Coolant leak
Discussion in '1st Gen Tundras (2000-2006)' started by robabeatle, Nov 20, 2022.
  1. Nov 23, 2022 at 6:55 PM
    #61
    robabeatle
    robabeatle [OP] New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    There isnt a lot of difference in those water jugs because there is a mix of each drain per jug. I watched the last drain and it was much cleaner, not exactly like water but not too bad either.
    Took it for a drive and no leaks and temp looks good. This is another one of those jobs that just feels good to have completed.
    FrenchToasty and shifty`[QUOTED] like this.
  2. Nov 23, 2022 at 6:57 PM
    #62
    robabeatle
    AZ
    Breh, that looked like the bottom of my drain bucket as well. I think it might have been the OG radiator from 2002 with 188K miles.
    FrenchToasty likes this.
  3. Nov 23, 2022 at 6:58 PM
    #63
    robabeatle
    AZ
    My new one was pristine from Rock Auto .
  4. Nov 23, 2022 at 7:02 PM
    #64
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I ordered my rad from scamazon last year (before I knew better) and it was messed up pretty good. So i returned it and they sent another. Also damaged had to return. I ordered from Rockauto and it was perfect.
  5. Nov 23, 2022 at 7:56 PM
    #65
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'd be shocked, and eat one of my shoes if you got that kind of shit out too.
    Are the later first gens an iron/steel block too or are they aluminum?
  6. Nov 23, 2022 at 8:00 PM
    #66
    shifty` You can call 1 (800) PP5-1-DooDoo
    My VVTi is cast FE block with AL heads if I'm not mistaken. I think the 1UZ was AL block. Not sure about 3UZ. Probably a question for @empty_lord, I'm too lazy to look it up. :rofl:
  7. Nov 23, 2022 at 8:38 PM
    #67
    Mr Badwrench
    Mr Badwrench New Member
    I've used NAPA brand before and was pretty impressed. It wasn't a recore, so brand new. It was for Tacoma with a manual transmission and no transmission cooling lines, so some added cooling capacity in absence of hot transmission fluid. That was a bonus.
    I know you already purchased a good brand (op), but for anyone in need, you may consider this option, for what it's worth.
    Denson, or Toyota brand, is the way to go, but if you're short for cash (who isnt?), then NAPA can probably help.
    FirstGenVol and robabeatle[OP] like this.
  8. Nov 23, 2022 at 9:01 PM
    #68
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    1uz and 3uz are all aluminum. 2uz is the only iron block.
    One day I’ll do a 3uz swap in the tundra to shave some weight and gain some power… since all the 2uz shit will bolt up.
    shifty`[QUOTED] and bmf4069 like this.
  9. Nov 24, 2022 at 8:42 AM
    #69
    Interesting on the 3UZ. Too bad my engine is so low-mile, else the 3UZ swap could be interesting....
    Only reason I know about the 1UZ is because I lusted after the '98-'00 SC 400 when I was younger. Back when I used to like that style, ala 240 SX etc. was incredible. I'd still take an SC 400 today if the price and condition were right, it's still a 2-door funbox, but I'd really hafta fight with the desire to LS-swap it and upgrade to MT.
    Tundra2 and FrenchToasty like this.
  10. Nov 24, 2022 at 8:50 AM
    #70
    empty_lord
    05 rollover special
    yea the 3uz for whatever reason makes more horsepower and more torque than the 4.7.. in similar powerbands too.. 10 extra ft lbs. 90% sure its all cam related. maybe the kelfords would fix that..
  11. Nov 24, 2022 at 8:56 AM
    #71
    empty_lord
    05 rollover special
    Yea 300hp @ 5600rpm vs 271 @ 4800 and 325ft lbs @ 3400 rpm vs 315 @ 3400 rpm.
    Tundra2 and shifty` like this.
