Crack P Trap on Upstairs Shower
Discussion in 'Home Improvement' started by Fearthisbeard, Apr 9, 2021.
  1. Apr 10, 2021 at 12:31 PM
    #61
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Hit that thing with some flex tape and call it a day. Flex seal tape will move with expansion and contractions and it will not leak.
  2. Apr 10, 2021 at 12:47 PM
    #62
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    It's too late, he's got all the parts cut out. I was looking at the configuration of that drain and trying to figure out what the heck is going on. There's too many elbow joints monkeyed in together. It looks all messed up. I'm not sure if there is an S, a P or a combo of both making a WTF. There should be a simple p-trap, maybe a vent and a line to the main and that's it.
    Maybe something like this:
  3. Apr 10, 2021 at 1:20 PM
    #63
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    If anything this thread has been educational..
    Great to see us helping each other out..:thumbsup:
  4. Apr 10, 2021 at 2:23 PM
    #64
    Fearthisbeard
    Fearthisbeard [OP] New Member
    Gilbert AZ
    2019 - 1794 TRD Offroad
    Well got all my pieces in place, glued and set, gave it the water test, everything looks good. Then I notice a little dripping even further up closer to the shower drain itself, there is a little hairline crack, but that part of the pipe is glued in to the bottom of the tub or whatever that is :annoyed::annoyed::annoyed:. Maybe I can give it the flex seal or JB weld treatment ?
  5. Apr 10, 2021 at 2:40 PM
    #65
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  6. Apr 10, 2021 at 2:45 PM
    #66
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    As a minimum you could try that. I’m assuming the flex in the shower floor , with old elbows wedged from the bottom it created pressure on those glued joints.
    See if the tape works or JV weld around the collar. Since it’s only a drain and not a pressured closed system , you’ll probably have success.
    If not, back to the drawing board. Does that joint go to another 90 and up into the shower pan or am I looking at
    The shower pan. Hard to tell.
    TaquitoBandito likes this.
  7. Apr 10, 2021 at 2:48 PM
    #67
    Rubberdown
    Don’t rig things. Fix them properly or they will haunt you and you’ll worry forever if you are going to have problems.
  8. Apr 10, 2021 at 2:50 PM
    #68
    Fearthisbeard
    Gilbert AZ
    I'm with you, just really sucks to possibly have to drop thousands on a shower we almost never use.
  9. Apr 10, 2021 at 2:52 PM
    #69
    Fearthisbeard
    Gilbert AZ
    Maybe the labels help, the crack is in the part of the pipe connected right to the shower drain I'm pretty sure.
  10. Apr 10, 2021 at 2:55 PM
    #70
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Can we talk about what was going on here? :threadjacked:
    Kung and Hightide like this.
  11. Apr 10, 2021 at 3:13 PM
    #71
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Just installed a shower in my basement a few months back. Plumbing(and breaking up the slab) looks daunting at first but once you get going, it’s actually pretty simple. Glad to see you tackled this yourself!
    Fearthisbeard[OP] likes this.
  12. Apr 10, 2021 at 3:19 PM
    #72
    Fearthisbeard
    Gilbert AZ
    :rofl::rofl::rofl:that was a 8 year old Facebook throwback back that popped up on my timeline today, back when me and my buddies thought we were buff. Had to Screencap and send out to cringe over.
  13. Apr 10, 2021 at 5:20 PM
    #73
    ScottsTundra
    ScottsTundra New Member
    2017 SR5 Crewmax
    Headwaters seat covers, Undercover Flex
    The redneck in me is telling me to tell you to just backbutter it with abs glue and roll with it
  14. Apr 10, 2021 at 6:02 PM
    #74
    NoRcptn
    NorCal
    2017 Platinum
    Is your shower a fiberglass floor? Tiled on the floor?
    You could probably get enough room to cut that section out and re-do it depending on how they set it in the floor for your shower drain and if you have enough room to cut the tub overflow/vent pipe above the Tee. By the workmanship on this I'm betting they cut corners. If you have some pipe to work with before it turns into the drain sleeve, you could redo that section. You should have some there. Keep us posted!
  15. Apr 11, 2021 at 4:32 AM
    #75
    Slayer
    Slayer Member
    Slayer
    It's open..
    Take a breath..
    make the effort & fix it correctly.
  16. Apr 11, 2021 at 8:08 AM
    #76
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    You need to use an ABS solvent or roughen up the joints with some fine grit sand paper before applying the joint glue. It's also a good idea to twist the joints a little after setting them in place permanently.
    I've done my own plumbing repairs and rough in's for nearly 40 years. You basically need to know one thing with plumbing. Shit flows downhill.
    GODZILLA and Fearthisbeard[OP] like this.
  17. Apr 11, 2021 at 8:30 AM
    #77
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    ...Unless you have a macerating toilet in your basement...
  18. Apr 11, 2021 at 8:36 AM
    #78
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    it’s all technically correct. There’s a p-trap with a vent downstream... then a really short downhill to transition it to the main. I’ve had to look at it a half dozen times to wrap my head around it.
    You’ve got the tub bottom exposed - fixing the drain pipe too would be best. Unfortunately that probably means redoing your trap (or part of it) again.
    You’ll want an inexpensive tub drain wrench, and the tub drain threads into a female thread x hub elbow. Use plumbers putty for a gasket seal on the tub drain.
  19. Apr 11, 2021 at 8:36 AM
    #79
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    This is an odd method of support.
    Can’t be code.
  20. Apr 11, 2021 at 8:47 AM
    #80
    Hightide
    Abalama
    Magic School Bus
    What a headache.
    Repair it correctly.
    Everything is open and accessible.
    Can you move some insulation and such back and get a good pic of where it connects to the tub itself?
    That connection should be a screw fitting.
    It may be possible to unscrew and pull that whole piece out while you’re rebuilding.
  21. Apr 11, 2021 at 9:15 AM
    #81
    Fearthisbeard
    Gilbert AZ
    Here is a pic looking straight up with some insulation moved, that pipe is the tub drain, looks like it is epoxied into a piece of drywall that is sitting below the tub?
  22. Apr 11, 2021 at 9:17 AM
    #82
    Hightide
    Abalama
    Magic School Bus
    What tha.?.?.
    Wow.
  23. Apr 11, 2021 at 9:17 AM
    #83
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    That’s fire caulk, it can be removed
  24. Apr 11, 2021 at 9:19 AM
    #84
    Hightide
    Abalama
    Magic School Bus
    Why in the world would they put fire caulk there?
    I’m not understanding that setup.
    Is that supposed to be a firewall?
  25. Apr 11, 2021 at 9:20 AM
    #85
    Fearthisbeard
    Gilbert AZ
    It does sit above the garage, could that be the reason?
  26. Apr 11, 2021 at 9:20 AM
    #86
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Holy crap. I would get in touch with Fulton tomorrow morning and find out wtf that plumber was thinking, and also how that passed their inspection.
  27. Apr 11, 2021 at 9:21 AM
    #87
    Hightide
    Abalama
    Magic School Bus
    Possibly.
    Just an odd way of doing that.
    There’s so many other failure points beside the caulk.
  28. Apr 11, 2021 at 9:24 AM
    #88
    Hightide
    Abalama
    Magic School Bus
    2hr fire caulk.
    20 minute usb board.
    Hm.
  29. Apr 11, 2021 at 9:26 AM
    #89
    Hightide
    Abalama
    Magic School Bus
    That plumber must have known something.
    No wonder the 2k quote.
    Was he the one that installed it?
    :notsure:
    Slayer and TaquitoBandito like this.
  30. Apr 11, 2021 at 9:29 AM
    #90
    Fearthisbeard
    Gilbert AZ
    haha I'm not sure, I definitely got the vibe that this was a job he did not want to do and the more I dig into it the more I am understanding why
