Correct Spicer Carrier Bearing for 1st gen tundra EXACT TOYOTA OEM
Discussion in '1st Gen Tundras (2000-2006)' started by 00TundraZ, Apr 30, 2019.
  1. Mar 1, 2022 at 12:10 PM
    #121
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
  2. May 11, 2022 at 10:28 AM
    #122
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    I called drivetrain america and per my vin he says part #211750-1x. Amazon has it but says it doesn't fit...is there an actual conclusion to what fits what what? Holy confused yes I read the thread still perplexed
  3. May 11, 2022 at 10:54 AM
    #123
    what is stamped on yours?
  4. May 11, 2022 at 10:56 AM
    #124
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    I don't know. I'm not by it right now. I assumed that I'd not be able to read a pn. But may stand corrected lol
  5. May 11, 2022 at 11:05 AM
    #125
    mine was prominently stamped on the side. Just had to clean it up a little to see it.
    Hi06silver[QUOTED] likes this.
  6. May 11, 2022 at 12:56 PM
    #126
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Nothing stamped into the metal except maybe n2.
    Nothing identifiable on the rubber either.
  7. May 11, 2022 at 1:29 PM
    #127
    OEM should have Toyota and the corresponding number in raised lettering on the rubber itself.
  8. May 11, 2022 at 2:26 PM
    #128
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Found it. Just makes things more fucking confusing unless the guy at drivetrain was wrong by Vin...
    37235-35030 stamped on. Wasn't shiny enough to see so a marker helped.
    According to their site he's misinformed from their system or the vin.
    KNABORES likes this.
  9. May 12, 2022 at 9:37 AM
    #129
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    After finally finding the OEM part # on the old rubber and today's research circles I have finally found some useful info. I called drivetrain again Gabe them the part number. This time a different bearing came up. 5002007. This IS the correct one for a 2006 tundra 4x4 DC. According to the guy that answered the phone the only difference between the 5002007, 211750-1x and another one can't remember part number that frequently come up is : 5002007 is sealed on both sides the other 2 are only sealed on one side or the other depending on the orientation installed respectively. They would all actually work.
    tvpierce and KNABORES like this.
  10. May 19, 2022 at 3:57 AM
    #130
    tvpierce
    tvpierce Formerly New Member
    Maine
    It's curious that they would have ever called for a non-sealed bearing in this application. :confused: It's exposed to a pretty harsh environment.
    I'm about to order one for my 2000 AC/4WD. It would seem the fully sealed version would be the best choice for durability/longevity, wouldn't it?
  11. May 19, 2022 at 4:07 AM
    #131
    Yes, the 4WD version is sealed on both sides.
    tvpierce[QUOTED] likes this.
  12. May 19, 2022 at 4:10 AM
    #132
    My post #34 on this thread should have the part number for your truck, as it’s the same as mine.
    Hi06silver and tvpierce like this.
  13. Mar 28, 2023 at 10:54 AM
    #133
    importxpresions
    importxpresions New Member
    2001 SR5 AC Imp Jade Mica 2WD
    Blast from the past. Searching for an oem supplied support bearing. Crawled under the truck and mine was stamped pn 37235-14030. Can't find anything on that including a cross reference. Emailed Toyota (McGeorge) and there response is below:
    I have a 2001 Toyota Tundra V8 2WD vin XXXX. I need the drive shaft center support bearing, the mounted rubber one in between the two shafts. When searching on toyota parts I get 37230-5120 but the factory part installed parted is stamped Toyota 37235-14030. I can't find any information on the PN that is stamped on this bearing.
    "Per the VIN supplied 37230-35120 is the factory part number. The numbers on the actual parts are not always indicative of the actual part number that Toyota uses"
    Just a heads up to anyone else. I crawled under the truck and left more confused with that part number lol
  14. Mar 28, 2023 at 11:46 AM
    #134
    If you search for the part in quotes at Google, you get a few sellers, but none I'd trust. There's a few threads that come up too, including this one:
    https://www.customtacos.com/threads/need-correct-carrier-bearing-part-for-1999-2wd-tacoma.197657/
    That thread suggests yours may've been replaced with a Chinese part? Or that it's a part typically used on Hilux, which you can find all over Central America (Mexico, CR)
  15. Mar 28, 2023 at 11:56 AM
    #135
    Oh and this Alibaba page: https://www.alibaba.com/product-detail/high-quality-37235-14030-Drive-Shaft_1600340665103.html
    Offers up a possible succession number of 37230-28010 which points to a '91 - '97 Toyota Previa (link) :rofl:
    Then this Alibaba page: https://eezee.sg/product/propeller-...g-p-n-37235-14011-for-toyota-hilux-60faef492b
    Offers up a possible succession number of 37235-14011 which points to no matching product! (with or w/o the hyphen).
    I found another page that equated it with 37230-35080 but that only fits '83 - '85 Toyota pickups.
    I would just go with whatever the dealership tells you is correct, frankly.
    JasonC. and importxpresions like this.
  16. Mar 28, 2023 at 12:35 PM
    #136
    importxpresions
    Once my searching yielded a link to alibaba I ended it there haha. It'll get replaced with a Spicer unit. It looked to be in good shape, aside from the excessive play in it.
    shifty`[QUOTED] likes this.
  17. Mar 28, 2023 at 1:09 PM
    #137
    Define "excess play"?
    It's normal for a carrier bearing to have upwards of an inch of play, maybe more. There is some room intended for movement. Mine only has 75k miles on it and at least 1/2" of play, if not a little more. General rule of thumb is, if it's not causing major problems, and it's still tight, rubber still good, leave it alone.
  18. Mar 28, 2023 at 1:22 PM
    #138
    importxpresions
    Mine has probably a 1/2" upward/downward play in it. I looked in my copy of the pdf digital fsm and couldn't find a spec for how much play it should have. I assumed that the play in it was due to wear. My driveshaft experience is limited so i've never dealt with this type of bearing before.
  19. Mar 28, 2023 at 2:22 PM
    #139
    Honestly, driveshafts and the driveline is one of those things: If it ain't clearly broke, don't fix it. Or put more simply, unless there's a very clear problem, don't F with it. Especially if you don't know a ton about drivelines, there's a couple of small mistakes a lot of people make that can cause grief. Keep things lubed and keep rolling.
    When I say mine has a 1/2" of play, that's what I mean. I can push it about 3/8" - 1/2" in any direction. Yes, that may seem like a lot of slop. If my lightly used truck with under 100k mostly-old-man-usage has that much play, and others on here have commented theirs does too, move on to something that's actually hurting.
    And whatever you do, never assume vibrations in the driveline are related to the carrier bearing. There are many other things that can cause, and are often responsible for, vibrations. Check the carrier when you grease your zerks (if 4WD) to ensure the housing is torqued down and the rubber isn't totally gone.
  20. Mar 28, 2023 at 4:19 PM
    #140
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    This should help clear it up (read the review by JCW) -
    https://www.amazon.com/Spicer-5002334-Center-Bearing/dp/B00GAPFESW
  21. Mar 28, 2023 at 5:42 PM
    #141
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  22. Mar 28, 2023 at 6:12 PM
    #142
  23. Mar 29, 2023 at 12:32 AM
    #143
    abcinv
    Tommy
    South of ATL
    Agreed, just read the review :thumbsup:
  24. Mar 29, 2023 at 7:25 AM
    #144
    importxpresions
    Thanks all for the insight, great information.
  25. Jan 30, 2024 at 4:17 PM
    #145
    poormxdad
    poormxdad New Member
    2012 Tundra Grade Four Door 4.6 4WD/ 2007 Sequoia SR5 Leather
    Folks,
    This was a very informative thread, so I'm piling on...
    Our 107,000 mile '04 Tundra has recently developed a small vibration I can feel in the steering wheel, but only in gear when stopped--the buzz goes away in Neutral or Park. There's also a bit of a vibration at speed. It seemed to have started when the temps went down. I did a timing belt/water pump/serpentine belt/radiator/etc. job on her back in March. She runs well. I started putting more miles on her a couple of years ago when I began towing my car to the track. My searches for "vibration that goes away in park" led me to this thread.
    I crawled around underneath her and inspected the carrier bearing, the driveshaft, trans mount, steering, and whatever else I could put a light on. The carrier bearing looks good--there are no tears, in fact the rubber looks to be in pretty good shape. The bearing doesn't show any signs of leakage. However, it does seem to be at the bottom of its available travel. I can move it upwards and side-to-side a bit, but I really can't pull it down, but it was about 40 degrees outside. I did not get around to inspecting the motor mounts.
    Is it time to replace the carrier bearing? Anything else I should look for?
    Thanks,
    poormxdad
  26. Jan 30, 2024 at 4:49 PM
    #146
    It's likely not the carrier bearing. You may want to create a new thread so we can work through diagnostics with you.
