Correct rear shocks with this setup?5125's(icon leafs/shackle)
Discussion in 'Suspension' started by Truckee Tundra, Nov 5, 2024.
  1. Nov 5, 2024 at 1:23 PM
    Truckee Tundra
    Truckee Tundra [OP] New Member
    Jp
    2013 Tundra Crewmax Platinum
    Okay I just redid my front end with 6112's on top setting and a 1" coachbuilder shim. Now I'm getting ready to do the rear.
    Currently I have very tired 5160's on a 1.5" block and blown out leaf springs...
    I'm thinking ditch the blocks for toytec 1.5" shackles and swap in a set of icon rxt springs. The leafs supposedly provide 1.75" of lift. So around 3" of lift right?
    That means I should change the shocks to these 5125'?- BILSTEIN TOYOTA TUNDRA 3" LIFT REAR 07-18
    5160's are only for 1.5" lift. Plus, I don't offroad as much as I used to so I can't justify the $300 cost difference.
    I've been trying to get ahold of Nexgen for days to ask about it, but their voicemail is full and I have 2 unanswered emails.
    I haven't seen those 5125's mentioned anywhere before so I'm turning to you guys for help, thanks.
  2. Nov 5, 2024 at 2:10 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  3. Nov 5, 2024 at 2:28 PM
    Truckee Tundra
    Jp
    I hadn't seen those springs yet, cost is about the same at the end. I was looking at the icons over alcan/deavers because they can get reconfigured if I ever decide to put on a camper. Realistically that probably won't happen, so the ironman's are a contender...
    Looks like you're confirming those 5125's are the right part number for that amount of lift?
    I thought they were right, but didn't want to find out otherwise...
  4. Nov 6, 2024 at 10:42 AM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Everything I could find says they work with a 3 inch lift, they just are not "Tundra" specific valved but work just fine.
    I had the Ironman rear leafs on my 17 and they were very nice. I want to say they are made by Dobinson, just rebranded for Ironman.
  5. Nov 7, 2025 at 7:40 PM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    Trying to find out information, will 5125 Billie’s fit our rigs?? Need shocks and cl has a deal. What do we know? That’s a big Friday thanks
