Completed: Steering rack replacement - 2WD version
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, May 6, 2024.
  1. Jun 7, 2024 at 5:25 AM
    shifty` Countin' and breathin', disappearin' in the fade
    I really need to get off my ass and re-clock my SPCs to +2. But yeah, there's a reason those numbers are in the suspension section of the megathread. Everyone that's used them has been super happy. @assassin10000 knows his shit.
    Weagle[QUOTED][OP] likes this.
  2. Jun 7, 2024 at 5:26 AM
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I guess I just need to keep reading the mega thread. So every time I think I absorbed it all I get another head scratching moment wondering why something wasn't there and then it turns out it was.
    shifty`[QUOTED] likes this.
  3. Jun 7, 2024 at 6:01 AM
    It's a living document, always changing. At least once a month I have someone text me, PM me, email me, or tag me in a thread to say, "Yo! You need to add this!" and I do. That's one of many reasons that thread is a community effort, not just a "shifty brain/observation dump".
    But Assassin's alignment numbers have been in there since the thread was started.
  4. Jun 7, 2024 at 6:27 AM
    Weagle
    Prattville, AL
    now that I'm getting more familiar with the truck, some of it will make more sense. And since it changes, I'll try to reread it every month or two
    For instance, I've never done any work with the drive train other than differential and the engine So now i'm beginning to understand the suspension, transmission, driveshaft and related joints, steering and alignment parts and issues and how they all work together
    that's why I went ahead and replaced the steering rack. I could've limped along with minimal power steering leaks and used additives to extend the life of the seals. However, I'm trying to get it back to driving as close to new as possible. And getting a brand new steering rack turned out to be a good move because there was definitely some playing in the steering wheel. Having new gears resolved that. I'm not sure a rebuilt one would've done anything but replace the seals.
    now that I've replaced the rack inner and outer tie rods and the entire driveshaft and all related joints, I believe the only thing that hasn't been refreshed is the upper ball joint, control arm bushings, and the leaf springs
    With all the money I've spent in the last few months. I've totally blown my budget. So I'll probably do the springs next year and if I can wait, I'll also do the upper ball joint at that time
  5. Jun 7, 2024 at 7:35 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    ill be revamping my entire PowerSteering system sometime this year as well. Everything sweats fluid.
    jpink, shifty` and Weagle[QUOTED][OP] like this.
  6. Jun 7, 2024 at 12:05 PM
    Thankfully, it seems like the UBJ have so little strain on them they'll probably go hundreds of thous of miles before seeing any noteworthy wear.
  7. Jun 7, 2024 at 12:32 PM
    FishNinja
    Lee
    06DC2wd
    +1
    Unless your UBJ boots are torn or leaky. You should be able to let those fuckers run for awhile longer.
    Weagle[OP] likes this.
