Couple questions...
Discussion in '1st Gen Tundras (2000-2006)' started by JKS6330, Oct 13, 2020.
  1. Oct 13, 2020 at 5:39 PM
    JKS6330
    JKS6330 [OP] New Member
    2005 tundra crew cab
    Subject: 2005 tundra crew cab 2wd w/ over 220,000 miles...
    1.) Does anybody know the cause (and remedy), for a flashing A/C button? The A/C works... until it starts flashing & then it doesnt blow cold air. If I push the A/C button to turn it off & then push it again to turn it on, it starts to work again. But now it seems to be happening more & more frequently.
    2.) In the last couple days, the check engine light came on & now it's become sluggish & doesnt accelerate or shift as it should. I havent had time to have a diagnostic test done on it so, was wondering if anyone has any ideas as to what it might be, or where to start.
  2. Oct 13, 2020 at 8:49 PM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    You can get the code read at most any autoparts store. They want to sell you the parts you'll need to fix it. Once you have the code you can search and/or asak how to further diagnose/fix it.
  3. Oct 13, 2020 at 10:21 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    USUALLY STICKY RELAY FOR COMPRESSOR, SWAP OUT WITH ANOTHER ONE TO OPS CHECK 10 DOLLAR FIX OR JUST PICK ONE UP AT A JUNKYARD.
  4. Oct 14, 2020 at 4:52 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    I'd suggest picking up a code reader for cheap and seeing what comes up. No way for us to tell without that for the CE light.
  5. Oct 14, 2020 at 10:48 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    THANK YOU. DID YOU KNOW THAT YOU ARE IN THE FIRST GEN FORUMS?
    NewImprovedRon, Lil Steve and bmf4069 like this.
  6. Oct 14, 2020 at 12:34 PM
    Professional Hand Model
    Hand Protectors
    I AM NOT SURE HE KNOWS. I WONDER WHERE @BFM4069 IS? HE NEEDS TO GET TO WORK.
    NewImprovedRon, bmf4069 and Lil Steve like this.
  7. Oct 15, 2020 at 4:47 AM
    bmf4069
    TX
    02 AC sr5 4wd v8
    HE WAS YELLING SO I PANICKED AND RAN AWAY.
