Colorado BS Thread
Discussion in 'Colorado' started by T-Rex266, Jan 6, 2014.
  1. Jan 17, 2021 at 4:07 PM
    #4501
    If you separate the red 1 it will solve the problem.
  2. Jan 17, 2021 at 4:08 PM
    #4502
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    Man. I suck. I don’t know what that means! I may need to call you. So flipping frustrated with this
  3. Jan 17, 2021 at 4:09 PM
    #4503
    I rigged up my light bar and ditch lights with remotes. Easy peasy.
  4. Jan 17, 2021 at 4:10 PM
    #4504
  5. Jan 17, 2021 at 4:10 PM
    #4505
    HighonFirewood
    2019 Tundra
    Yeah I honestly can’t figure out why this is a problem. Black/black. White/white. And two reds. Each red keeps switch on. One red powers light. One red doesn’t. But either red switch is on. No matter the configuration the switch is on. Losing my mind.
  6. Jan 17, 2021 at 4:14 PM
    #4506
    HighonFirewood
    2019 Tundra
    Do I have to tap onto another? I put it in the dash where I tap into another
  7. Jan 17, 2021 at 4:15 PM
    #4507
    I had the same issues you are going thru. I have 2 small remotes. One controlling my light bar and the other controlling my ditch lights. Both remotes are located in my aftermarket mossy oak visor attachment. I love it. Much simpler than f'ing around with panel switches.
  8. Jan 17, 2021 at 4:21 PM
    #4508
    Can you post a picture of the switch location?
  9. Jan 17, 2021 at 4:22 PM
    #4509
    HighonFirewood
    2019 Tundra
    I guess I need something like this. My issue seems easy but I’ve tried every option other than tying to tap into another switch. Which doesn’t make sense to me. I don’t even need the switch lit with dash lights. I just want the light bar to function when I’m out in the shit. Which is often. I’m on dirt roads in Wyoming or Nebraska often, always wish I had more light. Now hoping I don’t kill my battery out in the middle of nowhere
  10. Jan 17, 2021 at 4:25 PM
    #4510
    HighonFirewood
    2019 Tundra
    I didn’t actually put it in till I knew it was all good. So its set that I can run the connection through the back and put the switch in...but currently floating in my foot area till it’s dialed0791BF19-AF59-4432-B523-97932A6F9AA8.jpg
  11. Jan 17, 2021 at 4:32 PM
    #4511
    HighonFirewood
    2019 Tundra
    I had to add a 3 conduit to my harness from the engine bay. Which looks a little confusing. So in this photo it’s white black and green (but green is actually a red) . My switch harness has two reds (which go to green) and the rest is wired correctly. I had to add an extension witch made colors switch. I guess I wil pull green and see if I’m reversed but I can’t be. B6155F6D-E8AA-430F-8C1B-F71A7E7217DA.jpg
  12. Jan 17, 2021 at 4:33 PM
    #4512
    Show me where you are putting the switch eventually.
  13. Jan 17, 2021 at 4:43 PM
    #4513
    HighonFirewood
    2019 Tundra
    I’m holding it in front of where it will go. Between the two cigarette spots
  14. Jan 17, 2021 at 4:47 PM
    #4514
    HighonFirewood
    2019 Tundra
    Jim I appreciate you spending the time on this. It’s weird because it literally makes no sense. I only have 4 Options. 1 red, or the other red, both red, no red (which is no power)
  15. Jan 17, 2021 at 4:48 PM
    #4515
    So the closet lighted switch would be the tow/haul button. Get a test light and check if there is a green wire behind that switch. If there is see if the test light lights up when you turn the headlights on and that's where you tap the red 2 into.
    The tan wire should be power. If you tap into that I would put a inline fuse.
  16. Jan 17, 2021 at 4:49 PM
    #4516
    :hattip:
  17. Jan 17, 2021 at 4:53 PM
    #4517
    HighonFirewood
    2019 Tundra
    Ok. Makes sense. I was just thinking I wouldn’t need to tap into another switch. I’m an electrical amateur
  18. Jan 17, 2021 at 4:54 PM
    #4518
    Just don't use that hammer.:rofl:
  19. Jan 17, 2021 at 4:57 PM
    #4519
    I'll be back later. Feel free to PM me if you still need help.
  20. Jan 17, 2021 at 5:11 PM
    #4520
    HighonFirewood
    2019 Tundra
    Yeah. I’ll suck the life outta ya at this point. Might need my ass wiped too. Seems so simple but apparently it’s not. Tried every configuration
  21. Jan 17, 2021 at 5:17 PM
    #4521
    This^
  22. Jan 17, 2021 at 6:28 PM
    #4522
    HighonFirewood
    2019 Tundra
    Inline fuse exists between the switch and the relay...
  23. Jan 26, 2021 at 12:24 PM
    #4523
    vanthesupreme
    vanthesupreme I'm Batman
    OKlahoma
    2014 Tundra
    Gonna be heading to Dillon, CO in a couple of weeks and was wondering what trails you guys would recommend hitting for the weekend
  24. Jan 26, 2021 at 12:38 PM
    #4524
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    besides most of it being closed, it's the high country in winter and this year, the snow pack is pretty unstable. i could recommend some hike/snowshoe spots...
    Black Wolf, Nic146 and Wynnded like this.
  25. Jan 26, 2021 at 12:44 PM
    #4525
    vanthesupreme
    OKlahoma
    2014 Tundra
    Thanks for the heads up. Guess I will have to wait till spring/summer
    Nic146 and smslavin[QUOTED] like this.
  26. Jan 26, 2021 at 12:48 PM
    #4526
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    :cheers:
    wouldn't want you getting caught in a bad spot. you should go take a peek at the ice castles. pretty cool.
    https://icecastles.com/colorado
    Black Wolf and Nic146 like this.
  27. Jan 26, 2021 at 1:06 PM
    #4527
    vanthesupreme
    OKlahoma
    2014 Tundra
    That's the plan for the weekend trip
  28. Feb 7, 2021 at 10:58 AM
    #4528
    HighonFirewood
    2019 Tundra
    In Fort Collins today..saw a 2nd Gen Blue lifted (4” or so) Tundra with a Soft Topper and Kenda Kevlar Tires..multi colored American flag stickers..who is this? Anyone on here? Seriously the sickest truck I’ve seen in town.
  29. Feb 7, 2021 at 11:08 AM
    #4529
    Nic146
    Nic146 New Member
    Probably stuck somewhere
    2016 Barcelona Red TRD CM
    Ahh I saw that truck too!
    I feel like I’m seeing more and more cool tundras by the day
  30. Feb 7, 2021 at 5:58 PM
    #4530
    I went to Stevensons East yesterday to buy a replacement passenger side roof molding. Saw several Tacos, a red Supra, and ONE Tundra.
