Consistent Engine Stall
Discussion in 'General Tundra Discussion' started by prm1502, Jul 31, 2021.
  1. Jul 31, 2021 at 8:23 PM
    prm1502
    prm1502 [OP] New Member
    Patrick
    2011 White Tundra SR5
    Hey guys, I have a 2011 Tundra that randomly cut out on me while driving a few weeks ago. Just driving along and then the engine suddenly stalls out. The electrical stays on and I can immediately start the engine up again with no issue. But then it will randomly shut off again.
    At first I assumed it was the fuel pump, so I replaced it. Didn't help. Cleaned mass air flow sensor. Nothing. Cleaned the throttle body. Still no luck. It shuts off when driving or if you leave it in park.
    No codes are showing up. I did however time it, and it consistently shuts off 1:04 after ignition.
    Anyone heard of this before? Thanks!
  2. Jul 31, 2021 at 8:56 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Maybe some kind of anti theft device?
  3. Jul 31, 2021 at 11:44 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Maybe the battery... and have your alternator checked
    GIN•OKUMA likes this.
  4. Aug 1, 2021 at 12:58 AM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    I’d test the alternator and battery.
  5. Aug 1, 2021 at 7:11 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Does it have an aftermarket alarm or remote start?
  6. Aug 1, 2021 at 11:43 AM
    prm1502
    Patrick
    No aftermarket parts...
  7. Aug 1, 2021 at 11:44 AM
    prm1502
    Patrick
    Yea, I assumed it was the fuel pump/filter so I already replaced it. No change
  8. Aug 1, 2021 at 11:45 AM
    prm1502
    Patrick
    It starts right up after it stalls. Doesn't feel like a power issue. I can do it numerous times in a row and the power feels consistent.
  9. Aug 1, 2021 at 12:15 PM
    blackdemon_tt
    Starter relay? Try bypassing it see if it solves your issue?? If it does replace it..
  10. Aug 2, 2021 at 5:33 AM
    blanchard7684
    blanchard7684 New Member
    Disconnect battery for a good while (half hour). Then reconnect.
    I'm in the anti theft category as well.
  11. Jul 27, 2022 at 5:39 PM
    Abos
    Abos Long live 5.7L V8
    2014 SR5 Crewmax
    Did you ever figure this out? My truck has done this a couple times now. Happened 3 times Sunday and once today. No codes or anything. Sunday, I cleaned my MAF and made sure the battery cables were tight and not corroded. Happened again a half hour ago.
  12. Jul 27, 2022 at 5:53 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Are you on the same tank of gasoline from Sunday? Did you buy the gasoline from a station/shop you don't normally gas up at?
    Abos[QUOTED] likes this.
  13. Jul 27, 2022 at 6:10 PM
    Abos
    2014 SR5 Crewmax
    It is the same tank of gas as well as the same station I typically buy from. It's a Shell station.
  14. Jul 27, 2022 at 7:50 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Do you have an aftermarket security system?
  15. Jul 28, 2022 at 5:18 AM
    Abos
    2014 SR5 Crewmax
    No aftermarket security system. Stock airbox as well. I had checked the filter and it looks fine. I pulled the negative battery cable last night to reset the ECU and I think I'm going to clean the throttle body and put some fresh gas in it and see what happens. Super annoying. I'm hoping it's just bad gas but my gut tells me it isn't. Just annoying that I have no CEL to give me a starting point.
