COMPLETED-Oil change time, need some advice....
Discussion in '1st Gen Tundras (2000-2006)' started by bassman417, Sep 25, 2020.
  1. Sep 26, 2020 at 10:17 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    All highway on a 148hp 4 cylinder 20k was deemed safe by black stone.
    More cylinders and especially more stop and go shorter oil change intervals.
  2. Sep 27, 2020 at 6:19 AM
    Lab values aside, in the real world I run full synthetic with the largest factory spec filter I can find in all my vehicles. Currently use the Mobile1 M1-301 oil filter, holds an extra .5 qts of oil (for a total of 7qts) and has a lot of filter media inside for extended oil change runs. Pennzoil Platinum full synthetic for the last 150k miles. Have been changing at 10k miles or annual intervals, whichever came sooner. Last 4-5 years, have changed annually with only 5k or so miles driven. Had a BMW 525i go 455k miles on synthetic with 10k changes (sold it to a friend in Cali). My Tundy is at 256k. Wife's previous SUV (GM) went 188k before we sold it with no leaks, smoking or issues. Son's Mustang is at 178k miles, purrs like a kitten. Wife's current car and daughters car (both Jeeps) are over 100k with no issues as well. That covers all the major brands and every engine configuration out there with no issues, and long life on full synthetic at 10k mile intervals.
    Leo's first likes this.
  3. Sep 27, 2020 at 9:08 AM
    bassman417
    bassman417 [OP] "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    I just finished up the oil change. I went ahead and removed the skid plate, It came off easy and quick. Overall probably the easiest oil change i have ever done. the oil didnt look too bad and still had color. not sure what kind of cheap ass filter they put on but it was way shorter that the yzzd3. I checked the air filter and it looks good to me, see pic. I noticed a lot of my wire and vac hose plastic retainer clips are crumbling. I did a few temp reattachments with zip ties and taped up a couple areas where the plastic wire covers were gone and exposing wires going to the maf sensor. Cleaned up the skid plate real good before putting it back. was going to repaint it but i didnt have enough blk rustoleum to do it,this time.
    Something odd occured after drain and fill. I started her up and ran for a couple minutes to check for leaks, none found, then shut down and dipped the stick to see that it appeared slightly over filled and above the top dot on the stick .I put in 6.4 qts. when i discarded the old oil, it only filled up the 5qt jug. I barely spilled that much oil transferring it.
    So should i be concerned that i over filled it or more that it probably ran a qt low for a few thousand miles.
    20200927_072156.jpg 20200927_072909.jpg 20200927_073419.jpg 20200927_075532.jpg 20200927_081244~2.jpg
    Rsmallw2 likes this.
  4. Sep 27, 2020 at 9:23 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Mine always takes 6-1/2 quarts + or - a bit with a genuine Toyota filter. Park it level tonight and check it in the morning and see where it is. With the oil in the filter and residual oil in the drain pan, you probably had closer to 5-1/2 quarts drained out. Probably nothing to worry about and you can't do anything about it anyway. You have a good baseline now, so you can see how things go from here.
    bassman417[OP] likes this.
  5. Sep 27, 2020 at 12:32 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Just curious about the miles on your truck.
  6. Sep 27, 2020 at 7:00 PM
    bassman417
    Paul
    Las Vegas
    just hit 145000.
  7. Sep 28, 2020 at 5:29 AM
    Professional Hand Model
    Hand Protectors
    Probably under filled by prior goofy oil service tech. Your truck will love you for putting on the proper Toy Sized Filter. If you did over fill, easy enough to drain it by lightly unscrewing the plug and let it drain around the threads of the bolt. I like my oil at the high dot on the stick.
    bassman417[OP] and YardBird like this.
  8. Sep 28, 2020 at 11:03 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I always put in 13 quarts so I can double my oil change interval.
  9. Sep 28, 2020 at 2:54 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I am the same. This last oil change, 7QTS to put it right at the full mark.
  10. Oct 15, 2020 at 10:13 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    I just put on a 301a. My engine is much louder, lifter tick, and start up pressures are noticeably higher. not sure if I like all that paper. Makes me nervous, not sure I can last 5k on all that noise.
  11. Oct 15, 2020 at 11:08 PM
    10 blue trucks
    04 4WD RCLB
    If it doesnt saturate the paper and flow smoother, might have to revert to the mini can or toyota factory long before this 301 is due for replacement.
  12. Oct 16, 2020 at 4:26 AM
    Hand Protectors
    Whats the size of the 301 in relation to the YZZD-3?
  13. Oct 16, 2020 at 6:00 AM
    I haven't used the YZZD-3 filter, but the M1-301 is big. It takes 7qts of oil to fill instead of 6.5. I've not noticed any change in engine sounds, certainly no lifter tick, no change in the pressure compared to the smaller filters I had used before. I would be worried if that were the case. I'm on my 4th oil change with this filter. I was previously using the Bosch 3422, also an oversized version of the 3330 for these engines. No issues with that one either.
  14. Oct 16, 2020 at 7:10 AM
    trueblue1981
    trueblue1981 New Member
    2006 white tundra sr5 dc
    Question for everyone here>>is it ok to use mobil 1 10w30 high milage full synthetic oil on 2006 4.7 tundra?
  15. Oct 16, 2020 at 7:57 AM
    bassman417
    Paul
    Las Vegas
    Thats what i used.I even got a $10 rebate back in about a week also.
    bmf4069 likes this.
  16. Oct 16, 2020 at 8:35 AM
    trueblue1981
    Great thanks for the info!!
  17. Oct 17, 2020 at 7:39 AM
    smokey0810
    What mileage does your truck have on it, and why change now from what you’re currently running? I do agree with running a high mileage (maybe it’s snake oil, lol)
    Adam Carrolla had one of the main guys from Joe Gibbs oil on his carcast podcast a few years back, and was talking about high mileage oil having extra zinc added, which helped, especially in older engines.
  18. Oct 19, 2020 at 4:45 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
