    #2006
    Azblue
    This is what I have. They work well.
    https://www.equalizerhitch.com/store/
  27. Aug 21, 2022 at 4:45 AM
    #2007
    des2mtn
    Shady Grove
    Tonto cover
    You bringing this bad boy to T2S next year?
  28. Aug 21, 2022 at 6:11 AM
    #2008
    I run an equalizer, which I love, but even the Harbor Freight is a serviceable unit. Properly installed and adjusted is more important than brand.
  29. Aug 21, 2022 at 7:36 AM
    #2009
    Wait ... is there clear sign someone modified it down the road? 3 owners, I'm sure it got tweaked here or there. Just curious.
    How does insurance work on something like that?
    Neighbor across the street has damn good taste.
  30. Aug 21, 2022 at 9:00 AM
    #2010
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've only got experience with one trailer with brakes and if it's anything like that one instead of chasing electrical issues just buy a whole new brake kit and replace the wiring since you have no idea what the condition of either are.
