Corroded Electrical Unit - Unknown
Discussion in '2nd Gen Tundras (2007-2013)' started by happy-owner, Feb 14, 2020.
  1. Feb 14, 2020 at 5:58 AM
    happy-owner
    happy-owner [OP] New Member
    Mark
    2008 Tundra SR5 V8
    2008 Tundra SR5 V8.
    Please help me identify this part. It's quite corroded. It's located on the inside of the frame near the rear driver side wheel, above the axle. There are two electrical connectors that go unto a wrapped bundle, which also contains the wheel speed sensor wires. But the wheel speed sensor wires do not appear to be connected to this particular unit.
    I will order and replace this unit as soon as I can find out what it is.
    Thank you.
  2. Feb 15, 2020 at 3:47 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    9C8E3E08-7423-42CE-ADC5-A8018D464DA2.jpg Putting my rear swaybar on today and remembered your question. He is a pic of mine. 2008 limited nonflexfuel, 5.7.
  3. Feb 15, 2020 at 4:03 PM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    It looks like there is an additional layer of protective material on the OP one although it is very corroded/rusty as well.
  4. Feb 15, 2020 at 4:05 PM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    :eek: That looks like it came from the Titanic. Jokes aside it does look like the fuel pump controller.
    TheBeast, ZappBrannigan and bleach like this.
  5. Feb 15, 2020 at 4:05 PM
    https://www.sparksparts.com/oem-parts/toyota-computer-assy-fuel-8957034010
  6. Feb 15, 2020 at 4:06 PM
    Mnorris1206
    08 tundra
  7. Feb 15, 2020 at 6:00 PM
    Wsteven
    Wsteven New Member
    2007 White SR5 Single Cab
    Oh wow surprise that it still is working and seeing that it is a Fuel Pump control time to replace it for sure!
  8. Feb 15, 2020 at 7:05 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    If it still runs why mess with it. It's probably a good idea to get a spare when it finally gives up.
  9. Feb 15, 2020 at 8:11 PM
    Wsteven
    Wsteven New Member
    Almost agree with that but things like that like to go bad at the most undesirable times and it is something You know is going to go so it depends on how much you like to Gamble I guess.
  10. Feb 15, 2020 at 8:38 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Wow. Just wow. I can’t believe that thing still works!!!
    TheBeast likes this.
  11. Feb 16, 2020 at 5:29 AM
    happy-owner
    Mark
    2008 Tundra SR5 V8
    Your posts are very helpful. Including the one that mentioned the part looks like it was on the Titanic. After purchasing this truck, used, I noticed that there was a good deal of black undercoating sprayed on over corrosion. It appears that someone wanted to hide something. Maybe this truck sat in high floodwater near the ocean for a period of time in the past. Nevertheless, it's too late to do anything about it besides replacing parts one at a time. The next project will be to replace the emergency brakes, cables, and swivel arm.
    I see, according to some posts, that this part has several name variations: Fuel Pump Control, Computer Assembly Fuel, and FUEL PUMP CONTROL MODULE. And I'm seeing that some of these units are discontinued. I'll begin my search this morning. Maybe by this afternoon, I will have found a replacement.
    Thank you to all who posted a comment, and to HunterTN who posted the picture.
    bleach and NewImprovedRon like this.
  12. Feb 16, 2020 at 6:18 AM
    huntertn
    huntertn New Member
    Tennessee
    Mine is a 5.7 V8 if you have a 4.7 it may be a different number.
    You might be able to find someone parting out a truck. I see some from time to time on Craigslist and FB Marketplace. If you needed a lot of knick knack stuff I would think the more you buy the better the deal. Of course a junkyard might do the same.
  13. Feb 16, 2020 at 7:19 AM
    vhstejskal
    Vic
    OP it may be worth checking with your local parts guy; there could be some parts that are compatible across multiple years or makes Lexus Toyota etc... especially if you need to find of a donor vehicle it may help net you something easier to find.
    @Roman the parts guru to see if he could chime in here.
    Roman and NewImprovedRon like this.
  14. Feb 17, 2020 at 6:02 AM
    happy-owner
    Mark
    2008 Tundra SR5 V8
  15. Mar 8, 2022 at 8:24 AM
    Christopher Banks
    Christopher Banks New Member
    Chritopher
    Tundra
    im wondering will this work on my 4.7 because it says its for the 5.7
