Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Oct 5, 2021 at 7:36 AM
    #1021
    Yeah, it's pretty gnarly how much you're still working stuff out of the coolant system, the Liqui-moly coolant flush stuff may be advised for more flushing on coolant side - I've personally never used the stuff before, only the Prestone AS105 stuff that's pretty mild, but works. The water you're showing above is about 10 shades darker brown than I'd prefer to see before swapping in proper coolant. I'm happy to see stuff is still coming up though, it's a good sign, it means progress hasn't stopped.
    How much idling you think you had in it up to this point to get the color in the gallon jugs above? Just so you have a means to gauge?
    Tundra2[QUOTED][OP] likes this.
  2. Oct 5, 2021 at 7:43 AM
    #1022
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    I'm happy for any positive progress, or even lateral progress as long as I learn something. Below is the last drain on the V6 I did before adding zerex. 150 miles on that water. It didn't have anywhere near the level of gnar gnar this one does.
    V8 1st drain.
    So far, I haven't used any of my flush/cleaner products. Just been straight distilled water. Will add some of that blue devil stuff tomorrow since those jugs are in my way, and then can toss them!
  3. Oct 5, 2021 at 7:45 AM
    #1023
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Sorry for the long delay. Very busy day & night. If you're going to wrench on motors a mechanical gauge is an indispensable tool to have around. Post up your oil pressure results.
  4. Oct 5, 2021 at 7:46 AM
    #1024
    Tundra2
    Noah
    Western Kentucky
    No worries! I'll snatch that one up along with a leak down test kit. Any other recommendations are welcome.
  5. Oct 5, 2021 at 7:46 AM
    #1025
    I'd recommend saving a small sample of each as you go so we can get a gratifying spectrum at the end of this!
    I think in ChrisFix's flush it took him like 4 rounds to get to your V6 flush color from the current V8 color. By round 6 he was close to clear.
    Tundra2[OP] likes this.
  6. Oct 5, 2021 at 7:50 AM
    #1026
    Tundra2
    Noah
    Western Kentucky
    Well, I guess I need something better than tupperware, eh? Lol round 4 was where I was on the V6. Would have kept going to clear, but didn't trust the water on the interstate rolling to Knoxville. That wasn't a fun thought so I dumped some coolant in it, and burped.
    Hopefully, I'll have enough time to get to clear, and then dl the heater core. Main concern being the engine right now.
    Other news: Wheelers offroad brake lines have shipped! Parts are piling up for Toyota.
    shifty`[QUOTED] likes this.
  7. Oct 5, 2021 at 8:07 AM
    #1027
    Desert Dog
    My apologies again @Tundra2, per the FSM for your MY the oil pressure at idle is to be 4.3 psi or more. @ 3,000 rpm it is to be between 43-85 psi.
  8. Oct 5, 2021 at 8:08 AM
    #1028
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    HOLY POSTS BATMAN!
    I'm loving my Eibach pro-trucks with OME 2885 coils. The Eibach rear shocks are nice because they're slightly longer than the 5100s, so they allow for a 2" rear lift, which is why I went for them.
    double check, but it sure looks like I spy a pretty new looking 5100 already installed on your truck there. Looks like it's set on one of the highest settings, so that would explain the lumberjack ride quality.
  9. Oct 5, 2021 at 3:24 PM
    #1029
    Tundra2
    Noah
    Western Kentucky
    Do Bilsteins have a date code to figure out how old that one is? I agree it's pretty new-ish looking.
  10. Oct 5, 2021 at 7:04 PM
    #1030
    Tundra2
    Noah
    Western Kentucky
    Any reason to replace the four semi-circle plugs on the back of the Valve covers? Trying to plan into the next project. Seems like the FSM calls for reuse after cleaning the old ones. I ordered new ones for the V6, but haven't had the time to do the VCs...
  11. Oct 6, 2021 at 3:42 AM
    #1031
    Tundra2
    Noah
    Western Kentucky
    Thinking of adding magnetic drain plugs to the oil pan. $30 seems high. Anyone got anything cheaper?
    Flea-bay link
    Transmission Pan sane thread pitch as oil pan?
  12. Oct 6, 2021 at 7:13 AM
    #1032
    Why not just get a rare earth magnet and stick on the head of the drain plug bolt? $1 solution. You could also use magnets to magnetize the stock bolt, but they make rare earth magnets so small these days, I can't help but wonder if it's bad to just slap one on the head of the bolt.
    Tundra2[OP] and dbittle like this.
  13. Oct 7, 2021 at 5:34 AM
    #1033
    Tundra2
    Noah
    Western Kentucky
    Drained about three gallons of less nasty water from the block. Both engine drains stopped, and then I cracked the bottom of the rad. I knew I still had water in it, so I crawled back under and fully removed both brass drain plugs. Very little fluid from the passengers side, and a torrent from the drivers side. Strange that it all but stopped from the actual drains. Slightly concerned.
    Didn't take pics of the drain, but it's still nasty. Did take a shot of some boogerwelded pipes!
    Also, found out why the exhaust leaks on the passengers side.
    Also found that the power steering pump is rubbing on the lower radiator hose. Guess this engine really is moving because I knew for a fact that it wasn't rubbing when I put it on. May have it installed upside down... guess I'll order another one with my plugs from RA.
    1794TX likes this.
  14. Oct 7, 2021 at 5:40 AM
    #1034
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Gotta keep your hose trimmed.
  15. Oct 7, 2021 at 5:41 AM
    #1035
    Tundra2
    Noah
    Western Kentucky
    I did trim it! Or the doctor did for me...
    bmf4069 likes this.
  16. Oct 7, 2021 at 5:44 AM
    #1036
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Ive got about 1/2”.
  17. Oct 7, 2021 at 6:14 AM
    #1037
    Tundra2
    Noah
    Western Kentucky
    I had about a half inch when I put it on. Possible that the heat made it swell some I spose
  18. Oct 7, 2021 at 6:18 AM
    #1038
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Maybe twist the top of the hose a bit to tweak the middle of the hose forward?
  19. Oct 7, 2021 at 8:03 AM
    #1039
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Maybe take another 1" off the bottom of the hose.
  20. Oct 7, 2021 at 9:50 PM
    #1040
    Tundra2
    Noah
    Western Kentucky
    Took the exhaust bolt from the post above to work to get a nut, and washer goodies. Had some free time so I cleaned it up using special T2 formulers
    Light wipe down with very small amount of anti-sieze.
    bmf4069 likes this.
  21. Oct 7, 2021 at 9:51 PM
    #1041
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    What would you charge me to clean all my nuts? And bolts?
    bmf4069 and Tundra2[OP] like this.
  22. Oct 7, 2021 at 10:15 PM
    #1042
    Tundra2
    Noah
    Western Kentucky
    You like the way I play with nuts, and bolts eh? :)
    bmf4069 likes this.
  23. Oct 7, 2021 at 10:21 PM
    #1043
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    They look better when you get done with em.
    i like the results i get with the ?phospor? Rust treatment. I havent tried adding any dye yet.
  24. Oct 7, 2021 at 10:26 PM
    #1044
    Tundra2
    Noah
    Western Kentucky
    Just a little bit of scrubbing compound, elbow grease, and a stainless steel brush. Not sure you can buy this product as a consumer.
    Sirfive[QUOTED] likes this.
  25. Oct 7, 2021 at 10:43 PM
    #1045
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I do prefer to handbrush the n’s&b’s. I tell myself that im not rounding corners or edges.
  26. Oct 7, 2021 at 10:46 PM
    #1046
    Tundra2
    Noah
    Western Kentucky
    Hand brushing is the key! If I were retired, or had the kind of time that PHM did, I'd be dangerous!
  27. Oct 8, 2021 at 4:14 AM
    #1047
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I may have missed it while we were on the island. Are you still waiting on parts or is the timing belt job done?
  28. Oct 8, 2021 at 4:57 AM
    #1048
    Tundra2
    Noah
    Western Kentucky
    TB is done. Doing engine flushes in thus time slot. I'm not officially writing the TB as dine until I have toyota coolant in it.
    FirstGenVol[QUOTED] likes this.
  29. Oct 8, 2021 at 5:55 AM
    #1049
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    speaking of nuts, did you ever find a home for that extra one ?
  30. Oct 8, 2021 at 6:24 AM
    #1050
    Tundra2
    Noah
    Western Kentucky
    No, sure didn't.
