Cracked Pinch welds under bed (!!)
Discussion in '2.5 Gen Tundras (2014-2021)' started by goffredo, May 29, 2022.
  1. Jan 17, 2024 at 4:22 PM
    Not_a_toy_yoda
    Not_a_toy_yoda New Member
    2018 TRD Off Road 4x4 double cab
    Pic 1. bed is separated
    Pic 2. You can see the slope of the frame and no bed support at the most forward part of the bed
    Pic 3. What I had on the truck (total weight around 500 lbs)
  2. Jan 17, 2024 at 4:41 PM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    Bed rails not designed to carry that weight? So I design a rack to sit on the bed rails THEN blame Toyota it's Their fault?
    DMCK, Half Assed, GODZILLA and 2 others like this.
  3. Jan 17, 2024 at 5:59 PM
    Not_a_toy_yoda
    I’ve created a FB group to try and collect anyone who is willing to share photos/videos of any damage incurred to try and make a case of what I believe is a design flaw by toyota.
    the fact of the matter is the is, they changed the design on 2022+ models and added a crossmember at the weak point and 2 additional bed bolts.
  4. Jan 17, 2024 at 6:08 PM
    Not_a_toy_yoda
    The truck bed is unsupported nearest the cab past the final 2 bed bolts. This appears to be a known problem because they obviously addressed it in 2022+ models. So what happens to the rest of us?
  5. Jan 17, 2024 at 6:49 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Seems to me that an entrepreneurial person might make a bracket that extends from the frame to the bed.
  6. Jan 17, 2024 at 7:21 PM
    Not_a_toy_yoda
    Should be mass produced and sold just like the bed stiffeners for the rear.
    ZappBrannigan[QUOTED] likes this.
  7. Jan 18, 2024 at 6:42 AM
    bonefish
    bonefish New Member
    Peter
    Seems to me it’s a upfitter problem not Toyota. 2022 bed is composite so we’ll wait and see how the plastic holds up. Rack manufacturer needs to extend support down to bed floor and across floor.
  8. Jan 18, 2024 at 7:05 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I wasn’t implying that it was a Toyota problem. I was suggesting a solution that didn’t imply fault.
  9. Jan 18, 2024 at 3:54 PM
    DavidinPhx
    DavidinPhx New Member
    Phoenix
    2021 DC Tundra SR5
    Icons, Deavers, 34s, 4.88s, F&R e-lockers, Ovrlnd Camper, & other stuff
    Well, I get your point, but Toyota sells their bed rail system for the DCs and it's rated by them to support 880 lbs at the top of the bed. My camper weighs less than half that, and I don't have anywhere near 400 lbs in the front of the bed. It's clamped into their bed rail system, again at half the advertised weight. My truck is also a "TRD Off-Road" (probably like most) which is advertised for exactly what I do with it. Nowhere does Toyota warn against weight on the bed rails. I get that the camper puts stress on the front, and there's dynamic loads, etc. but they clearly whiffed on the front bed design for DCs that are used as they entice us to do. They know they have a super flexy frame and an unsupported front of the bed. They even built the P-side front of the bed stronger. Take a look under one and you'll see what I mean.
    https://www.toyotapartsdeal.com/accessories/toyota-deck_rail_kit.html
    DMCK and Terndrerrr like this.
  10. Jan 18, 2024 at 8:41 PM
    Not_a_toy_yoda
    The real issue is the amount of tundras that are a double cab is a small portion of overall tundras sold. Of the double cabs, the owners who have a camper or rack or shell, or something along those lines is a small portion as well. Of those owners, the portion who actually take their trucks and go wheeling with them is a small percentage.
    Essentially, we are talking about 1% of 1% of whatever percent the double cabs are. So not a lot of data/complaints/malfunctions.
    i hope toyota will take it seriously, but seeing as they have a new model year out and the new 6.5’ beds are utilizing an additional crossmember and 8 bed bolts instead of 6, I don’t if they will do anything.
    i am seriously considering making the switch to a f250 tremor or a Ram power wagon.
  11. Jan 18, 2024 at 8:44 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Good plan, can’t break the welds if it won’t start.:D
    On a more serious note, if your current tool won’t do the job you want then you’re right, it may be time for a different tool.
    panicman, woods, OHwendTrd and 7 others like this.
  12. Jan 18, 2024 at 9:05 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    That’s crazy to me that the frame just falls away from the bed like that. I always thought the double cab was the one to have if you’re hauling stuff because you can place it closer to right between both axles. But if you load up your bed and put the heaviest stuff toward the front, it’s unsupported. Weird.
    Agreed that there could be a bolt-on support for the front of the DC bed much like the bed stiffeners for the rear.
    PW won’t get you any additional payload. Ford might not come home from the trail. Either will drive MUCH larger than your Tundra.
    woods and ZappBrannigan like this.
  13. Jan 18, 2024 at 9:38 PM
    Not_a_toy_yoda
    Thanks for the chuckle.
  14. Jan 18, 2024 at 9:46 PM
    Not_a_toy_yoda
    Here is a pic of an older dodge 2500 I believe…not sure. Something like this in conjunction with a crossmember would do the trick. With additional bolts running to the crossmember up front so it not just two bolts on the corners.
    As you can see I’m passionate about this and have done some research….it just irks me.
    Same frame for 5.5’ bed and 6.5’ bed and didn’t bother to add support for the additional 12-15” or so. Could’ve been a $200 expense or so in metal cost to add 1 crossmember at the factory, instead of a several thousand repair job or bed replacement. IMG_0617.jpg
    Terndrerrr[QUOTED] likes this.
  15. Jan 18, 2024 at 11:53 PM
    If you do a little searching around, Toyota is not alone in this. Ford, GM, Ram....etc all have this happen. Now I will say it happens with the domestics and much larger/heavier campers. I would have a good plan going forward after fixing my bed.
    GODZILLA and ZappBrannigan like this.
  16. Jan 19, 2024 at 12:21 AM
    Not_a_toy_yoda
    I hear you….
    But all the evidence I’ve seen has been 500-600 lb set ups, and 1 camper at around 800lbs?
    Far below some of the 1500-1700 lb campers causing domestics to fail.
  17. Jan 19, 2024 at 12:27 AM
    Yep. That's what I said and agree. :thumbsup:
    Very unfortunate issue to have that will cost a grip of money to repair. :mad:
  18. Jan 19, 2024 at 2:54 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I recently toyed with the idea of getting a pop top camper shell! Between this thread and the $8k pricetag, think I'll just axleflip my enclosed trailer, install a cargonet hammock and escape window, and use that instead!
    woods, ColoradoTJ and ZappBrannigan like this.
  19. Jan 19, 2024 at 8:30 AM
    #49
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The problem isn’t just the weight on the bedrails. The problem is driving offroad on uneven terrain and the C channel frame flexing. Bolt on a rigid bed on top of the flexing frame and ofcourse you’ll start tearing the metal. Add a bunch of weight on the rails and it just makes it 10 times worse.
    You can weld everything back together and add more supports but it’ll eventually tear apart again. The only true solution IMO is boxing the frame.
    j-utah, Bulldog9, GODZILLA and 5 others like this.
  20. Jan 19, 2024 at 8:51 AM
    #50
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Well yes and no. I’ll start by saying I’m a big fan of boxed frames and didn’t buy a tundra for the longest because I didn’t like the c channel design. That said there’s advantages and disadvantages to both setups. The boxed frames flex as well, albeit not nearly as much, and they can also crack under those kinds of loads because they don’t flex enough.
    the bottom line here is that the pickup truck is designed to be used dozens of different ways and without specialization there’s always trade offs. This is especially true when it comes to costs. I mean, nobody would spent 250k on a tundra that could do all the things people want really well so compromise is the name of the game.
    j-utah and coTony like this.
  21. Jan 19, 2024 at 9:49 AM
    #51
    Terndrerrr
    Music City
    6UR-FE
    I hear you, but when you bolt more rigid things (rack, tent, etc) to your bed, adding weight and reinforcing the bed's rigidity, the hot spots where the bed is stressed by frame flex get even worse. The open C frame becomes more of a disadvantage.
    Best way to keep off-roading your truck at high speeds or even at low speeds with a tent and rack is by preventing the frame flex. Isolate the flex to the suspension. Changes the game for sure. Probably raises new concerns.
    If we're doing more than driving on gravel roads, we're well outside Toyota's anticipated use anyway.
    I was dead set on doing this when I first got my truck, then kind of forgot about it. But I came down pretty hard at one point on a service road while hunting in CO, and I'm fairly certain my bed hit the back of the cab. That got me curious again...
    If you've boxed your frame, how is it holding up? Has it caused any other issues? I've read all I can on it, just looking for updates on how things are holding up.
    @joonbug
    @831Tun
    @Vizsla
    @osidepunker
    @papasmurf
    @froggy78
    @reywcms?
    @KevinK?
    joonbug and 831Tun like this.
  22. Jan 19, 2024 at 9:56 AM
    #52
    Warreng
    Warreng New Member
    There was a trend in sled deck manufacturing that had the entire weight of the deck, and 2 snowmobiles, resting entirely on the bed rails. People were pika chu face when they started to get ripples in the sheet metal of the box.
    Like wtf did you think would happen?
    Terndrerrr, GODZILLA and ColoradoTJ like this.
  23. Jan 19, 2024 at 10:26 AM
    #53
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Mines not boxed yet and the old man’s rig is in getting it done now. This has proven well on the other trucks completed by the shop and no issues for those built rigs. We’re also adding frame and bed reinforcements for his gfc to tie it to the frame rather than the bed rails.
    I’m taking a different approach to boxing the rear and just cutting the frame off after cab and doing a full back half.
  24. Jan 19, 2024 at 11:54 AM
    #54
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Yep. You can see this in demonstration with how the Tundra's 2nd gen counterpart, the body-on-frame Sequoia, has a fully boxed frame. The Land Cruiser likewise is setup with a boxed frame. Rigid body on top, frame needs stiffening. Throw rigid things on something that has flex, expect stress concentrations.
  25. Jan 19, 2024 at 1:46 PM
    #55
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    We decided to embrace the wet noodle approach, and everything on our truck is designed to flex with the frame instead of trying to resist it so hard.
    There’s pros and cons to every choice, and we decided to keep ours light and flexible. If you brace it a bunch, you add weight, which can require even more bracing, leading to an almost never ending circle of chasing the dragon until you decide to do what @reywcms is doing and go full back half.
    It’s about deciding what weak points you want to keep and repair based on cost and ease of repair/replacement. Our shit wobbles and bends like a mofo. But it doesn’t break.
  26. Jan 19, 2024 at 4:13 PM
    #56
    Vizsla
    Vizsla pretend2send
    Holding up fine, no damage to bed. It’s not overloaded, and even though it doesn’t flex much, the rack/tent/awning lets the bed flex without resistance. Probably a poor example for the average off-road adventurer, whole truck is reinforced = not realistic for almost everyone imo..
    GODZILLA, KevinK, reywcms and 3 others like this.
  27. Jan 20, 2024 at 6:17 AM
    #57
    2mchfun
    Fix it, sell it, buy a Harley and a tent then follow the decent weather????? The fuel savings will cover periodic hotel stays during the inclement weather. Just an idea!
    ZappBrannigan likes this.
  28. Jan 20, 2024 at 10:46 AM
    #58
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    It's held up well and I can't think of any other issues it's caused. I have found the need to modify my driving and my expectations of how hard I can reasonably push this platform. Baja will do that to ya. So, I recently acquired a 2014 built Raptor because the ones I've traveled with down there have done fairly well in Baja and parts are more likely to be available.
    Vizsla, reywcms, KevinK and 1 other person like this.
  29. Jan 20, 2024 at 1:39 PM
    #59
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Put it this way. Of all the LT Tundras between the Bastrds and SGU, I believe they’re all boxed except for two trucks. There are two trucks in the group that have cracked beds. Guess which two.
    Realistically, not too many people are going to spend that kind of money to box their MT truck. But if you wheel it hard enough, it might be better than putting money into fixing this only for the problem to eventually come back again.
    https://youtu.be/p1LO6uxy11I?si=MZsMvEr09pFpQFHl
    KevinK, 831Tun, Vizsla and 2 others like this.
  30. Jan 20, 2024 at 2:43 PM
    #60
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Everybody loves the tundra twerk.
    GODZILLA likes this.
