Console Cover and Wireless Tray
Discussion in '2.5 Gen Tundras (2014-2021)' started by idude00, Mar 7, 2020.
  1. Mar 16, 2020 at 6:54 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    mine was just done 2 days ago and pictures are of the install day. I assume with a heat gun I can get them to go away. I doubt you can pull it any harder then this. give it time I am sure it will stretch out. I honestly think the way they cut the leather is not good. Like the center cubby leather was not precut and is not long enough. Also not wide enough. I have a Vynil version of this I got on eBay and its a much better fit over all.
    First get a heat gun or better a hair dryer.
    Keep about 6 - 10 inches away as you go over wrinkle area.
    Apply Leather conditioner. Non Shiny if possible.
  2. Mar 16, 2020 at 7:04 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    Thank you @idude00. My Kershaw blade clip nicked the side of my cover and left me a nickel size hole. I guess now is the best time to upgrade. We'll see how it goes.....
  3. Mar 20, 2020 at 1:18 PM
    ZTundra
    ZTundra New Member
    ZACK
    Knoxville, TN
    2021 MGM Nightshade
    Did the wrinkles ever work themselves out?
    @SiberianTundra @idude00
  4. Mar 20, 2020 at 3:39 PM
    SiberianTundra
    Greg
    War Machine
    not really. I have not had time to put some heat to them. But Im sure they will.
  5. Mar 20, 2020 at 6:40 PM
    idude00
    idude00 [OP] New Member
    Ike
    2017 SR5 - TRD Off-Road
    I gave it a shot with a heat gun and I couldn’t get them out. They seem to be sewn in.
  6. Mar 20, 2020 at 6:47 PM
    SiberianTundra
    Greg
    War Machine
    perhaps we should contact the seller about it.
  7. Mar 20, 2020 at 6:52 PM
    SiberianTundra
    Greg
    War Machine
    here are their contacts
    If you need any assistance with your order, please email us at fewolford@icloud.com or call us at 5403209978
  8. Mar 21, 2020 at 10:42 AM
    SiberianTundra
    Greg
    War Machine
    here is the response I got: (Its a copy and paste of the email)
    Hello, Toyota used vinyl because of Installation issues , leather is durable but can be a beast to install
    important:leather has to be stretched tightly not laid on , (you will not rip it) the rough grain will smooth out when stretched
    What glue to use? (Dap Contact cement and a small acid brush will work best )
    * Work cover from center out only
    1: align center seam (center horseshoe area)on lid and locate a center on cover and lid , only glue where seams lay ( this way the leather is free to settle out)
    2: fold cover and glue outer edge seams only and where they lay ( double stitched area ) allow glue to dry
    3: carefully heat leather ( sunlight or hair dryer) grab leather with both hands , wiggle and stretch as you work seam over edge ( this will be down over edge . Seams will Not be square with edge but over )
    4 laststep Finish off lower edge , pull tight enough where cover is smooth
    5 you can also add a extra layer of thin foam on top of original base foam , old upholsterers taught me this trick , wrinkles are caused by not enough padding under loose cover
    6 :if all else fails I offer free installation or corrections if needed
    Box up lid and put a return label in box
    Ship to
    Wolfmans
    811 Cinnabar Road
    Christiansburg Va,
    24073
    Thanks
  9. Mar 29, 2020 at 8:32 PM
    SiberianTundra
    Greg
    War Machine
    well I redid it with memory foam added. I had 2 layers
    Visco Memory Foam Square Sheet- 3.5 lb High Density 1/2"x15"x15" and another 1/4"x15x15 ordered from Amazon
    https://www.amazon.com/gp/product/B076VMHKTN/
    worked great. Removed some wrinkles and pushed the leather out a bit. I used a professional heat gun as.I worked the leather.
    I will post pictures tomorrow.
  10. Mar 30, 2020 at 9:28 AM
    idude00
    Ike
    Please send photos, I want to know if this is something I'll be able to fix as well, heat gun isn't doing it for me.
  11. Mar 30, 2020 at 1:52 PM
    SiberianTundra
    Greg
    War Machine
    Ok here is the result of Foam and properly heated leather as I stretched. I feel like I should have used more glue on sides and such. But over all it is much better.
    Compare that to previous install I did.
    :duh:
  12. Apr 4, 2020 at 9:05 PM
    SiberianTundra
    Greg
    War Machine
    Ok I redid it for the 3rd time and its great now. I added more foam to the front of the arm and it looks better.
    idude00[OP] likes this.
