Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Sep 26, 2021 at 9:01 AM
    #751
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Just a hook up. From the oil cooler to the block. All that fluid I mentioned earlier came from there. Hence the drizzle...
  2. Sep 26, 2021 at 9:03 AM
    #752
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Just get as much out as you can with a hose like the methods in those videos.
    Tundra2[QUOTED][OP] likes this.
  3. Sep 26, 2021 at 9:35 AM
    #753
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Wasn't he about to go on a trip with the wife? I kinda thought I remember reading that.
    Tundra2[OP] and FrenchToasty like this.
  4. Sep 26, 2021 at 9:44 AM
    #754
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Yeah like a 2k+ mile trip?
    Tundra2[OP] likes this.
  5. Sep 26, 2021 at 10:12 AM
    #755
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    He said that was in 3 weeks. Keep tagging him!!!
  6. Sep 26, 2021 at 10:16 AM
    #756
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Damn, catching up on this thread is better than anything on TV right now! You should name your truck Forrest Gump, I believe his mamma said "Buying a Crackhead Tundra is like a box of chocolates" or something like that! :rofl: Seriously though, great job/effort so far on the challenge that this truck has been.
    bmf4069, N84434, NUDRAT and 2 others like this.
  7. Sep 26, 2021 at 10:29 AM
    #757
    Tundra2
    Noah
    Western Kentucky
    Thanks. I got up about this time yesterday. Feeling a bit like a crack head, but two days off after 14 on doesn't leave a whole lot of time for this.
    Ran to town...
    bmf4069, N84434, NUDRAT and 1 other person like this.
  8. Sep 26, 2021 at 1:41 PM
    #758
    NOOOOOOOoooooOOOOoooo don't remove the valve cover! One thing at a time :D Last thing you need is another surprise. Save it for another day :D
    I'm starting to wonder if crackie had a bong that used he cooling system of the truck as a res. This is absolutely F'ing nuts, the truck is going to operate so much better once done it won't know how to act :D
    But for real, it looks like the lines are packed full of fish roe, and I concur, that makes me think someone mixed yellow and orange coolant together. This procedure may help either way, read this GM TSB, as poorly formatted as it is. It gives some flush directions.
    https://www.speed-talk.com/forum/viewtopic.php?p=424862&sid=ed2d74cd681bfe57d805cc42bfb2b6f5#p424862
    But before doing that, I'd start with rinsing/flushing with water at low PSI through the system, through various ports. Obviously you can't pull everything apart. There's bound to be a way to tackle this logically, given how many water drain/routing ports you've already exposed.
    Once it's back together and running, then you may want to follow the above TSB procedure, with products mentioned. One of those you may already have on-hand, IIRC.
  9. Sep 26, 2021 at 5:17 PM
    #759
    Tundra2
    Noah
    Western Kentucky
    One project at a time. Will probably do valve covers the same day I do plugs, and ignition coils. Some are still OEM Toyota coils, some are no name aftermarket, and some are denso. Strange.
    Maybe this is all cow shit, and I'm going to die a very painful, toxic, ass death. Still need to track down another connector that's broken.... more shittake
  10. Sep 26, 2021 at 5:22 PM
    #760
    Most in-depth shit you've seen enema-illion years.
    bmf4069 and Tundra2[QUOTED][OP] like this.
  11. Sep 26, 2021 at 5:38 PM
    #761
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    With the state of the rest of the truck I can't even imagine what kind of condition the plugs themselves are in.
    If only pull a part wasn't so far away. Pretty sure Camry's and other toyotas use that connector. Hell auto parts store might even carry one you can use.
  12. Sep 26, 2021 at 5:57 PM
    #762
    Hey Junior, do me a favor, just for S&G.
    If you still have the content from that one hose you biopsied, take a good helping of it, like a few tablespoons worth, and stir it up with water in a mayo jar.
    Just want to see if it mixes with the water, and make sure no oil solids float up to the top.
    It's so yellow in color, I'm assuming someone just added the wrong coolant once, else it would look more like a dark roux (found the Cajun!) or rusty mudbutt sauce.
  13. Sep 26, 2021 at 8:31 PM
    #763
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    This is a great thread so far. Should be interesting to see how this thing ends up...:thumbsup:
    Tundra2[OP] and Desert Dog like this.
  14. Sep 26, 2021 at 8:54 PM
    #764
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Glad to see you're getting the throttle-body cleaned up well and resolving a lot of the neglect now.
    When you said the TB had that goo in it I was under the impression you meant that it was also in the air & fuel ports as well and I was thinking "How in the world...?" Haha! Then you posted the images and that cleared that mystery up.
    Something to consider for the electrical connectors: apply some electrical grease inside them. This will seal them from moisture and dirt, etc., and allow much easier removal without damage in the future.
    Keep up the good work. I think we're all rooting for you.
  15. Sep 27, 2021 at 2:11 AM
    #765
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    But at least it leaves you enough cash to pay for it all...
  16. Sep 27, 2021 at 4:49 AM
    #766
    Tundra2
    Noah
    Western Kentucky
    I'm not sure I have anymore of it, but I'll look around in my trash bag. This is a good idea, and wished I'd thought of it when I had my large sample. Lol Thank you for bringing it up.
    Thank you much. I look to your thread for much advice, and glad that I can provide "adequate" reading material. :rofl:
    I have some electrical grease on order as my little tubes are spent. Still need to track down another connector. Probably should really use a computer to search for it. Small screen on the phone ain't where it's at. Lol
    Thanks for the bold.
    Very true here. Keeps me busy 110% of the time.
    N84434[QUOTED] likes this.
  17. Sep 27, 2021 at 4:51 AM
    #767
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Damn. That's as bad as when I pulled some hoses on my 92 SHO. How does shit get that bad? Well, mine sat for 10 years, so there's that. This one never sat though, did it?
  18. Sep 27, 2021 at 4:54 AM
    #768
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I recommend a tablet on your cell plan. It comes in handy when not around wifi. It's how I keep up with all you heathens while at work.
  19. Sep 27, 2021 at 4:55 AM
    #769
    Tundra2
    Noah
    Western Kentucky
    I have no idea how long it really sat, if it did at all. It came from a farm, and then sold to the guy I bought it from. Shit like this is why I rotate through my vehicles. Drive the Silver one once every two weeks.
  20. Sep 27, 2021 at 4:56 AM
    #770
    Tundra2
    Noah
    Western Kentucky
    I have a tablet, but it's not on the cell plan. I honestly forget about it....
  21. Sep 27, 2021 at 4:57 AM
    #771
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I gotcha. Hot spot the phone and leech off it for the tablet?
  22. Sep 27, 2021 at 5:00 AM
    #772
    Tundra2
    Noah
    Western Kentucky
    :yes:
    There it is! Only really works if my phone isn't half dead. I think the last update gave my phone cancer. Battery cancer too. Planned obsolescence...
    NUDRAT and bmf4069[QUOTED] like this.
  23. Sep 27, 2021 at 5:03 AM
    #773
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I wouldn't doubt it. If you hot spot it, plug it in. It'll kill your battery quickern shit.
  24. Sep 27, 2021 at 5:09 AM
    #774
    Tundra2
    Noah
    Western Kentucky
    Yes, I know. I used to use my Hotspot at work when I was going to lunch with all the guys.
    I have unlimited data. Another guy had that Motorola phone with swappable accessories. He brought in the projector attachment once, and I brought in the bluetooth speaker. We used to watch movies outside. Until the Karens got involved, and we all got written up for watching movies when we were CLOCKED OUT, and on our own personal time.
  25. Sep 27, 2021 at 5:34 AM
    #775
    Tundra2
    Noah
    Western Kentucky
    Pops bought this at a discount store :rofl:
    I have a left, and a right :drevil:
    NUDRAT and bmf4069 like this.
  26. Sep 27, 2021 at 5:56 AM
    #776
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Stick it on the Virus.
    bmf4069 likes this.
  27. Sep 27, 2021 at 6:44 AM
    #777
    Tundra2
    Noah
    Western Kentucky
    Ooh yeessss
  28. Sep 27, 2021 at 6:47 AM
    #778
    Tundra2
    Noah
    Western Kentucky
    Made some sampler sippin cups. Looks like two distinct colors, and seperated accordingly. @shifty`
    Now we wait for sedimentation to take place.
    bmf4069 and shifty` like this.
  29. Sep 27, 2021 at 7:07 AM
    #779
    I was coming back here to mention that. If there's oil in it, you may make an emulsion when you stir, then need to wait for separation. I'll be interested to see how this pans out. If you don't stir too vigorously, you may have a good result within an hour or two. Else you may be waiting a day. Either way, it should be really clear if it's layering, although a transparent glass jar makes it easier to see a thin oil slick than translucent tupperware. :D
    I'm suspicious about the more rust-colored, that could suggest oil leaking into coolant, I'm sure we all know how/why and don't want to think about that possibility. Say the PO knew there was a leak and added a 'stop leak' product into either water/oil side (or both!) and it passed between the two... this is what I'd expect to see, coagulated oil in coolant. However, the yellow-colored, I just don't know ... possible incompatible coolant mixing there? Weird they were in the same line....
    Clearly, you pulled oil filter and drained the oil. I take it there was no froth or condensate in the oil drain? Could be maybe comforting to know if seepage is happening oil>water or water>oil.
    PS - fingers crossed!!
  30. Sep 27, 2021 at 7:18 AM
    #780
    Tundra2
    Noah
    Western Kentucky
    I gave each a light stir with a pencil. About 30 minutes since the stir on these pics below. None of my shot glasses are clear, and wouldn't be able to see through them anyways... why I used tupperware. Didn't have enough of a sample for big jar as I already threw most of the chunky out...
    Finger dip on the surface tension here just feels like dirty water on both samples. Feeling pretty good about no mixing of oil/water.
    New line in place from the block nipple to the oil cooler nipple once I have a new oil cooler.
    Regarding the oil, I only pulled the filter. Looked, smelt, tasted, and felt like straight oil.
    Also, something I forgot to mention like two weeks ago. When I pulled the transmission lines off the old radiator, the fluid that came out was bright red, and felt exactly like what I put in my V6 transmission. Will by pass the transmission warmer on the new Rad when I get ready to install unless the 4WD transmission has a different cooling loop than my A340E in the V6. (4WD is A340F?)
    shifty`[QUOTED] likes this.
