Cost for entire paint jobs??
Discussion in 'General Tundra Discussion' started by Henry2019, Mar 22, 2022.
  1. Mar 22, 2022 at 3:49 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    I know this question is kinda subjective, but how much would one be looking to pay for a bumper to bumper spray paint job (OEM quality) on a full sized pickup truck?
  2. Mar 22, 2022 at 3:54 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    as long as there is not a lot of repair, for a quality job I think you would be looking at 4-5 large or more. Of course most of the cost is labor and prep. A good paint job is not cheap.
    I spent over $3k on paint for a 72 Pontiac I was restoring, shoot like 20 years ago. So you are probably looking at 5 grand for entry .
    Saltyhero13 likes this.
  3. Mar 22, 2022 at 4:07 PM
    poop_bubbles
    poop_bubbles New Member
    For true OEM quality? Impossible. The entire chassis would have to be stripped, cleaned to like new metal in every 100% inaccessible nook and cranny, phosphated & electro-coated before being perfectly coated with primer and paint by an automated machine. This process involves complete submersion in a tub. This would probably cost more than a new car. You simply cannot replicate a factory job. Keep in mind I am not talking about concourse level garage queen collector car paint that you can see the stars in, that is a very different process. I am talking about paint that will stay bonded to metal for 400k miles and still kind of shine in 20 years.
    This is how OEM does it;
    https://www.youtube.com/watch?v=3OMAnAS8cBI
    Best shops in town will claim OEM quality but they offer nothing close, not even remotely close. If they do it right; all trim is removed, all glass is removed, still not anywhere near OEM. You'll probably spend $3-6k for a "good" paint job. No paint shop can do anything that will last as long as an OEM Toyota finish, but they can make it shiny and newish looking for 10+ years.
    For less budget they do not remove glass but tape around it, same with trim. This method usually results in chipping along edges over time and paint never quite looks right at seams.. $2-3k I would guess. Usually starts to look like shit after 5 years.
    Maaco will spray it for less than $800. Very low quality. You're lucky if they even use primer. No sanding, no body work. It'll look like trash and every chip will show through the new paint as a little indentation. This is what most people do on a high mileage beater that they don't care about or are looking to sell quick. These paint jobs look like shit on day one, and way worse after a year or two.
    Regardless of where you go, body work is expensive if done right. Every little dent repair is a couple hundred bucks minimum.
  4. Mar 22, 2022 at 4:18 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    A lot of variables as others have stated but if your talking door jams and behind the cab I think your looking at close to 8k
    Have you considered a wrap job?
