Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Sep 13, 2021 at 8:56 PM
    #481
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Why is there pastrami in there?
  2. Sep 13, 2021 at 8:59 PM
    #482
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Yeah, the UV exposure in the desert southwest will expose weaknesses very quickly on exposed parts especially but if you think about the conditions a crank pulley operates under constantly it's incredible how well-designed and engineered they are.
    PHM just threw up in his gloves a little.[/QUOTE]
    Now that's funny.
  3. Sep 13, 2021 at 8:59 PM
    #483
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Weep hole. It’s actually normal… it’s coolant that gets past the seal for the shaft. Instead of it collecting at the seal and drying and causing a total seal failure it works itself out through that weep hole
    shifty`, des2mtn, FirstGenVol and 4 others like this.
  4. Sep 13, 2021 at 9:00 PM
    #484
    Desert Dog
    This is my thinking.
    shifty`[QUOTED] likes this.
  5. Sep 13, 2021 at 9:50 PM
    #485
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've seen coolant cone from weep holes but never saw it look like that. Then again I've only seen two weeping weepholes.
    shifty` likes this.
  6. Sep 13, 2021 at 9:55 PM
    #486
    empty_lord
    05 rollover special
    It’s just the way the Toyota coolant crusts up.
  7. Sep 14, 2021 at 12:13 AM
    #487
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    I can't seem to find the Drivers side crank sensor under the Denso name. This is the only one I can find that I posted about earlier.
    Emailed McGeorge to see what they had to say. Anyone of y'all got a part number?
  8. Sep 14, 2021 at 2:50 AM
    #488
    Desert Dog
    N84434 likes this.
  9. Sep 14, 2021 at 2:52 AM
    #489
    Tundra2
    Noah
    Western Kentucky
  10. Sep 14, 2021 at 4:54 AM
    #490
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    @Tundra2 why do they take weird pics of us?
    Tundra2[OP], Darkness and FirstGenVol like this.
  11. Sep 14, 2021 at 5:12 AM
    #491
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  12. Sep 14, 2021 at 7:45 AM
    #492
    C'mon now, you're bound to get someone excited presenting like that. :spending:
    Tundra2[OP] and bmf4069 like this.
  13. Sep 14, 2021 at 10:08 AM
    #493
    Tundra2
    Noah
    Western Kentucky
    Did some more sleuthing... I have ZERO intention of buying from the rainforest. I just used that to actually look at a picture of the sensor. Here's a link.
    Lexus 19300-50020, Engine Camshaft Position Sensor
    Found it on RA also. Here's a link to the "overview" page. Camshaft Position Sensor overview. There's a few different brands, but the one that stands out to me is the NTK one for $53.79.
    Here's a link to the NTK one directly.
    Here's a McGeorge link. toyota-camshaft-position-sensor-1930050020 $111.94
    Thoughts?
  14. Sep 14, 2021 at 11:19 AM
    #494
    Tundra2
    Noah
    Western Kentucky
    Investigated pictures from shitty JVC and noticed that the wiring harness ends were the same. Went ahead, and test fit the new Kenwood without doing up the new wiring harness.
    There's a little bit of a gap, but I think it's gonna be fine. The important thing is that I didn't cut the bezel to make it fit like a fuckin crack head.
    Need to go through the settings and change the back light rotation to a single color.
    shifty` and FirstGenVol like this.
  15. Sep 14, 2021 at 11:26 AM
    #495
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    I found a a weeping weephole on my 2006 when I did the timing belt last week. Truck only had 62,000 miles on it too. I guess it does happen occasionally.
    NUDRAT, shifty` and Tundra2[OP] like this.
  16. Sep 14, 2021 at 12:58 PM
    #496
    That one point was my major beef with my last (never again) Kenwood, any time the battery cable is pulled, there's so much crap to go back in and change. My best friend next door has lots of complaints with his Kenwood in the same line as yours but I didn't want to be the schmuck who was, like, "Yo that stereo you just bought ... "
    Crazy the harnesses is a match between the two brands! But maybe the car stereo world is becoming like the home Appliance world, where 2 brands make 90% of units?
    I doubt you'll notice the gap once you get your brackets and permanently install, but if t drives you nuts, there are some options you can use like felt or the fuzzy size of velcro to "smooth" things over.
    I feel like the unit will sit a couple mm forward after final install? It looks a bit too deep-set to me.
    Tundra2[QUOTED][OP] likes this.
  17. Sep 14, 2021 at 1:41 PM
    #497
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Worthless tidbit, Kenwood owns JVC now.
    shifty`[QUOTED] and Tundra2[OP] like this.
  18. Sep 14, 2021 at 1:58 PM
    #498
    Tundra2
    Noah
    Western Kentucky
    I remember you mentioning something about a neighbor and Kenwood. I'm thoroughly enjoying the single din in the Corolla virus though which is why I went with Kenwood. If I hadn't stopped off at best buy and Fiddled with radios in person getting a feel for them I probably wouldn't have bought any at all. Lol
    Here's pics from the corolla.
    Here's a link to that post. https://www.tundras.com/threads/2003-corolla-virus.89458/#post-2249983
  19. Sep 14, 2021 at 3:50 PM
    #499
    Tundra2
    Noah
    Western Kentucky
    I've made up my mind to order OEM for this as I've been unable to find for sure that NTK made that camshaft sensor. My gut instinct says that NTK did make it, but without documentation (such as Aisin) I'll pay the toyota surcharge.
    I think I'll also order a gear shift assembly. I replaced the gear shift lever because the O/D switch didn't work consistently. Tightened up the torx screw and there was still plenty of slop in the mechanism. My V6 is still tighter than a Virgin. Lol
    Emailed mcgeorge and found that this was the mechanism for it.
    https://parts.mcgeorgetoyota.com/oem-parts/toyota-shaft-sub-assembly-cont-335010c012
    N84434 likes this.
  20. Sep 14, 2021 at 5:45 PM
    #500
    Tundra2
    Noah
    Western Kentucky
    Before I place my McGeorge order... Is there anything else that I should include on the list. Below is a list of what I have on hand currently, or on order.
    1. Aisin TB/WP Kit. (On Hand)
    2. Aisin Hyd. Tensioner (On Hand)
    3. Toyota Oil pan FIPG (Recco'd by @empty_lord) (On Hand)
    4. Aisin Thermostat with seal (On Hand)
    5. New Aisin Fan bracket as the studs came out with the fan clutch. (On Order)
    Here's what I plan to order from McGeorge soon.
    1. Shift mechanism as posted above.
    2. Camshaft position sensor.
    I'll inspect the alternator brushes when I get home. Possibly order that also. Any thing else you all can think of?
  21. Sep 14, 2021 at 5:59 PM
    #501
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Sorry, I don't have a part #
  22. Sep 14, 2021 at 6:00 PM
    #502
    Tundra2
    Noah
    Western Kentucky
    No worries Steve. My McGeorge-Fu has been getting strong :muscleflexing:
  23. Sep 14, 2021 at 6:09 PM
    #503
    Tundra2
    Noah
    Western Kentucky
    The plan for today when I get home is to remove the camshaft Position Sensor, and inspect it. See if I can de-pin the connector and then put some kind of abrasion coating on the wiring to prevent this in the future.
    I'll see what I can scavenge up here at work. May use some self Vulcanizing tape which will only stick to itself, and is incredibly heat resistant. We use it on heater wires at work for the extrusion lines. Those are routinely around 500°F+
  24. Sep 14, 2021 at 6:35 PM
    #504
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    @Tundra2 Were you able to measure your new Denso radiator core thickness?
  25. Sep 14, 2021 at 6:37 PM
    #505
    Not worthless, good to know.
    For a decade or two now I've passed by the Kenwood Factory Outlet building on the interstate in ATL which I'm fairly certain is abandoned at this point. There's a Technics/Panasonic building off the interstate somewhere up here too. I can't keep tabs on who is doing what these days.
    So, sounds like maybe this turning into home appliances land. Where Electrolux and one other company make damn near everything.
    Tundra2[OP] likes this.
  26. Sep 14, 2021 at 6:39 PM
    #506
    Sucks nobody makes 1.5 DIN radios anymore. I really wish there were some 1.5 DIN options out there on touch screens, I might not have sold a few vehicles along the way.
  27. Sep 14, 2021 at 6:40 PM
    #507
    Tundra2
    Noah
    Western Kentucky
    Not yet. I can pop a side off the old one, and the new one to measure. Thanks for the reminder by the way... I totally forgot
    assassin10000[QUOTED] likes this.
  28. Sep 14, 2021 at 6:41 PM
    #508
    Tundra2
    Noah
    Western Kentucky
    Ordered new brush with shifter mechanism and camshaft toyota surcharge. $16 for a brush+holder.
  29. Sep 14, 2021 at 7:54 PM
    #509
    Tundra2
    Noah
    Western Kentucky
    This is self Vulcanizing tape. It's silicone based, and extremely durable. It only sticks to itself.
  30. Sep 14, 2021 at 8:45 PM
    #510
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    No worries. You've got a lot going on.
    Here's the measurement of the original radiator from my '05.
