Covering Up Chrome
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ahutch_6, Feb 10, 2020.
  1. Feb 10, 2020 at 2:19 PM
    Ahutch_6
    Ahutch_6 [OP] New Member
    2017 Toyota Tundra SR5 crewmax
    So I want to cover up chrome on interior of Tundra and I have found forums to do that My questions is what are the recommendations for paint? Could I use plasti dip? I used plasti dip on an old Challenger I had.
    Also for the End caps on both bumpers what is you recommendation for painting. I had a few people say to ruff it up and then use a primer and paint. Any suggestion on both of those? Also someone suggested spray in bed liner to paint it. Is that any good?
    Any suggestions or Tips I appreciate
  2. Feb 10, 2020 at 2:26 PM
    Upser11
    Upser11 New Member
    Luis
    Central Florida
    2017 limited
    Leveled,rims,TRD Sport grille,TRD headlights,wrapped bumpers, flow master exhaust, and more
    I wrapped my bumper ends last Jan (19') and they still look good. I know it won't last as long as primer and painted bumper ends, but for $150, it's not a bad option.
  3. Feb 10, 2020 at 2:32 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I used plasti dip on my interior ones only 2016. I put ajt designs in my 2020
    As for the bumper, scuff it up really good, then when you think it's done, scuff it up more. Primer and paint. I did my 2016 while they were on the tundra
    panicman likes this.
  4. Feb 10, 2020 at 7:02 PM
    Hhtundra
    Hhtundra New Member
    Sparks sells the caps, but theyre expensive, i use plasti dip once, never again, too messy
  5. Feb 10, 2020 at 7:25 PM
    Aren't some of the 3rd Gen owners using something called Bumpershells or something to that effect?
    Hammy68 likes this.
  6. Feb 10, 2020 at 7:56 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    I took my bumper off, had the end caps sandblasted to remove the chrome finish (i think i was charged $30 or $40 total for both end caps), then i had them painted at a shop. Paint has stuck nicely, and since it was prepped well there’s a mirror shine unlike the plastic end caps which can sometimes have a textured appearance depending on how they prep it.
    1lowlife likes this.
  7. Feb 11, 2020 at 11:15 AM
    Blazing Blue
    Blazing Blue New Member
    I just did mine diy.
    GAknight, Mcoop and jewsNbrews like this.
  8. Feb 11, 2020 at 11:37 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    I protect-dipped my end caps and am happy. It was a quick fix to get me through the winter, and I'll be painting them permanenetly in the summer or maybe the following summer, depending on how I feel.
    300BLK likes this.
  9. Feb 11, 2020 at 12:59 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    Some dude on here monstalined them, and they looked good [and color matched] ... monstaliner
  10. Feb 11, 2020 at 2:43 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    I wrapped mine almost two years ago. Zero issues.
    Whether you wrap or paint; the two main keys for long term success and durability; quality products and prep!!!
    What color is your truck?
  11. Feb 11, 2020 at 2:46 PM
    ZTundra
    ZTundra New Member
    ZACK
    Knoxville, TN
    2021 MGM Nightshade
    You got any pics with them installed on the truck? What paint did you go with and did it match pretty well?
  12. Feb 11, 2020 at 2:48 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    what special prep do you need for wrap?
  13. Feb 11, 2020 at 3:44 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    The biggest thing...Cleaning!
    I degreased the hell out of mine with Super Clean, then gave them a good washing with Dawn dish soap, and just before wrapping used a lint free rag with 70% alcohol to wipe down the surface one last time to remove any dirt or oils (from your hands).
    Of course, your work area too. I did mine inside. I sat mine on a big fold-out table. While the garage wasn't to dirty, inside the house was cleaner and (at the time) warmer.
    Which is the other 'prep' element to keep in mind; Temp/humidity.
    While you'll definitely need/use a heat gun at times, if the air temp where you're working is under 65 (like in a garage this time of year perhaps), the vinyl may be more likely to cool down quicker giving you less time to stretch and shape. Reheating areas repeatedly increases your risk of burning/scorching the vinyl. On the other end, if it's to warm, your vinyl may stretch to easily which can lead to more wrinkles, especially around corners, and clean tucks around edges.
    Lastly, Good tools are a must! Get a good squeegee with a good felt-wrapped edge. If you only get one, it should have some flexibility IMO...nothing to rigid or to flexible. Also consider a good wrapping (lint free) glove.
    And use a new/clean razor! I used my Xacto knife with all my wrapping.
  14. Feb 11, 2020 at 3:57 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    The best solution is getting the bumper ends pro prepped and painted. Mine are wrapped, maybe 2y+ and it doesn't look great closeup, chips, underside peeling, fade. It started out pretty close to the black paint. I'm sure any other body color/shade is harder to match. Plastidip is budget friendly, requires touchups, DIY messy but works for some. I see some members here with impressive wrapping or paint skills too. And we have a vendor that sells caps as well. Depends on what you want to spend, what you're willing to do yourself.
  15. Feb 11, 2020 at 4:01 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    cool great info....I am buying the wrap but having a shop do it but I didn’t figure they would be the same steps as if you were painting. Thanks!
  16. Feb 11, 2020 at 4:15 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Sounds good. Are you taking them the truck or the parts?
    If you're taking them the truck, ask them if they'll be taking the parts off.
    Reason being, confirming how they will plan to do the edges?
    By taking the parts off (aside from the cleaning), it allowed me to take the wrap around to the back/underside of the parts.
    Aside from the complete coverage, it prevents the potential for the edges to pull up (over time) from exposure to elements, washings, etc.
  17. Feb 11, 2020 at 6:16 PM
    Borador
    Borador New Member
    Olive Branch, MS
    2016 Crewmax 4x4 w/1794 Interior upgrade
    I just had my chrome bumper ends wrapped. It looks much better. If the rain will stop and the sun shines again soon, I'll take better pics.
    Jsnake89 and aperezsh like this.
  18. Feb 11, 2020 at 7:00 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    not sure how they do it but hopefully they know what they are doing.
  19. Feb 11, 2020 at 8:52 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    Mine are wrapped as well in 3M gloss black wrap. It came out pretty good and they've been wrapped since July.
    Like many have mentioned though, I've kept my expectations realistic and I know the wrap is only good for 2-3 years and I'll need to either wrap again or paint.
  20. Feb 11, 2020 at 9:36 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    What wrap was used?
    Iron1 likes this.
  21. Feb 12, 2020 at 8:30 AM
    Blazing Blue
    It matched perfect. I also did the rear caps and mirror caps. I bought color matched paint from automotive touch up and 2k primer.
    9am53, KTM Hauler, Jsnake89 and 6 others like this.
  22. Feb 12, 2020 at 1:24 PM
    kenstl
    kenstl New Member
    Haven't seen many that are two tone between the grill surrounds and bumper de-chrome, looks great! Mirror caps look great as well.
  23. Feb 13, 2020 at 9:29 AM
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    What color did you go
    With to match the bumper exactly? I liked and saw 3 different black.
  24. Feb 13, 2020 at 6:40 PM
    socaltundra951
    Southern California
    Black CrewMax 5.7
    To be honest I'm not sure, a local vinyl guy did it for me. All I remember is that he said it was 3M gloss black vinyl.
  25. Feb 14, 2020 at 7:40 AM
    Ahutch_6
    Looks amazing! Did you have to remove whole bumper or did you just order caps and paint them yourself?
  26. Feb 14, 2020 at 8:52 AM
    TundraBlack
    TundraBlack New Member
    What wrap did you use. Looks good
  27. Feb 14, 2020 at 8:56 AM
    Ahutch_6
    Also where did you get black surround for bumper? I cant find that anywhere. I am trying to black out my 2017 SR5
  28. Feb 14, 2020 at 4:11 PM
    Borador
    Borador New Member
    Olive Branch, MS
    Vinyl Wrap is GLOSS970RA-937 - ORACAL Series 970RA Vinyl Wrap Film W/Rapid Air | Gloss Charcoal Metallic from metrorestyling.com
    The black bumper was on the front and rear when I bought the truck. I just covered the chrome end caps.
  29. Feb 14, 2020 at 6:16 PM
    FL_YOTA_FANATIC
    FL_YOTA_FANATIC New Member
    2016 Tundra 1794 4x4 BBP
    9am53 likes this.
  30. Feb 18, 2020 at 4:50 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    Night and day!! looks amazing, I see you snuck in some headlights too. Is the middle of the bumper grey on your truck? I think its black on mine.
