Condensation on driver headlight
Discussion in 'General Tundra Discussion' started by YotaBro, Feb 2, 2021.
  1. Feb 2, 2021 at 7:03 AM
    YotaBro
    YotaBro [OP] This forum will make me broke
    Calvin
    FL
    Lots of shenanigans.
    I noticed this morning that my driver headlight has condensation in it but the passenger doesn’t. Any idea on how to fix this issue/ prevent it from happening again?
    I initially thought that I didn’t put the running light bulb back into place properly but that wasn’t the case. It was seated in perfectly snug.
  2. Feb 2, 2021 at 10:12 AM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    Usually, condensation on the inside surface means there is an opening to outside air. Either there is a damaged bulb seal, or the seal between inner/outer halves has a leak, or you have a stone chip in lens. Turning on the headlights should heat the headlight assy. up and evaporate the condensation, but if there is a leak to outside air, it will return.
    frichco228 and YotaBro[OP] like this.
  3. Feb 2, 2021 at 10:21 AM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Pull the headlight off to make inspection easier and to dry the housing out. Try adding a little bit of Vaseline to the bulb seal gaskets..
    YotaBro[OP] likes this.
  4. Feb 2, 2021 at 10:31 AM
    YotaBro
    Calvin
    FL
    Thanks, guys! I'll pull it apart this weekend
  5. Feb 2, 2021 at 10:34 AM
    Im leaning towards a bulb seal as well. It might be dried out from this hot a$$ state that we live in.
    MTRock and YotaBro[QUOTED][OP] like this.
