Could it be that a Porsche just beat a Tundra on towing?
Discussion in 'General Tundra Discussion' started by TXMiamiFan, May 3, 2017.
  1. May 3, 2017 at 11:43 AM
    TXMiamiFan
    TXMiamiFan [OP] SSEM #3 and tractor extraordinaire
    Jose
    2016 White Crew Max TRD
  2. May 3, 2017 at 12:00 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    4.2L V8 Diesel
    Tundra still has it for the naturally aspirated gas guys
    JC303 likes this.
  3. May 3, 2017 at 12:05 PM
    TXMiamiFan
    Jose
    That pulled seemed too easy; like it wasn't even there. Not sure how credible this is for me.
  4. May 3, 2017 at 12:09 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    They're French.....wine and arrogance are the only credible things about them.
    As for porsche...German.....hot women and bratwurst....
  5. May 3, 2017 at 12:11 PM
    csuviper
    Broomfield, CO
    Kevin Fast (Canada) pulled a CC-177 Globemaster III, weighing 188.83 tonnes (416,299 lb), a distance of 8.8 m (28 ft 10.46 in) at Canadian Forces Base in Trenton, Ontario, Canada, on 17 September 2009.
  6. May 3, 2017 at 12:11 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    100f that's it?! How far did the tundra pull that space shuttle?
    NewImprovedRon likes this.
  7. May 3, 2017 at 12:12 PM
    csuviper
    Broomfield, CO
    Straight from Guinness website:
    ColoradoTJ likes this.
  8. May 3, 2017 at 12:19 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Didn't the tundra also tow the space shuttle more than 100 ft? A little up hill as well, if I remember right?
    Y0TA PR0 likes this.
  9. May 3, 2017 at 12:24 PM
    csuviper
    Broomfield, CO
    Just towed it across the 405 freeway. It was driven by four robotic vehicles for most the trip. The reason for the Tundra doing this pull was because the weight of the four robotic vehicles plus the Endeavour, approximately 650,000 pounds, was going to be too heavy to cross the Manchester Bridge. It drove at 2.5 mph in 4-Lo. Toyota put a 1,700-pound weight in the back to give the rear tires some force for grip and the tire pressure was lowered to give the treads as much contact patch as possible.
    Weight was 145 tons.
  10. May 3, 2017 at 12:39 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    They also did a airliner towing challenge on Top Gear America a couple years back.
    ColoradoTJ, Krezz and Y0TA PR0 like this.
  11. May 4, 2017 at 1:10 PM
    10forty2
    10forty2 New Member
    Doug
    NC
    2017 Tundra TRD-4x4 XSP-X
    There is virtually no weight on the truck hitch, as the plane supports its entire load and is completely balanced. Unless there's something causing friction on the wheels, I see no reason our Tundras couldn't pull that plane!
    Y0TA PR0 and TXMiamiFan[OP] like this.
  12. May 5, 2017 at 7:11 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Yes, no weight on the hitch so no weight on the bed. That's why it needed the 1700 lbs in the bed to get traction.
