Compustar dc3 remote start problems
Discussion in '2.5 Gen Tundras (2014-2021)' started by Joehinojosa15, Nov 12, 2019.
  1. Nov 12, 2019 at 3:29 PM
    Joehinojosa15
    Joehinojosa15 [OP] New Member
    Jose
    2014 toyota tundra platinum
    Hi guys i just installed dc3 compustar with tl5 harness. I have a little bit of a problem. When i try to start truck using factory fob, its cranks but stays cranking. Someone has had this problembefore. Not a pro installer. Any help is good. Maybe I programmed it wrong. Thanks
  2. Nov 12, 2019 at 8:54 PM
    HazMatt
    HazMatt Go go gadget thingamajigger
    2019 MGM Tundra TRD Sport
    Toytec Boss Coilover suspension, JBAOffroad UCAs, Black Rhino Fury Gunmetal 18x9.5, Nitto Ridge Grappler 295/70R18, Access Vanish bed cover, spray-in liner, running boards, wind deflectors, Borla exhaust, Bedrug liner, rear floor storage, LED front turn signal bulbs, LED interior lights, TOGUARD dash cam, Yaesu FTM-400XDR HAM radio, Victory 4x4 18” modular bed rack, Tepui Autana 3 RTT
    I’m not familiar with this unit, but installed a number of aftermarket remote start alarms in the past. It’s been a while, but it sounds like it’s not getting a good read from the tachometer wire to indicate the engine has started.
  3. Nov 13, 2019 at 3:34 AM
    Joehinojosa15
    Jose
    Thanks for the response. Im gonna check that is that the same wire called sil (data). Im going of the tl5 wiring kit i bought. Im gonna post a picture. Thanks for your advice.
  4. Nov 13, 2019 at 4:22 AM
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    Sounds to me like your truck is not receiving the chip key bypass information. when you put a key that hasnt had the chip programmed in your ignition and try to start it this is what happens. it will crank and crank but never start. you probably missed a step that programs your chip code into the bypass.
    Rockgate likes this.
  5. Nov 13, 2019 at 6:22 AM
    Joehinojosa15
    Jose
    Prerunnerseth, thanks for reply, im gonna try and check my module again to check programming with the weblink i did probably miss a step. So yea i hit the 3x oem fob and it tries to crank but wont do nothing just crank and crank. Thanks guys ill check it and keep you guys informed thanks for the advice
  6. Nov 13, 2019 at 6:28 AM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    Following for a solution.. I have a different remote start, but the same problem. Mine worked for 8 months and now decided it doesn't wanna anymore, right when it's starting to get cold.
  7. Nov 13, 2019 at 6:38 AM
    Fsmith6505
    Fsmith6505 New Member
    2019 Tundra platinum
    I've installed two of these, you need to program the tach sensor. There are two ways to do this, depending on if you are using an oem keyfob or an aftermarket key fob. Instructions should be in your manual. If you're using oem Here's the instructionsScreen Shot 2019-11-13 at 8.37.06 AM.jpg
    plumber802 and SilverBullet77 like this.
  8. Nov 13, 2019 at 7:17 AM
    Joehinojosa15
    Jose
    Im gonna program it again maybe i did miss something when programing and that I remember i did not stay green at the end for confirmation of programming. Ill try that and ill let you all know thanks guys
  9. Nov 13, 2019 at 2:50 PM
    Joehinojosa15
    Jose
    Im using oem control Fsmith6505
  10. Nov 13, 2019 at 4:14 PM
    Fsmith6505
    That programming procedure above should program the tach sensor for you. Other checks would be to check all the plugs in the ecu and the obd and wires to make sure they're good. If the lights don't flash exactly as it says in the guide, it didn't take.
  11. Nov 13, 2019 at 4:17 PM
    Fsmith6505
    I was using oem key fob but bought a two way remote because the remote won't unlock while the starter is engaged. Have to use aftermarket remote or the key. Kind of silly. Easy add on with 3000' of range. Also put a drone mobile on and security add kit.
  12. Nov 14, 2019 at 2:40 PM
    Joehinojosa15
    Jose
    Tried to program everything even tachometer again and it cranks the it cranks again engine on then it turns off and the right turn signal turns on. Ive tried it over and over again. Im gonna have to take it to a tech to get it done.
  13. Nov 14, 2019 at 5:43 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Did you do the TPMS connection? I skipped it because I don't plan on using the OEM key to remote start.
  14. Nov 14, 2019 at 5:46 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Double check your wiring. This is the same RS I put on my truck. Even with the TL5 harness there are some manual connections necessary.
  15. Nov 14, 2019 at 6:27 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I’m the one who had this problem. But it was caused by the alpine maestro harness and the compustar harness fighting for data basically. Installer called compustar and they had to adjust the connection somehow.
  16. Nov 15, 2019 at 4:36 PM
    Joehinojosa15
    Jose
    On the wiring injust did the toms behind the glove box and the parking lights and the autolights from the switch in the steering column. Thanks for the help guys very appreciated
  17. Nov 16, 2019 at 5:36 PM
    Joehinojosa15
    Jose
    Its weird that both of my keys are black did a programming on other key everything seemed good but truck still gets stuck cranking. Im gonna check wiring again to make sure they sre in the right spot and go from their.
  18. Nov 16, 2019 at 5:48 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Can you try this? Put a key in the ignition, leave in off position. Then try remote start.
  19. Nov 16, 2019 at 5:51 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    If you want I can give you the phone number to the shop that fixed mine. They were on the phone with compustar for a good amount of time fixing it.
  20. Nov 16, 2019 at 8:33 PM
    Joehinojosa15
    Jose
    Im gonna try that tommorrow see what it does ill let you know thanks
  21. Nov 19, 2019 at 3:41 AM
    Joehinojosa15
    Jose
    What i noticed of tl5 it does not have a tachometer wire conmection and in other remote start kits almost all of them have the tach wire conmection.
  22. Nov 19, 2019 at 5:01 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I'm thinking it gets tach via data (OBD2).
  23. Sep 1, 2020 at 9:54 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Joehinojosa15, did you ever figure out why your Compustar remote starter did not start? I have the same issue after enabling the alarm features on the Compustar DC3. Now it will only cranks but no start. It was working perfectly until I enable the alarm feature. After resetting the module, it does not want to program to my tundra. DC3 module flash code SIL data not connected but tested the connection being good. Any help will be appreciated.
  24. Dec 8, 2020 at 8:13 AM
    SilverBullet77
    SilverBullet77 New Member
    Joseph
    KY
    2019 BR TRD Sport 4x4
    Hello all! Have a 19 SR5 TRD Sport. The wiring diagram is a little vague on whether to make the TPMS connection or not if you are using OEM vs aftermarket RF remote... seems like I may have to make the connection in the drivers side kick panel.. if I do this will I retain oem fob functionality as well as aftermarket fob? I want to use aftermarket for the increased range, but don’t mind if they both work... advice? @Rockgate
  25. Dec 8, 2020 at 12:28 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Connect tpms if you want both to work. Don't connect if you only using aftermarket remotes.
  26. Dec 8, 2020 at 5:41 PM
    SilverBullet77
    Joseph
    KY
    Thanks! So, I’m still having trouble... I flash it and get out there to program it to the truck and all I get is red flashes when I hit the program button... do I need to connect the hood switch sensor? It’s the only thing I haven’t made a connection with. But as for any of the programming... or reprogramming instructions I find, none of it works... :confused: I am missing something here. This has been going on for days fml. I wish I would’ve bought the start x or the tech 12 volts...:ballchain:
  27. Dec 8, 2020 at 6:16 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Did you hard wired the RDA, CANL, and CANH wires? Those are the three wires you have to splice. Rest is plug n play. This is for 2020 model. I assumed 2019 is the same.
  28. Dec 8, 2020 at 6:20 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Also no need to connect hood switch.
    SilverBullet77 likes this.
  29. Dec 8, 2020 at 6:40 PM
    SilverBullet77
    Joseph
    KY
    No mine is a little different. I have been having to borrow a windows PC and I don’t have it at the moment. I am working on getting some photos posted momentarily...
  30. Dec 8, 2020 at 6:49 PM
    SilverBullet77
    Joseph
    KY
