Cooler systems for supercharge cars
Discussion in 'Performance and Tuning' started by mohd.darmaki, Aug 27, 2018.
  1. Aug 27, 2018 at 1:18 PM
    mohd.darmaki
    mohd.darmaki [OP] New Member
    Mohammed
    1794 platinum Black model 2017
    Honey-D kit , sos performance lowering kit , TRD daul exhaust , front & rear sway bars ,TRD Air Intake , TRD Pro Grill/Hood Bulge , 2018 Front lights/ Fog lights , Fuel marveick wheels 20x12 negattive44 with grapper 305 tires , Glossy Black Door Handles Cover Half mirrors tailgate w cam, Tundra Steep foot; Fridge center console ,Tundra black Tailgate Trim Bezel , 4x4 Tundra tail , cup olders , Disk Brake Calipers Cover , TRD Liscense Plate , kuda mount black, Super Charger
    guys
    I need help from experts my car is supercharged , headers , gear valve , HK air intake , trd dual exhaust custom honey D kit plus big wheels 20x12
    My Tundra is 2017 (candian spec) with all this upgrade mentioned up
    These are my questions
    1. Best transmission cooler fan / should get it with fan american spec they come with an extra small black transmission cooler front left candian doest come with this setup.
    2. Is there a fan which sit perfect in front of the supercharger radiator
    3. Do i need to add an extra coolers if yes pls recomind to me like automatic transmission fluid, engine oil etc...
    In dubai the weather is hot and sometimes i drive long travel and noticed the heat thremo goes up
  2. Aug 27, 2018 at 1:40 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    not much help but just had to say that truck is sexy. well done putting that together. bet it's a total hoot to drive.
    1UPPER and mohd.darmaki[OP] like this.
  3. Aug 27, 2018 at 1:57 PM
    mohd.darmaki
    Mohammed
    Thank you sir yes its but spent lots of money
    smslavin[QUOTED] likes this.
  4. Aug 27, 2018 at 2:10 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    What issues are you actually having? Can you explain when/where/driving conditions/etc?
  5. Aug 27, 2018 at 2:41 PM
    mohd.darmaki
    Mohammed
    Hello sir
    Till know there no issues but the weather here its to hot i have been hearing from people to install extra transmission oil cooler fan and to get engine cooler system so am not sure do i need these extras i have been googling and i found this company the question should go for it as transmission oil cooler fan and what should i get for the engine oil to coolet up
    B&M Hi-Tek Engine/Transmission Oil Cooler w/ Fan
  6. Aug 27, 2018 at 3:08 PM
  7. Aug 27, 2018 at 3:37 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    welcome to the club :spending: :D
  8. Aug 27, 2018 at 3:38 PM
    mohd.darmaki
    Mohammed
    Thanks for the link this site is amazing i have been learning alot and seeing good things what you guys doing so your suggesting me to install an extra tranmission oil cooler or not
  9. Aug 27, 2018 at 3:44 PM
    This is an amazing site.
    Enjoy your search for perfection.
    Following.
  10. Aug 27, 2018 at 3:47 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Have you ever considered using water wetter to run cooler? I used this years ago when my sport bike would over heat in the summer. It helped significantly with running cooler in the heat. BF52A83B-35D9-405A-B991-72B8073138E0.jpg
    ColoradoTJ and mohd.darmaki[OP] like this.
  11. Aug 27, 2018 at 3:56 PM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    Supercharged, TRD Dual Exhaust, Bilstein 6112's/5160's, TSS wheels, Toyo AT Xtreme 285/60R20, LED bed lights, Hellwig sway, PopNLock tailgate lock
    I installed this Ultra-Gauge to watch my trans temperatures, awesome tool. Mine appear to be to damn hot as I have been watching it constantly.
    This is driving on the highway up a light incline in 85-90 degree weather with my thermstat pinned open. Gets to 200 (T1) / 225F (T2) towing a 4500lbs trailer toward Eisenhower. I am also looking to supplement the trans cooling but need to not block the Supercharger radiator, condenser or engine radiator.
  12. Aug 27, 2018 at 3:57 PM
    mohd.darmaki
    Mohammed
    I will give a try
    1UPPER[QUOTED] and ColoradoTJ like this.
  13. Aug 27, 2018 at 4:28 PM
    Nick T
    Nick T New Member
    Nick
    1. 2017 tundra have the transmission cooler on the top rows of the ac condensor (the seperate trans cooler you see are on older tundras)
    2. An extra fan will not cool your supercharger heat exchanger anymore then stock, you will always be 20°F above ambient. Use a killer chiller or similar to cool more.
    3. Extra coolers are only needed if you tow, what are your transmission fluid temps, engine oil temps ?
  14. Aug 27, 2018 at 11:03 PM
    mohd.darmaki
    Mohammed
    Hello sir
    Hmmm i believe its normal transmission fluid temps, engine oil temps?
    The point was is there any extra after market coolers ; liquids ... which can be installed to drop any kind of temp in the car
  15. Aug 28, 2018 at 2:14 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Tundras.com helping Tundra owners worldwide like a boss!
