*COMPLETED* Coachbuilder TRD Pro Kit Install
Discussion in '2.5 Gen Tundras (2014-2021)' started by jmevis, Feb 6, 2019.
  1. Nov 21, 2020 at 10:35 PM
    Zizyang
    Zizyang New Member
    2020 tundra pro army green
    @jmevis.... have you done any off roading at all? I want to take my pro to Colorado but with this CB kit is it made for off roading as well. I bought 295/70/18 falken wildpeak at3w and everyone said it was fine, but its rubbing so either i go back to stock tires size or buy this kit. But i wanted to see if people has off road with this kit. I'm not talking about super extreme just lite off road
  2. Nov 21, 2020 at 10:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Where are you getting the rubbing? I just got that same tires on mine and the only thing I encountered was the inside bolt head on the front mud flaps running a little. I’m not running wheel spacers at all... which I believe helps. If anything, you’d likely only need the bumper shim... I just pulled my front mud flaps off.
  3. Nov 21, 2020 at 11:07 PM
    Zizyang
    Zizyang New Member
    bulldog93 likes this.
  4. Nov 21, 2020 at 11:12 PM
    Zizyang
    Zizyang New Member
    @RainMan_PNW ... its rubbing here on both sides. I decided im going to return these tires i plan on doing light off road and these tires takes to much of the wheel well. You lose to much clearance. I dont want to lift my pro either, its perfect the way it came. Check your lower arms and be careful, i was warned and went against what people said. Also if you live in the cold watch your psi drop, the flatter the tires gets, it expand and will hit your uca. Im going back to stock or maybe 275/70/18.
  5. Nov 21, 2020 at 11:35 PM
    Zizyang
    Zizyang New Member
    bulldog93 and RainMan_PNW like this.
  6. Nov 22, 2020 at 12:24 PM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    I have the CB 3” rear shackles ,
    3” EXT Kings up front . The CB bump stops were too high and I lost a lot of articulation . I took them back off. I think you can just lube that broken bolt and drill it in and it will screw out the other side if its open below it.
  7. Nov 22, 2020 at 2:53 PM
    Zizyang
    Zizyang New Member
    @PeakIT... after talking with many people that have the CB kit and people who has 295/70/18 with out the kit. I've decided to go back to stock tires, i will be off-roading and the CB kit no one can tell me long term and 295 just fills up the wheel well to much and not ideal for off roading. One fellow member said to me... the pro can handle medium to lite trails. No need to mess with it unless your going extreme. He had 295 on a stock pro and he damage some parts of his 2020 pro.
  8. Nov 22, 2020 at 3:20 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    You need a wheel spacer or wheels with a more aggressive offset. I have the stock pro wheels with 1.25” bora spacers. No rubbing.
  9. Nov 22, 2020 at 3:28 PM
    Zizyang
    Zizyang New Member
    @LT75. Yes I've read that also. Alot of people are telling me to stay away from spacers, because it transfers weight around. So i decided to keep all stock. With aggressive tires. Thx for all your input i really appreciate it
  10. Jul 14, 2021 at 5:10 PM
    TahoeJon
    TahoeJon New Member
    I hope someone can help me... I recently bought a 2016 TRD from a friend. He put the Coachbuilder kit on. It currently has 25K miles and now the tie rods need to be replaced? I don't know too much, but does anyone know why tie rods would need to be replaced at 25K miles? The only think I can think of, as it's possibly a result of the Coachbuilder kit? Thanks in advance!
  11. Jul 14, 2021 at 5:40 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    That kit is only in 1 inch lift. Shouldn’t really affect it unless the grease escaped somehow. Did he mess with them while installing the coachbuilder kit?
  12. Jul 14, 2021 at 5:46 PM
    TahoeJon
    TahoeJon New Member
    Thanks for the response. I don't believe so, but still waiting to hear back from him. Another buddy looked and said I may need bigger control arms? Does this make sense? I'm definitely clueless on this. Thanks
  13. Jul 14, 2021 at 6:06 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    On my 2018 platinum with a 3 inch lift I changed the control arms to SPC. But on my 2019 Trd pro I left the control arms the same with the Coachbuilder lift. A 1” lift should not affected it. But every truck is different.
  14. Jul 14, 2021 at 6:26 PM
    TahoeJon
    TahoeJon New Member
    Awesome info. Thanks! Much apprecaited.
  15. Jul 14, 2021 at 8:24 PM
    jmevis
    jmevis [OP] New Member
    Nashville TN
    2017 Tundra Trd Pro
    What makes you think you need new ones? Mine were popping but I re torqued them and it went away.
  16. Jul 15, 2021 at 10:04 AM
    TahoeJon
    TahoeJon New Member
    I definitely heard the popping on mine as well. My brother is a mechanic and when throwing up on the rack, he's telling me they need to be replaced. He made the comment that tie rods shouldn't need to be replaced especially at 25K miles. So the only think I could think of is possibly a result of the Coachbuilder kit, or with the mechanic that installed it?
  17. Jul 15, 2021 at 10:32 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    All I did was take the nut off. Pull it out grease it and tighten it back down and it went away just fine.
  18. Oct 21, 2021 at 3:43 AM
    joeyk39
    joeyk39 New Member
    joseph
    Tundra Trd Pro White
    none
    I just received the same exact setup. Did you ride change at all after the 35s and or the installation of the setup? I love the quality of this ride and want to make sure it does not change. Thanks so much in advance and great job.
    Joey:)
  19. Jan 29, 2022 at 9:06 AM
    #49
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    I was wondering if the TRD skid plate still pinned (via the push clips) into the bumper after you added the shims?
  20. Jul 12, 2022 at 9:53 PM
    #50
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    How are the Bora spacers treating you? any issues? you wheel it super hard or just more mellow stuff?
  21. Mar 1, 2023 at 11:28 AM
    #51
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    how does the coachbuilder kit achieve 1 inch of lift on the front if the shims themselves aren't 1" thick? Mine is sitting in the garage and im curious.
  22. Mar 1, 2023 at 11:43 AM
    #52
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    It has to do with triangulation between the upper shock mount, the lower shock mount on the lower control arm and the distance from that lower mount to where your wheel mounts.
  23. Mar 1, 2023 at 12:37 PM
    #53
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    Huh. Interesting. Im contemplating going for some eibach trd pro specific springs instead of the shim to get the front lifted. Thanks for the info
  24. Mar 11, 2023 at 9:23 PM
    #54
    Petergoose1
    Petergoose1 New Member
    2020 pro army green
    Hey, Did you go with the shim or springs? What do you plan on for the rear?
  25. Mar 12, 2023 at 6:19 PM
    #55
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    @Petergoose1 I went with the Eibach front springs, coachbuilder steering kit, bump stop extensions. Thats the front.
    Rear, I did coachbuilder +3 shackle and the carrier bearing drop kit.
    I get the truck back either tomorrow or tuesday. The shop its at doesnt have a ball joint press tool, so I had them install the shackle with the oem bushing in the leafs. I will be swapping in the coachbuilder ones in about a week and a half once I get back from a trip. Ill throw some photos up here once thats done and the truck sits how it will long term.
    Tripleconpanna and Petergoose1 like this.
