Coolant pooling on top of radiator
Discussion in '1st Gen Tundras (2000-2006)' started by NomadicFrog, Jul 8, 2022.
  1. Jul 21, 2022 at 11:35 AM
    NomadicFrog
    NomadicFrog [OP] Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    Yeah, I didn't know what would happen, since nobody really talked about it, so I plugged them just in case.
    As for the timing belt, not ideal, I know, but in the week before my timing belt appointment I had a 1000 mile road trip in Arizona heat a long way from what passes for civilization, so I needed to get the radiator fixed. I'm not usually the guy that goes out into a potentially dangerous environment with a known serious issue. (Unlike my buddy on that trip whose Tundra has only been firing on 7 cylinders for a while. "Funny" side note: he broke a front axel on the trip...ratchet strapped it out of the way and kept going. I don't have his level of risk tolerance...)
  2. Jul 21, 2022 at 11:55 AM
    Somewhere between 1 and the point in 2 where you open the petcock, I'd probably jot down to pop the radiator cap off. Faster drain time :D
    I think it's probably easier if you just pop off the shroud too, but I haven't had to do it so I'mma STFU. :rofl:
  3. Jul 21, 2022 at 12:10 PM
    NomadicFrog
    Mark
    Flagstaff, Arizona
    Thanks, I edited to add that - as well as a note to make sure everything is sufficiently cool enough to work on safely.
    But, to reiterate for any other novices finding this thread: please use some reference besides my post as the main source of instructions. ;)
    shifty`[QUOTED] likes this.
  4. Jul 21, 2022 at 2:29 PM
    Bilgepump
    Bilgepump New Member
    '06 Sequoia Limited 4.7L VVT-i 2WD
    All Stock
    NomadicFrog,
    Next time around, we can step you thru the process of changing your timing belt, water pump, pulleys, and tensioner. You can save yourself quite a bit of money. Just work slow and methodical....it is easier than you think.
    NomadicFrog[OP] likes this.
