COMPLETE loss of throttle as I was crossing a two lane highway
Discussion in '3rd Gen Tundras (2022+)' started by bigredman, May 5, 2023.
  1. May 27, 2023 at 12:38 PM
    saleen079
    saleen079 New Member
    22 Tundra Limited TRD
    Lots of DIY stuff
    Man that's terrible! Your dealership should be somewhat of an advocate when there's an issue. Mine wasnt/ isn't near that bad. I really do love the truck but the only fix to the throttle lag that I can find is the pedal commander. People have said that solves thier issue. You clearly have more bad shit goin on with yours. Hope they get It figured out.
  2. May 27, 2023 at 2:36 PM
    Eagleye
    Eagleye New Member
    22 SR5 4x4
    Rear seat cover, bed mat
    I wonder if the ECU got a seatbelt disconnected input.
  3. May 27, 2023 at 3:33 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    This is exactly it on my pickup. Make a complete stop, no hesitation or lag. Come to a rolling stop, and I get hesitation/lag every time. It's so predictable, I can time the lag with oncoming traffic.
  4. May 27, 2023 at 4:10 PM
    THOR's
    THOR's New Member
    Thor
    North Carolina
    2021 Tundra TRD Sport and XP Predator Package
    If the dealer cannot fix this issue, I'd sell the truck and get something else. Bottom line is that it should not be behaving in this fashion.
  5. May 28, 2023 at 11:05 PM
    SDT
    SDT New Member
    B
    2022 Limited Tundra Mesquite
    TRD running boards/skid plate
    TSB didn't help here. Happens almost every morning pulling up out of my driveway to the point of I'd like to invite a service tech over in the morning to see it happen dependably. It's scary and ridiculous. There's no way Toyota doesn't know about it, it's just probably not an easy fix at this point.
    jeosbor1 likes this.
  6. Jun 13, 2023 at 1:20 PM
    Tusa123
    Tusa123 New Member
    New Tundra owner here, Limited TT with 1,100 miles. I think I’ve found the right thread. Started to ease into traffic and as I was in the middle of pulling out the truck lost all power. Regained it and I was able to begin accelerating through the intersection when it happened again. I went straight to the dealer and have an appointment for tomorrow. Is there any advice I can pass along to the dealer in terms of replicating the issue?
    Also, the Turbo lag. Is this the over revving that I have to do to get this truck moving while easing into the throttle? It gets to about 1500-2000 rpm before it starts to behave like a normal vehicle. It almost feels like a detachable lift chair on a mountain. It starts going slowly and eventually the chair grabs the cable and takes off? I’ve had this since day one and noticed it very clearly on my 10 hour drive home.
    Anything to prep me for my dealer visit tomorrow would be huge! Thanks y’all.
    Kap1 and mattymags like this.
  7. Jun 13, 2023 at 2:13 PM
    saleen079
    Lots of DIY stuff
    I have noticed when I'm pulling my camper in tow+ it hasn't lagged, Does it in all other modes. I've had mine in 2 different dealerships with no solution. One tech tried to tell me it was my air filters. Good luck!
  8. Jun 14, 2023 at 7:44 AM
    6thyota
    6thyota New Member
    23 TSS Tundra
    Following!
    Mine had not done this yet but after reading the different posts I have to wonder if the problem is one of the new
    “ fabulous ” safety sensors kicking in by mistake. Like if you open the door while the engine is running- zero throttle
  9. Jun 14, 2023 at 8:28 AM
    violetkibbles22
    violetkibbles22 New Member
    2022 tundra
    Did the tsb on mine worked good for a bit then it came back! Rolling stops is where it’s really noticeable.
  10. Jun 14, 2023 at 8:39 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    For me as I drive up my drive way Trans shifts to 2nd as I slow down it will pull throttle to shift into first then throttle is restored. Past Ford would just bang into first and the whole truck would shake. For me as I understand it's just pulling throttle to get into 1st gear smoothly. I'm ok with it.
    CRFL82 likes this.
  11. Jun 14, 2023 at 9:49 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Did you had the TSB done at the dealer? It addresses this issue and may help. See the TSB updates sticky thread
