Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Sep 28, 2021 at 8:17 AM
    #841
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm curious of what the block passages look like too. Like a 500b man's arteries?
    Darkness, Tundra2[OP] and shifty` like this.
  2. Sep 28, 2021 at 8:31 AM
    #842
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    you can sleep later @Tundra2
    Darkness, Desert Dog and Tundra2[OP] like this.
  3. Sep 28, 2021 at 2:39 PM
    #843
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I found you an oil cooler! Picking it up tomorrow morning. When I'm there I'll try and grab other connectors. It's not a pick and pull yard so they will have to grab it for me.
    NUDRAT, Darkness, shifty` and 2 others like this.
  4. Sep 28, 2021 at 2:47 PM
    #844
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Darkness and BubbaW[QUOTED] like this.
  5. Sep 28, 2021 at 2:47 PM
    #845
    Tundra2
    Noah
    Western Kentucky
    NUDRAT likes this.
  6. Sep 28, 2021 at 3:41 PM
    #846
    Tundra2
    Noah
    Western Kentucky
    Damn near thirty pages! If you've lurked this long...
    NUDRAT, TundraGirl2, Darkness and 3 others like this.
  7. Sep 28, 2021 at 5:28 PM
    #847
    Hell yeah, man!
    dbittle, daveeasa and Tundra2[OP] like this.
  8. Sep 28, 2021 at 7:23 PM
    #848
    Tundra2
    Noah
    Western Kentucky
    Throttle body by pass hose from RA should be here Saturday. Thanks again to @w666 for posting that link.
    All three engine bay clips are on order at McGeorge, and order is "in process." I expect it to take at least a week before they arrive at their facility to be sent out to me. Similar to the camshaft sensor, or until @rock climber comes through on clips, and the oil cooler.
    Not much more that I can do until I have those parts so I think I will rest after work today. I feel like shit.
    bmf4069 likes this.
  9. Sep 28, 2021 at 9:05 PM
    #849
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You've been busy, I think you can chill for a minute.
    NUDRAT and Tundra2[QUOTED][OP] like this.
  10. Sep 28, 2021 at 10:23 PM
    #850
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Drain it when it's time for the coolant. Leave the distilled water for now.
  11. Sep 28, 2021 at 10:27 PM
    #851
    Tundra2
    Noah
    Western Kentucky
    I'll try to remember to get your core measurements today since I'll be taking it easy when I get home.
    Glad to see that my gut instinct was right about leaving the distilled.
  12. Sep 28, 2021 at 11:04 PM
    #852
    Tundra2
    Noah
    Western Kentucky
    Is there anything else I haven't touched, that needs to be done excluding an oil change?
    Can you all think of anything?
  13. Sep 28, 2021 at 11:06 PM
    #853
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Not sure if you just mean in general or just involving engine related stuff but axle and transfer case juice replacement. Probably a drain and fill on the trans.
  14. Sep 28, 2021 at 11:09 PM
    #854
    Tundra2
    Noah
    Western Kentucky
    Engine stuff mainly. Trying to close that chapter as best I can.
  15. Sep 28, 2021 at 11:12 PM
    #855
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I didnt see sparkplugs in the directory.
    Compression test?
    Tundra2[OP] likes this.
  16. Sep 28, 2021 at 11:22 PM
    #856
    Tundra2
    Noah
    Western Kentucky
    Spark plugs is a good idea. I favor NGK brand unless otherwise recommended for the V8.
    Guess I'll read up on a compression test. Heard of it. Never done it.
  17. Sep 28, 2021 at 11:26 PM
    #857
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Cleaning injectors is always fun, too. Not sure what voltages 2uz injectors run at, but i used a 9v battery to trigger my jeep injectors while squeezing a water bottle of injector cleaner through em.
    Tundra2[OP] and bmf4069 like this.
  18. Sep 28, 2021 at 11:33 PM
    #858
    Tundra2
    Noah
    Western Kentucky
    I'll probably replace those with @dirtydeeds at some point off in the future. Probably need to investigate exhaust at some point too. Pretty much every system is compromised in some fashion. LOL
    Also, just found these NGKs on RA. WTF
    More Information for NGK 94279 (rockauto.com)
    Darkness likes this.
  19. Sep 28, 2021 at 11:34 PM
    #859
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I run ruthenium’s on the 1998 truck… they work better with boost. Just get iridiums for the v8
    Tundra2[QUOTED][OP] likes this.
  20. Sep 28, 2021 at 11:35 PM
    #860
    Tundra2
    Noah
    Western Kentucky
    Never heard of a ruthenium critter. I'll go back to the plug list.
  21. Sep 28, 2021 at 11:38 PM
    #861
    Tundra2
    Noah
    Western Kentucky
  22. Sep 28, 2021 at 11:39 PM
    #862
    empty_lord
    05 rollover special
    Those work. I run the factory plugs on my truck… I think they’re iridium.
  23. Sep 28, 2021 at 11:40 PM
    #863
    Tundra2
    Noah
    Western Kentucky
    I like a "Fire, and forget" plug (with notes to check at XXX,XXX mileage.) No need to swap plugs every oil change IMO.
    NUDRAT likes this.
  24. Sep 28, 2021 at 11:43 PM
    #864
    empty_lord
    05 rollover special
    i run iridiums for 100k.
    i've had copper plugs come in at work with 200k too.. i mean.. most plugs last WAY longer than spec'd these days
    Darkness and Tundra2[QUOTED][OP] like this.
  25. Sep 28, 2021 at 11:44 PM
    #865
    Tundra2
    Noah
    Western Kentucky
  26. Sep 28, 2021 at 11:45 PM
    #866
    empty_lord
    05 rollover special
  27. Sep 28, 2021 at 11:52 PM
    #867
    Tundra2
    Noah
    Western Kentucky
    Oh, I never knew this. Guess I should have.
  28. Sep 29, 2021 at 1:12 AM
    #868
    NickB_01TRD
    Nick
    KY
    For the older 1st gens it calls for copper from factory. Denso K20RU if I remember right. That's supposed to be a 30k plug. That's what I ran in mine since I don't drive it a whole awful lot. Figure it's good to pull the plugs out every so often to keep from anything getting seized.
    FirstGenVol and Tundra2[OP] like this.
  29. Sep 29, 2021 at 4:45 AM
    #869
    Tundra2
    Noah
    Western Kentucky
    @assassin10000
    Did a quick hack job with the Sawzall.
    Obviously, the fan has hit the radiator, but how does this happen, and how can I prevent it? I genuinely do not understand. This is a light touch looks like. Now of the water channels were ruptured. Just folded ever so slightly.
    All three pictures below are from the bottom of the radiator.
    That's it for today. I'm wore out, and my toes are swollen. Night!
  30. Sep 29, 2021 at 4:56 AM
    #870
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    VC gaskets and plug well seals. Intake manifold gasket.
