Continuous left CV axle break
Discussion in '2.5 Gen Tundras (2014-2021)' started by TonyTSS16, Jan 19, 2020.
  1. Jan 19, 2020 at 8:04 PM
    TonyTSS16
    TonyTSS16 [OP] 16 TSS
    Alabama
    16 Tundra 4or TSS
    6in Rough Country suspension lift, XD wheels, FS Destination MT 35x12.5x20. Backlift hard tonneau cover w/tool box upgrade. 2 fold out wheel well tool boxes/coolers. 50%windshield tint, 15% tint all other. Upgraded speakers throughout.
    I will say it rides great, just nervous about locking it in 4wd now. I dont get mine off road much myself, but if I decide to go somewhere, I want to know I have all resources working to get me out. Lol
  2. Jan 19, 2020 at 8:08 PM
    And that pic you posted, I see they cut your rear cross member out, apparently I spoke with RC several times, cause mine is not cut as per the online instructions, they say I have an older version lift kit, and I do have the diff drop kit as well, and my CV axle angles are like yours, and I'm on stock struts, like stated earlier I have the older version struts that RC put out, but have to put on, and if and when I do off road I try not to turn too sharp
    TonyTSS16[QUOTED][OP] likes this.
  3. Jan 20, 2020 at 10:24 AM
    Mark18TRD
    Mark18TRD New Member
    Mark
    Cypress TX
    2018 White Tundra TRD
    6" RC lift, 20" Fuels, RC rear bumper w/ lights, RC front bumper light bar, (NSV light bar ordered and on the way)
    so i have the same RC lift you do as well, frame chop for the diff drop .......but i also run factory suspension in the front with an RC strut in the rear only. also in the front are spacers/blocks for allowing the factory struts to work/fit, appears to be the only difference that i can see on our setups.
    i do use four wheel drive quite frequently but i try to baby it as my younger years proved lessons on how quickly you can tear these things up. i haven't had any issues yet on cv axles and hope it stays that way. hope this info helps you out.
    p.s., haven't been stuck yet!:mudding:
    R0Q7xSHPTr+pV+gnVXHKmw.jpg J1iXfRKaQr+7+870e+f5hQ.jpg y6wYwnT4TnSMwnR+DUFENw.jpg iN5sg1tVT0Woe26axz6BTg.jpg sDmFTe0ZQ2O%xI5kAWKQYg.jpg 6u7KBytMROqCS3PmP9VMUA.jpg
  4. Jan 20, 2020 at 12:14 PM
    What does the rear cross member chop do anyways?
  5. Jan 20, 2020 at 12:59 PM
    Mark18TRD
    Mark
    Cypress TX
    hey Adam, i'm no installer so i'm not entirely sure. my only guess is to allow a straight path for the driveshaft instead of requiring a drop kit for it, allowing for no extreme angles.
    TXRailRoadBandit73 likes this.
  6. Jan 20, 2020 at 8:21 PM
    Elduder
    Elduder New Member
    Not for the CVs, aftermarket UCAs would potentially allow for more droop which would make your issue worse.
  7. Jan 20, 2020 at 8:25 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    You cut the subframe to bolt in the drop bracket. The drop bracket is where the LCA attaches, new alignment cam location, etc. This is why you actually lose ground clearance when doing a drop bracket lift. A 3" on 35s has the same if not better ground clearance than a 6" on 35s.
  8. Jan 20, 2020 at 8:41 PM
    Well as I stated earlier, I spoke with RC and I have an older kit version and the RCM is not cut
  9. Jan 20, 2020 at 8:47 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Ok....I was only answering the question you asked.
  10. Jan 20, 2020 at 8:49 PM
    boatzNhoez
    boatzNhoez Owner / Operator of MS MOTORSPORTS
    Cypress, CA
    2019 Platinum CMSB LT
    Too many hahahaha
    If you guys keep busting axles then maybe you should look into the RCV units.
  11. Jan 20, 2020 at 9:19 PM
    Yes I wanted to know the purpose of them being cut, thanks!
    14burrito[QUOTED] likes this.
  12. Jan 20, 2020 at 9:30 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Did you call RC and ask them WTF?
  13. Jun 10, 2021 at 1:45 PM
    Joeystjean
    Joeystjean New Member
    Joey
    2014 Platinum crew max
    TRD intake/exhaust/light bar/bullydog
    Is there any solution found? I am having the same CV issue. Have looked at other lifts installed and they are not extended out like my axle is.
  14. Jun 10, 2021 at 2:01 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Joey your kit is missing the bumpstop spacers
    snivilous, Joeystjean and des2mtn like this.
  15. Jun 10, 2021 at 2:37 PM
    2mchfun
    Wholly hell, lucky to not have broke the neck off those shocks!!
    Joeystjean and Hbjeff[QUOTED] like this.
  16. Jun 10, 2021 at 2:43 PM
    2mchfun
    Dude, don't drive anywhere before you get some serious extensions on the front bump stops or you might be buying two new shocks because when they compress to the limit and take all the force the necks will bend or break off.
    Joeystjean[QUOTED] likes this.
  17. Jun 10, 2021 at 4:17 PM
    Joeystjean
    Joey
    Working on the bump stops not sure why they were not installed. I should have just done the kit myself. It’s been a nightmare since I picked it up!
    2mchfun likes this.
  18. Jun 10, 2021 at 4:32 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    If you did bottom out hard, it might bend the shock and shorten it so your CV angle wouldn't be so bad :D
  19. Jun 10, 2021 at 4:45 PM
    #49
    Joeystjean
    Joey
    :)You make a valid point
  20. Jun 10, 2021 at 7:17 PM
    #50
    Elduder
    Elduder New Member
    What lift is this, the perch on that shock looks very high.
  21. Jun 11, 2021 at 1:44 AM
    #51
    Joeystjean
    Joey
    Same as the OP 6” Rough country
  22. Jan 23, 2022 at 5:14 PM
    #52
    capt754gmail.com
    capt754gmail.com New Member
    Greg
    16’ Tundra
    6” RC Lift 35-12.59.20 MT’s Fuel D693
    Tony Tss16
    I’m having same issue. Well local 4x4 shop is footing the bill. I’ve broke 5 now. Did you ever get the issue resolved. Same lift, same struts, and shock upgrades. Local shop is in talks with RC but everyone is just scratching their heads at this point. Please email me so we can talk. Capt754@gmail.com.
    Or anyone else that has a fix or resolution for this problem. Email me please. Tired of my truck being in the shop.
  23. Jan 24, 2022 at 6:16 AM
    #53
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Those angles in that picture look really steep. Maybe the RC shocks are allowing it to droop down too far
    also- what is breaking, the inner joint? Maybe the rc lift doesn’t locate the diff correct side to side sometimes?
  24. Jan 24, 2022 at 6:34 AM
    #54
    2mchfun
    Maybe the LCA alignment cam bolts were torqued super tight with the truck off the ground basically binding the bushings. Those should only be torqued with the truck on the ground.
  25. Jan 25, 2022 at 1:55 PM
    #55
    falcon313
    falcon313 New Member
    tyler
    2014 Tundra Crewmax
    6 inch pro comp lift
    OK has anyone figured anything out on this I bought a 2014 and am having the same exact issue. My lift is a 6 inch pro comp 3 cv axles divers side in 3 months. my 4x4 guys are looking into it now but they are scratching there heads as to why its happening.
  26. Jan 25, 2022 at 2:11 PM
    #56
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Which part is breaking, inner joint?
  27. Jan 25, 2022 at 2:22 PM
    #57
    falcon313
    tyler
    2014 Tundra Crewmax
    mine is shearing at the top near where it enters.
    Hbjeff likes this.
  28. Jan 25, 2022 at 2:24 PM
    #58
    falcon313
    tyler
    2014 Tundra Crewmax
    this morning i was able to pull the upper part completly out spline and all and then rest the bottom part on the lower arm and limp it in to the 4x4 shop.
  29. Jan 25, 2022 at 2:28 PM
    #59
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm running 7.5" and here is my CV angle. Still on OEMs.
    Screenshot_20220125-162702_Gallery.jpg Screenshot_20220125-162616_Gallery.jpg
  30. Jan 25, 2022 at 2:32 PM
    #60
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    sounds like the new wheel hub is too far from the diff if it is pulling on the inner joint? Maybe the manufacturing tolerance of the knuckle/drop bracket is not to oem dimensions?
