Console vault half safe
Discussion in '2.5 Gen Tundras (2014-2021)' started by belairbrian, Jan 11, 2023.
  1. Feb 10, 2023 at 10:32 AM
    #91
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    It should fit, 17mm is real close to 5/8".
    MedCityMoto[QUOTED] likes this.
  2. Feb 12, 2023 at 9:49 AM
    #92
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    So I got around to putting this in today!
    It's slightly too long, but! I reused the additional hardware from the original lock as a small spacer, and it works perfectly now.
    Edit: to be more specific, I removed the old lock, took the black spacer and the slightly-larger-diameter nut on the lock, put it through the lid, and put the included locking nut on. Cranked down to fairly tight, and everything lines up nicely. Would recommend programming it to your phone via the eSmartlock app, getting your fingerprints on it, and then installing it physically. You can add plenty of fingerprints, put mine and the fiance into it, works pretty darn quickly. Took a video but unsure how to post it up to these forums.
  3. Feb 12, 2023 at 9:57 AM
    #93
    MedCityMoto
    Wallygator and TaquitoBandito like this.
  4. Feb 14, 2023 at 11:06 AM
    #94
    TaquitoBandito
    Joel (AKA Bif)
    My console vault came in yesterday. I ordered the top of the line lock since it was on sale and I have to say that the lock works. It spins if you don't have the correct combination. I know this because when I was resetting the combo, the paper clip must have slipped out of the reset button, and I have no idea what it set to. After a few hours of trying to get it to unlock last night, I wrote Console Vault.
    They got back to me early this morning, told me how to drill it out and offered to send me a new lock. The kicker is that they also offered to set the combo for me so I wouldn't have to try to do it again (probably recognizing that I'm an idiot and I'll most likely screw up the new one too). All of this for free.
    If that's not customer service, I don't know what is.
  5. Feb 14, 2023 at 11:41 AM
    #95
    MedCityMoto
    See now that's what I like to hear about. I feel good recommending a business that's good to their customers.
  6. Feb 14, 2023 at 6:34 PM
    #96
    Rangers
    Rangers New Member
    Joe
    Oklahoma
    2017 Bad Barcelona TRD Pro
    TRD sway bar
    I had a different experience with console vaults customer service.
    I accidentally ordered the CV with the key. I meant to get the combo lock, same price.
    My mistake and when I emailed CV telling them about my mistake they sent me a link to buy a different lock and told me it was easy to swap the locks when I received the one I bought.
    I was hoping to swap locks with them but it's not really a big deal, Ill just keep the keyed lock.
  7. Feb 14, 2023 at 6:52 PM
    #97
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    How did you remove the tray brackets? They look like rivets, won't go in without removal.
    Anyone else experience this? Or am I missing something lol.
  8. Feb 14, 2023 at 6:54 PM
    #98
    Wallygator
    I still have not heard from them regarding the damaged lock. It's been days.
  9. Feb 14, 2023 at 7:17 PM
    #99
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Tray brackets?
  10. Feb 14, 2023 at 7:21 PM
    #100
    TaquitoBandito
    Joel (AKA Bif)
    That's crazy - like I said, I wrote them last night using their contact form. They wrote me this morning and said to let them know if I was gonna drill out the lock. I wrote them back (had to use the contact form because you can't reply to their emails) and told them I was and asked how much a new lock would be. They wrote me back and asked if I'd like them to put in my combo for me and if the address was correct. I went back to the contact form and wrote them with the combo code and thanked them. Then I got another email from them saying they'd ship the lock out tomorrow. All of this within 20-30 minutes.
    I'd probably reach out to them again if I were you.
    Wallygator[QUOTED] likes this.
  11. Feb 14, 2023 at 7:22 PM
    #101
    OHwendTrd
    Josh
    21 SR5 3UR-FE
  12. Feb 14, 2023 at 7:28 PM
    #102
    TaquitoBandito
    Joel (AKA Bif)
    That's fancy - did you buy your Tundra new?
  13. Feb 14, 2023 at 7:29 PM
    #103
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Yeah, came installed.
  14. Feb 14, 2023 at 7:32 PM
    #104
    TaquitoBandito
    Joel (AKA Bif)
    I don't think I've seen that. It came with the felt tray then? Dealer add-on, I'm thinking. Crazy they riveted it there. Actually, before I speak any more about it, I'm gonna run outside and look at mine.
  15. Feb 14, 2023 at 7:33 PM
    #105
    Wallygator
    Wow! Ok I will try again then.
  16. Feb 14, 2023 at 7:35 PM
    #106
    TaquitoBandito
    Joel (AKA Bif)
    Yeah, I couldn't believe it myself.
  17. Feb 14, 2023 at 7:37 PM
    #107
    TaquitoBandito
    Joel (AKA Bif)
    @OHwendTrd I took a picture of the inside of my console. This is standard (minus the Kleenex):
    RobertD likes this.
  18. Feb 14, 2023 at 7:38 PM
    #108
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    I thought the kleenex's were for my tears. I won't be able to install my vault without removing them somehow.
  19. Feb 14, 2023 at 7:44 PM
    #109
    TaquitoBandito
    Joel (AKA Bif)
    Whenever I have a problem I shine my big 20000w @RainMan_PNW spotlight into the sky and he usually shows up with a pretty good solution.
    RobertD and Wallygator like this.
  20. Feb 14, 2023 at 7:46 PM
    #110
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Open to any solutions! Thanks guys
  21. Feb 14, 2023 at 7:46 PM
    #111
    TaquitoBandito
    Joel (AKA Bif)
    I'm guessing a rivet remover and some kind of goop that'll fill in the holes - if you get the full-size safe you won't need to worry about that though. Well, maybe a spot or two.
  22. Feb 14, 2023 at 7:50 PM
    #112
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Here is mine
  23. Feb 14, 2023 at 7:51 PM
    #113
    Wallygator
    Ok went back into my email, cuz something didn't seem right, and found it in the spam folder for some reason. They offered to send me a new lock. :thumbsup:
  24. Feb 14, 2023 at 7:52 PM
    #114
    TaquitoBandito
    Joel (AKA Bif)
    So much for me thinking I'm special. :(
    RobertD and Wallygator[QUOTED] like this.
  25. Feb 14, 2023 at 7:53 PM
    #115
    Wallygator
    You are special!!:cheers:
    Thanks for getting me looking for their reply!
  26. Feb 14, 2023 at 7:55 PM
    #116
    TaquitoBandito
    Joel (AKA Bif)
    Wallygator[QUOTED] and RobertD like this.
  27. Feb 14, 2023 at 8:03 PM
    #117
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    How far back do I need to read?
  28. Feb 14, 2023 at 8:06 PM
    #118
    TaquitoBandito
    Joel (AKA Bif)
    Sorry, I should have dimmed the spotlight a little. :)
    101 and then skip to 105.
    RobertD and RainMan_PNW[QUOTED] like this.
  29. Feb 14, 2023 at 8:09 PM
    #119
    RainMan_PNW
    Casey
    Clark County, WA
    That’s the port-installed option for a tray.
    The Gen2 came with a tray standard, and the “lip” for it was molded into the console. So many things in the gen 2.5 were a regression.
  30. Feb 14, 2023 at 8:14 PM
    #120
    TaquitoBandito
    Joel (AKA Bif)
    I think he wants to put in a console vault so he's trying to figure out if he needs to remove it and the best way to do it since it's riveted in. If he has to remove it, would you drill them out (the rivets) and then epoxy the holes?
