Covered Threaded Bed Holes
Discussion in 'Tonneau Covers, Caps and Shells' started by THORYOTA, Sep 18, 2021.
  1. Sep 18, 2021 at 5:38 PM
    THORYOTA
    THORYOTA [OP] God of Thunder
    Thor
    Asgard
    2021 MGM TRD CM "Mjölnir"
    I was gifted a OEM Tundra Tri-Fold for my 21 crewmax. Went to put the sucker on and could not find the threaded holes! After freakinging out for 30 min and doing some scrambling research, I found it’s common for the holes to be covered by the factory bed liner. I’m guessing the factory is working faster than normal, causing this error.
    All I had to do was push on the bump outs in the bed sides to feel for where the hole was and then use a utility knife to cut the liner to expose the holes.
    Anyone else run into this?
  2. Sep 18, 2021 at 5:54 PM
    It is fairly common for that to happen when the beds are sprayed. Happens when it's sprayed after purchase as well.
  3. Sep 18, 2021 at 5:57 PM
    GTundraX
    GTundraX Rub some dirt on it.
    Melyssa
    Oceanside, CA
    2019 TRD Off-Road DC
    Yes, ran into the same thing when we installed our bed rails to mount our rack. Poked it with a center punch and screwed through the remaining coating with no issue.
