Color Matched Mirror Caps Cement
Discussion in '3rd Gen Tundras (2014+)' started by Napvid, Feb 9, 2019 at 4:36 PM.
  1. Feb 9, 2019 at 4:36 PM
    Napvid
    Napvid [OP] New Member
    Dave
    2018 Cement CM Limited XP
    ASV Vent Visors, Rough Country Bull Bar With LED, Rough Country Fender Flare/Rivets, Rough Country Floor Mats......
    No turning back now!
  2. Feb 9, 2019 at 4:43 PM
    TXTundra2722
    TXTundra2722 New Member
    2015 black Tundra
    Good luck! I'm sure that it will turn out nicely as long as you don't rush it
    Napvid [OP] likes this.
  3. Feb 9, 2019 at 4:46 PM
    Xplorin
    Xplorin New Member
    2019 cement crewmax
    I wish I had chrome ones to do this
  4. Feb 10, 2019 at 10:22 AM
    Napvid
    Dave
    Very pleased with the way it came out. Color match is spot-on. Going to give the clear coat sometime to harden before I install . Maybe a day or two . Next on the list is the door handles. And then I think I will have the confidence to do the Bulge and bumper caps.
  5. Feb 10, 2019 at 10:24 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    2010 Super White DC
    Very nice! Looks a lot better than some of the other color-match attempts I've seen.
  6. Feb 10, 2019 at 11:12 AM
    Markman
    Markman New Member
    Mark
    Utah
    2019 limited cement cm
    Tint and airbags so far
    Looks good keep us posted on the door handles I'm way curious myself!!!:thumbsup:
    mattyd170 and Napvid [OP] like this.
  7. Feb 10, 2019 at 11:51 AM
    Tundra1078
    Tundra1078 New Member
    Peter
    Los Angeles
    2018 White Platinum 4x4
    TRD dual exhaust, sway bar, TRD skid plate, grab handle (future), husky liners
    Where did you purchase the color matched paint? Looks nice.
  8. Feb 10, 2019 at 1:13 PM
    Napvid
    Dave
    I got the paint from here.
    http://www.automotivetouchup.com
    Here is a screenshot of my order. I actually ordered one more clear coat because once you pop the can it is only good for the day. And I think I ordered one more of the Cement This should be enough to do my mirror caps , door handles, bumper caps, Grill surround and bulge. I added up what it would take to purchase the pieces prefinished from Sparks and Toyota and we were over $2,000 because Cement is a surcharge.
  9. Feb 10, 2019 at 1:21 PM
    TheBeast The Beach
    very nice. looks pro.
  10. Feb 10, 2019 at 1:50 PM
    scgrab21
    scgrab21 New Member
    Maryland
    Tundra CM|Limited|TRD| Cement
    That is impressive. Do you have how-to for us less paint inclined?
  11. Feb 10, 2019 at 2:25 PM
    TXTundra2722
    2015 black Tundra
    Looks good!
  12. Feb 10, 2019 at 2:32 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Borla Cat-back, Black Rock Warrior Wheels, Black LED Tails, HID conversion, Tonneau 3/1 lift A lot of minor stuff
    For that cost, could a shop have done it for less? Before I had my shop, I was getting bumpers sprayed for $100... Either way, nice work man.
  13. Feb 10, 2019 at 10:07 PM
    tundradownsouth
    tundradownsouth New Member
    New Orleans
    19 tundra crewmax
    Looks good.. how many coats did you do for each?
  14. Feb 11, 2019 at 7:35 AM
    Napvid
    Dave
    Thanks man. The paint I bought is enough to do mirror caps, door handles, Grill surround, bulge and bumper caps. I did get quotes to paint everything and it was between $1,200 to $1,600 at different shops. I figure $200 in paint and supplies and my own labor to save over $1,000 is worth it IMO. Plus with me doing it myself I get to pay direct attention to detail.
    1BadTundra and mattyd170 like this.
  15. Feb 11, 2019 at 7:37 AM
    Napvid
    Dave
    After I get off work and get some time to write up the process I will post it to my original post. Thanks for the interest I believe it is well worth it. That is if you'd like to get rid of your Chrome for a reasonable price.
  16. Feb 11, 2019 at 8:06 AM
    Bongskie
    Bongskie New Member
    2016 Black Crew
    6" Pro Comp Kit, Mayhem 20" rim, Toyo M/Ts
    Nicely done.
  17. Feb 11, 2019 at 8:30 AM
    mattyd170
    mattyd170 New Member
    2012 Tundra Platinum Crewmax. Barcelona Red
    Bilstein 5100's middle with 2 CB shims.
    I understand the whole process. I just want to know what you used to sand your chrome caps with. 400 grit knock down to scuff up or what. I have a platinum edition and am looking to do the same thing. I plastidipped my mirrors black for now, but want to color match. Also bought black door handles to color match and the grill,,,,,,,,,,,,,,,omg. Lol. Thanks.
    LOOKS GREAT BY THE WAY!!!!!!!!!!!!!!!
  18. Feb 11, 2019 at 9:31 AM
    Napvid
    Dave
    Thanks man. I tried 320 first but didn't seem to be coarse enough for me. So I went with 120 for a nice deep scuff and then I worked it up to 800. Just make sure you get a nice dull finish on the whole cap . Then I laid my primer down three coats wet sanding with a thousand in between each coat. Pay special attention to the edges of the Caps because there is a slight micro rise along the edge that would not allow the Sandpaper to scuff along the edge. Also I sanded everything by hand.
    mattyd170 likes this.
  19. Feb 11, 2019 at 9:56 AM
    conlons26
    conlons26 Funboy
    Raleighwood, NC
    2018 Quiksand Limited CM
    Got some sweet floor mats so far...
    Looks great! So I also color matched my mirror backs and panted my handles black...yes way cheaper than buying the color matched pieces. Used paint from touch up direct and it was a great match with my quicksand. For what its worth I did a lot of research and it seemed many folks had problems with paint holding up over the chrome and that more than not paint shops would not paint over the chrome. Not trying to scare you and hopefully it holds up. However...if you decide to de chrome the pieces and start with the stripped plastic peroxide and muriatic acid at 2:1 is your friend. dump it in a rubber maid container or 5 gallon bucket, drink a 6 pack, come back 3 hours later, pull them out wash them with water...done. Wear rubber gloves, the ones under the sink for cleaning, if you would like to keep your skin. I plan on doing the bulge and surround too, just need to figure an appropriate shaped container to strip them in. Bumper ends are a different story, either need to take to a chrome plater and have them stripped or sand/media blasted off.
  20. Feb 11, 2019 at 10:53 AM
    Napvid
    Dave
    Thanks man and thanks for the advice. I was going to use the method you suggested with the muriatic acid but didn't want to deal with waste disposal. I think I knocked down the chrome enough and with the adhesion promoter for plastic it was a really good base to start with. But of course time will tell but I am confident it will hold up. And yea for the bumper ends I have a sand blaster to knock them down with.
  21. Feb 11, 2019 at 11:02 AM
    conlons26
    conlons26 Funboy
    Raleighwood, NC
    In payment for the advice ill be sending you my bumper ends to be blasted...:spending:
  22. Feb 12, 2019 at 9:51 AM
    Napvid
    Dave
    Mirror caps are installed. And it looks just as good as I hoped it would. Door handles are next. But now I have a conundrum. Guy on my Facebook group Florida Tundra Crew also did his mirror caps color matched this weekend but he did his door handles black instead of color match. I really like the way it looks. The last picture is his in desert sand.
    NewImprovedRon likes this.
  23. Feb 12, 2019 at 10:27 AM
    mattyd170
    Either will look good, especially against Cement. I bought black ones to paint Barcelona Red, but just installed them black for now and really like the look. If you have to paint or are going to paint, do them in cement to match, can always do black over them later, or buy black ones. I lucked out and found a set on eBay cheap.
  24. Feb 12, 2019 at 10:45 AM
    conlons26
    conlons26 Funboy
    Raleighwood, NC
    I personally like the black, thats what i did on my truck but both will look good.
  25. Feb 12, 2019 at 11:26 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Nice job @Napvid !!! Especially from a can, they look perfect installed :)
