Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Sep 26, 2021 at 12:03 AM
    #691
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You don’t run the engine doing this. It’s purely engine cold and off. That’s why both upper and lower hoses need to be off
  2. Sep 26, 2021 at 12:05 AM
    #692
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Oh, gotcha. I have ZERO air compressors or anything with pressure, and the garden hose out here in the country doesn't have that much pressure.
    What's your thoughts on having a shop do a power flush on the coolant system? I don't have the equipment for this, and don't have the space for an air compressor currently...
  3. Sep 26, 2021 at 12:07 AM
    #693
    empty_lord
    05 rollover special
    ask around. personally i wouldnt put it together yet and run that radiator or anything new because you'll likely clog them to the point of them not being easily reused.
    you may be able to rent a gas powered air compressor though. thats a thing.
  4. Sep 26, 2021 at 12:08 AM
    #694
    empty_lord
    05 rollover special
  5. Sep 26, 2021 at 12:09 AM
    #695
    Tundra2
    Noah
    Western Kentucky
    Well shit. @TundraGirl2 says they have an air compressor I can borrow, but that doesn't solve the water pressure problem, or does it?
  6. Sep 26, 2021 at 12:09 AM
    #696
    empty_lord
    05 rollover special
    the water pressure should be fine. its volume you want. the air compressor handles the pressure.
    Tundra2[QUOTED][OP] likes this.
  7. Sep 26, 2021 at 12:10 AM
    #697
    empty_lord
    05 rollover special
  8. Sep 26, 2021 at 12:10 AM
    #698
    Tundra2
    Noah
    Western Kentucky
    Okay. I can do this myself then
  9. Sep 26, 2021 at 12:12 AM
    #699
    Tundra2
    Noah
    Western Kentucky
    Thanks for posting the link to that. Looks simple enough.
    Any ideas for a strainer type thing to see how much shit I get out of it?
  10. Sep 26, 2021 at 12:12 AM
    #700
    empty_lord
    05 rollover special
  11. Sep 26, 2021 at 12:12 AM
    #701
    empty_lord
    05 rollover special
    just use a bucket to catch it all.
  12. Sep 26, 2021 at 12:13 AM
    #702
    empty_lord
    05 rollover special
    you'll want a regulator.. not a good idea putting 110 psi to the cooling system.. 20 psi is what i've used
  13. Sep 26, 2021 at 12:13 AM
    #703
    Tundra2
    Noah
    Western Kentucky
    I figure there's going to be a SHITLOAD of water pushed through it.
  14. Sep 26, 2021 at 12:14 AM
    #704
    empty_lord
    05 rollover special
    likely. when you do it, put the old oil cooler and lines on too... dont want to plug up the new ones.
  15. Sep 26, 2021 at 12:15 AM
    #705
    empty_lord
    05 rollover special
    watch the video of him doing these heater cores. guys good at explaining.
  16. Sep 26, 2021 at 12:17 AM
    #706
    Tundra2
    Noah
    Western Kentucky
    I don't have replacement for any of those hoses yet. Looks like half inch? I can scrounge some up at work unless it has to be the specific bends or it'll kink'em.
  17. Sep 26, 2021 at 12:18 AM
    #707
    empty_lord
    05 rollover special
    see is @lsaami has them. if so, just get them from him..
    factory lines would be metric. not sure the size.
  18. Sep 26, 2021 at 12:20 AM
    #708
    Tundra2
    Noah
    Western Kentucky
    How hard is a heater core replacement? :rofl:
    I'd bet money that the lines coming up to the heater core have a pretty good film of shit in them, but are mostly clear as the bypass tube for the WP was clear. By pass tube goes directly to heater core?]
  19. Sep 26, 2021 at 12:25 AM
    #709
    empty_lord
    05 rollover special
    heater core is a nightmare.. EVERYTHING comes apart in the dash. and you'll need to remove the evap core.. which means the a/c needs to be discharged
    Desert Dog likes this.
  20. Sep 26, 2021 at 12:28 AM
    #710
    empty_lord
    05 rollover special
  21. Sep 26, 2021 at 2:22 AM
    #711
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    The throttle body is full of it too? I would just remove the old one and suck it up and buy a used one.
  22. Sep 26, 2021 at 2:26 AM
    #712
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    That or just bypass the cooling/heating loop in the throttle body. I've heard of people doing that before.
    Tundra2[OP] and FrenchToasty like this.
  23. Sep 26, 2021 at 3:41 AM
    #713
    Tundra2
    Noah
    Western Kentucky
    Just left a message on @lsaami's part out thread.
    Any seals or gaskets to replace while "I'm in there"
    lsaami likes this.
  24. Sep 26, 2021 at 4:08 AM
    #714
    Desert Dog
    That's an interesting possibility. Any known consequences of that mod?
    Tundra2[OP] likes this.
  25. Sep 26, 2021 at 4:18 AM
    #715
    NickB_01TRD
    Nick
    KY
    Really just helps things heat up when it's cold. How much of an effect it really has, I'm not sure.
    Kinda like the transmission fluid cooler/warmer that's built into the rad.
  26. Sep 26, 2021 at 4:28 AM
    #716
    Tundra2
    Noah
    Western Kentucky
    I need to sit down and schmoke a smiggerette while I upload some photos. Pulled the Throttle body, and have various other pictures for yall.
  27. Sep 26, 2021 at 4:41 AM
    #717
    Tundra2
    Noah
    Western Kentucky
    Started on the heater hoses by the blend valve. They're brittle, and dry rotted. Need to be replaced anyways.
    Pictured below is the heater hose on the left of the blend valve. Not terrible. Still needs replacing.
    Pulled the throttle body, and found another mess. Nipple is brass, and has a temp call out on it. Think it's 86°C. Think it opens like the thermostat. Cleaned it up, and will set up some boiling water for it. Pushed a small screwdriver in there, and whatever kind of spring door it has still springs back and forth so that's good. Last picture of the three is a shot of inside the TB where this mini-t-stat screws in. Gnarly, but perhaps cleanable with pressure washer.
    The hose that goes into the nipple was packed full of fuckin shit. I cleaned it out, and blew through it. Usable, but will be replaced.
    Nipple side.
    Water inlet side.
    Nipple from water inlet.
    Took a shot of inside the intake since I had my phone out. Not nearly as bad as my V6.
  28. Sep 26, 2021 at 4:44 AM
    #718
    Tundra2
    Noah
    Western Kentucky
    Something shiny caught my eye in the valley below the intake plenum.
    Oil? Coolant? Head gasket? Runoff from the blocked nipple? Who knows? :rofl:
  29. Sep 26, 2021 at 4:48 AM
    #719
    Tundra2
    Noah
    Western Kentucky
    Checked the temp sensor (?) On the water inlet. Found evidence of a previous mangling. Anyone know if I can order just this connector, and then repin it?
    Sensor was pretty damn clean honestly. Shocked.
    Hole was clean too.
    Reinstalled.
    Also need a connector for the throttle body. I broke it wiggling it...
  30. Sep 26, 2021 at 4:50 AM
    #720
    NickB_01TRD
    Nick
    KY
    That connector is for ECU so most likely your issue. The one on the left of it is for the dash gauge
