Come on Toyota...a little lazy are we?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ScenicRoute, May 4, 2021.
  1. May 4, 2021 at 2:10 PM
    Elduder
    Elduder New Member
    Option "LB" is labeled as a "spray on bed liner".
  2. May 4, 2021 at 2:14 PM
    G10dra
    G10dra Not a New Member
    A port-installed Toyota option doesn't cut corners. There are two ways to know if the bed liner was from Toyota
    1. The most obvious one is in your bed If you have the word "TUNDRA" embedded then the bed liner on the back wall was port installed. Dealerships/local installers can't replicate that. seen an example in this picture here.
    Source https://www.cars.com/vehicledetail/detail/845707338/overview/
    Furthermore, you can see the bed liner was sprayed all the way to the top of the walls. That's Toyota standards.
    2. Check your Vin number here. You will see under Port or Factory installed equipment section if your bed liner was from Toyota
    In the case of this truck above, it was
    So in OP's case a Toyota dealership got it done locally.
    Wynnded likes this.
  3. May 4, 2021 at 2:16 PM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    I have the Tundra stamp and mine is not sprayed behind the rails.:notsure:
    Hbjeff, Rocko9999 and BravoDeltaRomeo like this.
  4. May 4, 2021 at 2:19 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Nevermind,well at least partially.
    Actually yours is post production so Toyota did not install it, I just dont accept that the factory would do it this way.
    Also notice the blue thread lock in the hex head bolts re-installed in the rail holes?
    This truck had the rails clearly from birth.
    Boerseun and Elduder[QUOTED] like this.
  5. May 4, 2021 at 2:28 PM
    ScenicRoute
    ScenicRoute [OP] New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Negative. I’m the OP. I watched it come off the hauler it was already spray in bedlined and it is stamped TUNDRA on the front too.
    BravoDeltaRomeo likes this.
  6. May 4, 2021 at 2:29 PM
    G10dra
    Lets see it
  7. May 4, 2021 at 2:46 PM
    I_Am_Thee_Walrus
    Don’t mind the extra weather stripping in the front..
    You can see easily from the bottom-up and through the holes that it is not sprayed behind the rails. It is also something no one will notice except for me and I don’t particularly care.
    BD0B58F0-B407-4A20-AFE2-C9F562DB2327.jpg 66060103-8E5F-4D93-9EB6-F878BE51BC62.jpg ED112BE1-072E-4682-9410-432C402B7386.jpg
  8. May 4, 2021 at 3:15 PM
    All 4 of my corner tie downs are sprayed. Behind my rails is sprayed as well. I don't think I have Tundra stamped at the front.
  9. May 4, 2021 at 3:17 PM
    G10dra
    I am dumbfounded that Toyota has started cutting corners like this. I didn't see this happening in the 2020s.
    Here is a picture from Carvana from a 2020 model
  10. May 4, 2021 at 3:29 PM
    ScenicRoute
    Hence my point of them being lazy!
    It’s sort of like if I pulled off the molding or the badges and it was just primer underneath.
  11. May 4, 2021 at 3:32 PM
    JC21Tundra
    JC21Tundra If I'm not here, I'm somewhere else...
    Jeff
    St L Missouri
    2021 MGM Tundra Crew Cab TRD Sport 4x4
    looked the same on my Tacoma and it did not have the spray in bed liner.
    I was going to remove and keep the bed rail system before I traded it so I could put them in my Tundra, but when I saw that underneath and left them on the Taco.
  12. May 4, 2021 at 3:54 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Wait til you need to remove your bed bolts. :laugh: They spray over them at the port.
  13. May 4, 2021 at 6:51 PM
    ScenicRoute
    here
  14. May 4, 2021 at 6:55 PM
    IndianaGeologist
    IndianaGeologist New Member
    Rails or not, this is lazy. My line-x dealer removed my rails prior to spray.
  15. May 4, 2021 at 7:36 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    It's not lazy, it's efficient and maximizes positional accuracy by eliminating a variable in the tolerance stack-up.
    Installing rails over bedliner increases variation in positional range.
    Sure a couple MM's per side may not seem like a big deal, but ultimately can create a fit issue for aftermarket accessories with a set bed width to rails.
    Masking ensures whether line-x'ed or not, the rail position is the same truck bed to truck bed.
    Since its covered up. it's protected and therefore does not require line-x protection. The dis-assembled appearance is unfortunate.
    Sure it's a cost down on spray materials, but OEM's don't design nor cater to customers who complain about dis-assembled conditions. Vehicles are evaluated in full assembled condition only.
    Example: Customer complained floor carpet has cutouts when center console was removed.
    Boerseun, Bakershack, Jaypown and 6 others like this.
  16. May 4, 2021 at 7:57 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    Bammer, landphil and Cpl_Punishment like this.
  17. May 4, 2021 at 8:03 PM
    IndianaGeologist
    We buy Toyota as a brand for quality and reliability, sure I want them to be efficient as possible, but not taking corners on options that charge as much if not more than line-x and provide worse quality.
    CurtisLemansky likes this.
  18. May 4, 2021 at 8:10 PM
    HighonFirewood
    2019 Tundra
    I stand by my mic drop.
  19. May 4, 2021 at 8:12 PM
    #49
    IndianaGeologist
    I still disagree
  20. May 4, 2021 at 8:15 PM
    #50
    HighonFirewood
    2019 Tundra
    But...what about now? I’m giving you a mic drop too!
  21. May 4, 2021 at 8:55 PM
    #51
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    What kind of aftermarket accessories would require this level of precision for fitment and wouldn’t account for a couple MM tolerance in such?
    Also, why would Toyota care?
  22. May 4, 2021 at 10:22 PM
    #52
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I agree that the rails will fit better without the liner underneath it, whether that matters all that much is debatable.
    I also agree that it would have been better to install that cap using the rail system clamps instead of removing that feature.
    You lose the use of the rails for other things and create an eyesore and, thus, this topic.
    I disagree that its Toyota being lazy or cutting corners regarding spray around the rails, or over the bed bolts and clamps.
    This is not a factory/assembly line feature, its an add on after the truck leaves the factory, not something that leaves San Antonio on the truck. Whether its port installed, dealer sourced, customer sourced or a DIY job, there's going to be some variation in the process and results. Each source may have a slightly different process or standard, but I don't think its a matter of one cheaping out while the other is going the extra mile, its just a different way of lining the bed.
    Either way, its not like Toyota is leaving it up to the port or dealerships to build the motors or transmissions or wiring harnesses and all that kind of internal stuff, so I wouldn't equate a spray-in liner with stuff that really matters in the overall reliability of the truck as built by the actual factory.
  23. May 5, 2021 at 4:50 AM
    #53
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    If I were Toyota I'd do it the same way. Very few people are ever going to touch anything in the bed, might as well guarantee that those fasteners never work themselves loose.
    Yeah it's a huge PITA. I had to remove my two tie-downs when installing my bed extender. The best way to expose the bolt holes was to heat up a sturdy nail till red hot and then burn the crap off. Using a torch directly on the bolts was too much, I'd fry the surrounding material as well.
    joonbug[QUOTED] likes this.
  24. May 5, 2021 at 5:38 AM
    #54
    ScenicRoute
    So, I am the OP. I installed this myself with what was supplied. Was a bit disappointed to see the rails had to be removed as I specifically wanted them for the bed. So....I can’t find these special rail clamps that would allow me to retain the rails. I’d gladly buy them if they’re compatible with the rails and my rsi smartcap.
  25. May 5, 2021 at 5:45 AM
    #55
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    https://www.tundras.com/threads/come-on-toyota-a-little-lazy-are-we.88424/#post-2224024
  26. May 5, 2021 at 5:52 AM
    #56
    ScenicRoute
  27. May 5, 2021 at 7:13 AM
    #57
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Mostly correct, except that Toyota does not install bed liners. The port is not Toyota, it is a private franchise, or "middleman dealer". The different regional ports are independently owned and they can install options the way they want to. There is no "Toyota standard" for bed liners. One specific port might decide to contract with Line-Ex to do their liners while another might have a guy employed to do it at the distribution facility. Same can happen at the dealer.
    In other words, there is not necessarily any difference between a port installed option and a dealer installed option, or if there is a difference, there is no guarantee that one will be better than the other.
    Wynnded likes this.
  28. May 5, 2021 at 7:23 AM
    #58
    Boerseun
    Ferdie
    Sarasota Florida
    There are drop brackets available to re-install the rails a little lower, so you can keep your current cap clamps and keep your rails.
  29. May 5, 2021 at 7:26 AM
    #59
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Just buying the correct clamps is less costly...
  30. May 5, 2021 at 7:28 AM
    #60
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    The Bed Bolts are one of the few things that my Line-X dealer did remove (along with the bedrail).
